查看: 4574|回复: 10
[原创]:一个选择集的增强类
发表于 2004-11-18 22:40:09 | 显示全部楼层 |阅读模式
  1. 'TlsSel类
  2. 'By 雪山飞狐
  3. '模块名---TlsSel
  4. ' You may use the code included in this module in any way,
  5. ' provided that both the above copyright notice and the
  6. ' release of liability (stated below) appear in all copies.
  7. Private oSel As AcadSelectionSet
  8. Private TlsFt, TlsFd
  9. Private sName As String
  10. Public Sub NullFilter()
  11. '清空过滤器
  12.     TlsFt = Null
  13.     TlsFd = Null
  14. End Sub
  15. Private Function IsNull() As Boolean
  16.     If oSel Is Nothing Then
  17.         IsNull = True
  18.     ElseIf oSel.Count = 0 Then
  19.         IsNull = True
  20.     Else
  21.         IsNull = False
  22.     End If
  23.
  24. End Function
  25. Public Sub Init(Optional ByVal Name As String = "TlsSel")
  26. '创建选择集
  27. On Error Resume Next
  28.
  29.     NullFilter
  30.     If Not oSel Is Nothing Then oSel.Delete
  31.     sName = Name
  32.     ThisDrawing.SelectionSets(sName).Delete
  33.     Set oSel = ThisDrawing.SelectionSets.Add(sName)
  34.
  35. End Sub
  36. Private Sub Class_Terminate()
  37. '类析构时清除选择集
  38. On Error Resume Next
  39.
  40.     If Not oSel Is Nothing Then oSel.Delete
  41.
  42. End Sub
  43. Public Function ToArray()
  44. '转化选择集为对象数组输出
  45. On Error Resume Next
  46.
  47.     Dim i
  48.     Dim objs() As AcadEntity
  49.     Dim nCount As Integer
  50.
  51.     nCount = oSel.Count - 1
  52.     ReDim objs(nCount)
  53.
  54.     For i = 0 To nCount
  55.         Set objs(i) = oSel(i)
  56.     Next i
  57.
  58.     ToArray = objs
  59.
  60. End Function
  61. Public Property Get Count() As Integer
  62. '获取选择集实体个数
  63. On Error Resume Next
  64.     Count = oSel.Count
  65.
  66. End Property
  67. Public Property Get Name() As String
  68. '获取选择集名称
  69. On Error Resume Next
  70.     Name = sName
  71.
  72. End Property
  73. Public Property Get Item(ByVal Index) As AcadEntity
  74. '获取选择集实体
  75. On Error Resume Next
  76.     Set Item = oSel(Index)
  77.
  78. End Property
  79. Public Sub Add(ByVal obj)
  80. '向选择集加入单个实体
  81. On Error Resume Next
  82.
  83.     Dim objs(0) As AcadEntity
  84.
  85.     Set objs(0) = obj
  86.     oSel.AddItems pbjs
  87.
  88. End Sub
  89. Public Sub AddItems(ByVal objs)
  90. '向选择集加入实体数组
  91. On Error Resume Next
  92.
  93.     oSel.AddItems objs
  94.
  95. End Sub
  96. Public Sub Remove(ByVal obj)
  97. '在选择集中移除单个实体
  98. On Error Resume Next
  99.
  100.     Dim objs(0) As AcadEntity
  101.     Set objs(0) = obj
  102.     oSel.RemoveItems objs
  103.
  104. End Sub
  105. Public Sub RemoveItems(ByVal objs)
  106. '在选择集中移除实体数组
  107. On Error Resume Next
  108.
  109.     oSel.RemoveItems objs
  110.
  111. End Sub
  112. Public Sub Clear()
  113. '清空选择集
  114. On Error Resume Next
  115.
  116.     Select Case sName
  117.     Case "PICKFIRST"
  118.         GetPickfirstSel
  119.     Case "CURRENT"
  120.         GetActiveSel
  121.     Case Else
  122.         Init sName
  123.     End Select
  124.
  125.     oSel.Clear
  126.
  127. End Sub
  128. Public Sub Update()
  129. On Error Resume Next
  130.
  131.     oSel.Update
  132. End Sub
  133. Public Function GetSel() As AcadSelectionSet
  134. '获取选择集
  135. On Error Resume Next
  136.
  137.     Set GetSel = oSel
  138.
  139. End Function
  140. Public Sub GetPickfirstSel()
  141. '获取Pickfirst选择集
  142. On Error Resume Next
  143.
  144.     NullFilter
  145.     If Not oSel Is Nothing Then oSel.Delete
  146.     sName = "PICKFIRST"
  147.     ThisDrawing.SelectionSets(sName).Delete
  148.     Set oSel = ThisDrawing.PickfirstSelectionSet
  149.
  150. End Sub
  151. Public Sub GetActiveSel()
  152. '获取Active选择集
  153. On Error Resume Next
  154.
  155.     NullFilter
  156.     If Not oSel Is Nothing Then oSel.Delete
  157.     sName = "CURRENT"
  158.     ThisDrawing.SelectionSets(sName).Delete
  159.     Set oSel = ThisDrawing.ActiveSelectionSet
  160.
  161. End Sub
  162. Public Sub SetFilterType(ParamArray FilterType())
  163. '设置过滤器类型
  164. On Error Resume Next
  165.
  166.     Dim i
  167.     Dim nCount As Integer
  168.     nCount = UBound(FilterType)
  169.
  170.     Dim ft() As Integer
  171.     ReDim ft(nCount)
  172.
  173.     For i = 0 To nCount
  174.         ft(i) = FilterType(i)
  175.     Next i
  176.
  177.     TlsFt = ft
  178.
  179. End Sub
  180. Public Sub SetFilterData(ParamArray FilterData())
  181. '设置过滤器数据
  182. On Error Resume Next
  183.     Dim i
  184.     Dim nCount As Integer
  185.     nCount = UBound(FilterData)
  186.
  187.     Dim fd()
  188.     ReDim fd(nCount)
  189.
  190.     For i = 0 To nCount
  191.         fd(i) = FilterData(i)
  192.     Next i
  193.
  194.     TlsFd = fd
  195.
  196. End Sub
  197. Public Sub SetFilter(ParamArray Filter())
  198. '设置过滤器
  199. On Error Resume Next
  200.
  201.     Dim i
  202.     Dim n As Integer
  203.     Dim nCount As Integer
  204.     nCount = (UBound(Filter) + 1) / 2 - 1
  205.
  206.     Dim ft() As Integer, fd()
  207.     ReDim ft(nCount), fd(nCount)
  208.
  209.     For i = 0 To nCount
  210.         n = i * 2
  211.         ft(i) = Filter(n)
  212.         fd(i) = Filter(n + 1)
  213.     Next i
  214.
  215.     TlsFt = ft
  216.     TlsFd = fd
  217. End Sub
  218. Public Sub SelectObjectOnScreen()
  219. On Error Resume Next
  220.
  221.     If IsArray(TlsFt) Then
  222.         oSel.SelectOnScreen TlsFt, TlsFd
  223.     Else
  224.         oSel.SelectOnScreen
  225.     End If
  226.
  227. End Sub
  228. Public Sub Selectobject(ByVal Mode As AcSelect, Optional ByVal Point1, Optional ByVal Point2)
  229. On Error Resume Next
  230.
  231.     If IsArray(TlsFt) Then
  232.         If IsMissing(Point1) Then
  233.             oSel.Select Mode, , , TlsFt, TlsFd
  234.         Else
  235.             oSel.Select Mode, Point1, Point2, TlsFt, TlsFd
  236.         End If
  237.     Else
  238.         If IsMissing(Point1) Then
  239.             oSel.Select Mode
  240.         Else
  241.             oSel.Select Mode, Point1, Point2
  242.         End If
  243.     End If
  244.
  245. End Sub
  246. Public Sub SelectObjectAtPoint(ByVal Point)
  247. On Error Resume Next
  248.
  249.     If IsArray(TlsFt) Then
  250.         oSel.SelectAtPoint Point, TlsFt, TlsFd
  251.     Else
  252.         oSel.SelectAtPoint Point
  253.     End If
  254.
  255. End Sub
  256. Public Sub SelectObjectByPolygon(ByVal Mode As AcSelect, Optional ByVal Points, Optional ByVal Point2)
  257. On Error Resume Next
  258.
  259.     If IsArray(TlsFt) Then
  260.         oSel.SelectByPolygon Mode, Points, TlsFt, TlsFd
  261.     Else
  262.         oSel.SelectByPolygon Mode, Points
  263.     End If
  264.
  265. End Sub
  266. Public Property Let Visible(ByVal Value As Boolean)
  267. On Error Resume Next
  268.     If IsNull() Then Exit Property
  269.
  270.     Dim i As AcadEntity
  271.     For Each i In oSel
  272.         i.Visible = Value
  273.     Next i
  274.
  275. End Property
  276. Public Property Let Layer(ByVal Value As String)
  277. On Error Resume Next
  278.     If IsNull() Then Exit Property
  279.
  280.     Dim i As AcadEntity
  281.     For Each i In oSel
  282.         i.Layer = Value
  283.     Next i
  284.
  285. End Property
  286. Public Property Let LineType(ByVal Value As String)
  287. On Error Resume Next
  288.     If IsNull() Then Exit Property
  289.
  290.     Dim i As AcadEntity
  291.     For Each i In oSel
  292.         i.LineType = Value
  293.     Next i
  294.
  295. End Property
  296. Public Property Let Color(ByVal Value As ACAD_COLOR)
  297. On Error Resume Next
  298.     If IsNull() Then Exit Property
  299.
  300.     Dim i As AcadEntity
  301.     For Each i In oSel
  302.         i.Color = Value
  303.     Next i
  304.
  305. End Property
  306. Public Sub Move(Optional ByVal Point1, Optional ByVal Point2)
  307. On Error Resume Next
  308.     If IsNull() Then Exit Sub
  309.     If IsMissing(Point1) Then Point1 = CreatePoint()
  310.     If IsMissing(Point2) Then Point2 = CreatePoint()
  311.
  312.     Dim i As AcadEntity
  313.     For Each i In oSel
  314.         i.Move Point1, Point2
  315.     Next i
  316.
  317. End Sub
  318. Public Function Copy(Optional ByVal Point1, Optional ByVal Point2)
  319. On Error Resume Next
  320.     If IsNull() Then Exit Sub
  321.     If IsMissing(Point1) Then Point1 = CreatePoint()
  322.     If IsMissing(Point2) Then Point2 = CreatePoint()
  323.
  324.     Dim objs() As AcadEntity
  325.     Dim i
  326.     ReDim objs(Count - 1)
  327.
  328.     For i = 0 To Count
  329.         Set objs(i) = oSel(i).Copy
  330.         objs(i).Move Point1, Point2
  331.     Next i
  332.
  333.     Copy = objs
  334.
  335. End Function
  336. Public Sub Rotate(Optional ByVal BasePoint, Optional ByVal RotationAngle As Double = 1#)
  337. On Error Resume Next
  338.     If IsNull() Then Exit Sub
  339.     If IsMissing(BasePoint) Then BasePoint = CreatePoint()
  340.
  341.     Dim i As AcadEntity
  342.     For Each i In oSel
  343.         i.Rotate BasePoint, RotationAngle
  344.     Next i
  345. End Sub
  346. Public Sub Rotate3D(Optional ByVal Point1, Optional ByVal Point2, Optional ByVal RotationAngle As Double = 1#)
  347. On Error Resume Next
  348.     If IsNull() Then Exit Sub
  349.     If IsMissing(Point1) Then Point1 = CreatePoint()
  350.     If IsMissing(Point2) Then Point2 = CreatePoint()
  351.
  352.     Dim i As AcadEntity
  353.     For Each i In oSel
  354.         i.Rotate3D Point1, Point2, RotationAngle
  355.     Next i
  356. End Sub
  357. Public Sub ScaleAll(Optional ByVal BasePoint, Optional ByVal scalefactor As Double = 1)
  358. On Error Resume Next
  359.     If IsNull() Then Exit Sub
  360.     If IsMissing(BasePoint) Then BasePoint = CreatePoint()
  361.
  362.     Dim i As AcadEntity
  363.     For Each i In oSel
  364.         i.ScaleEntity BasePoint, scalefactor
  365.     Next i
  366. End Sub
  367. Public Sub Mirror(Optional ByVal Point1, Optional ByVal Point2)
  368. On Error Resume Next
  369.     If IsNull() Then Exit Sub
  370.     If IsMissing(Point1) Then Point1 = CreatePoint()
  371.     If IsMissing(Point2) Then Point2 = CreatePoint()
  372.
  373.     Dim i As AcadEntity
  374.     For Each i In oSel
  375.         i.Mirror Point1, Point2
  376.     Next i
  377. End Sub
  378. Public Sub Mirror3D(Optional ByVal Point1, Optional ByVal Point2, Optional ByVal Point3)
  379. On Error Resume Next
  380.     If IsNull() Then Exit Sub
  381.     If IsMissing(Point1) Then Point1 = CreatePoint()
  382.     If IsMissing(Point2) Then Point2 = CreatePoint()
  383.     If IsMissing(Point3) Then Point3 = CreatePoint()
  384.
  385.     Dim i As AcadEntity
  386.     For Each i In oSel
  387.         i.Mirror3D Point1, Point2, Point3
  388.     Next i
  389. End Sub
  390. Public Sub Highlight(Optional ByVal HighlightFlag As Boolean = True)
  391. On Error Resume Next
  392.
  393.     Dim i As AcadEntity
  394.     For Each i In oSel
  395.         i.Highlight HighlightFlag
  396.     Next i
  397. End Sub
  398. Public Sub Delete()
  399. On Error Resume Next
  400.
  401.     oSel.Erase
  402. End Sub
  403. Public Sub CopyObjects(Optional ByVal Owner, Optional ByVal IdPairs)
  404. On Error Resume Next
  405.     If IsNull() Then Exit Sub
  406.     If IsMissing(Owner) Then
  407.         If IsMissing(IdPairs) Then
  408.             ThisDrawing.CopyObjects ToArray
  409.         Else
  410.             ThisDrawing.CopyObjects ToArray, , IdPairs
  411.         End If
  412.     Else
  413.         If IsMissing(IdPairs) Then
  414.             ThisDrawing.CopyObjects ToArray, Owner
  415.         Else
  416.             ThisDrawing.CopyObjects ToArray, Owner, IdPairs
  417.         End If
  418.     End If
  419. End Sub
  420. Public Sub GetBoundingBox(ByRef MinPoint, ByRef MaxPoint)
  421. On Error Resume Next
  422.     Dim i
  423.     Dim d1, d2, p1, p2
  424.
  425.     If IsNull() Then Exit Sub
  426.
  427.     oSel(0).GetBoundingBox d1, d2
  428.
  429.     For i = 1 To Count - 1
  430.
  431.         oSel(i).GetBoundingBox p1, p2
  432.
  433.         If p1(0) < d1(0) Then d1(0) = p1(0)
  434.         If p1(1) < d1(1) Then d1(1) = p1(1)
  435.         If p2(0) > d2(0) Then d2(0) = p2(0)
  436.         If p2(1) > d2(1) Then d2(1) = p2(1)
  437.
  438.     Next i
  439.
  440.     MinPoint = d1
  441.     MaxPoint = d2
  442.
  443. End Sub
  444. Public Function ToBlock(Optional ByVal InsertionPoint, Optional ByVal Name As String = "*U") As String
  445. On Error GoTo ErrHandle
  446.     If IsNull() Then Exit Function
  447.     If IsMissing(InsertionPoint) Then InsertionPoint = CreatePoint()
  448.
  449.     Dim oBlock As AcadBlock
  450.     Set oBlock = ThisDrawing.Blocks.Add(InsertionPoint, Name)
  451.     CopyObjects oBlock
  452.
  453.     ToBlock = oBlock.Name
  454.
  455. ErrHandle:
  456. End Function
  457. Function CreateArray(ByVal TypeName As VbVarType, ParamArray ValArray())
  458.     Dim nCount As Integer
  459.     Dim i
  460.     Dim mArray
  461.
  462.     nCount = UBound(ValArray)
  463.
  464.     Select Case TypeName
  465.     Case vbDouble
  466.         Dim dArray() As Double
  467.         ReDim dArray(nCount)
  468.         mArray = dArray
  469.     Case vbInteger
  470.         Dim nArray() As Integer
  471.         ReDim nArray(nCount)
  472.         mArray = nArray
  473.     Case vbString
  474.         Dim sArray() As String
  475.         ReDim sArray(nCount)
  476.         mArray = sArray
  477.     Case vbVariant
  478.         Dim vArray()
  479.         ReDim vArray(nCount)
  480.         mArray = vArray
  481.     End Select
  482.
  483.     For i = 0 To nCount
  484.         mArray(i) = ValArray(i)
  485.     Next i
  486.
  487.     CreateArray = mArray
  488. End Function
  489. Public Function CreatePoint(Optional ByVal X As Double = 0#, Optional ByVal Y As Double = 0#, Optional ByVal Z As Double = 0#)
  490.
  491.     Dim pnt(2) As Double
  492.     pnt(0) = X: pnt(1) = Y: pnt(2) = Z
  493.
  494.     CreatePoint = pnt
  495.
  496. End Function
 楼主| 发表于 2004-11-18 22:43:00 | 显示全部楼层
下面是一段测试
  1. Sub test()
  2.     Dim ss As New TlsSel
  3.     ss.Init
  4.     ss.SetFilter 0, "Insert", 2, "1"
  5.     ss.Selectobject acSelectionSetAll
  6.     MsgBox ss.Count
  7. End Sub
发表于 2004-11-19 08:59:05 | 显示全部楼层
很好的一个类!请问引用块的过滤数据类型和数据是什么?谢谢
'设置过滤器
    Dim i
    Dim n As Integer
    For i = 0 To nCount
        n = i * 2
        ft(i) = Filter(n)
    Next i
    TlsFt = ft
    TlsFd = fd
End Sub
这个函数不太明白,为什么nCount = (UBound(Filter) + 1) / 2 - 1??
 楼主| 发表于 2004-11-19 09:36:27 | 显示全部楼层
(UBound(Filter) + 1)是Filter数组的元素个数
设置过滤器前先在命令行键入"(entget(car(entsel)))",看看对应实体的DXF组码
发表于 2004-11-20 00:56:56 | 显示全部楼层
好程序!!怎么没有加分?
发表于 2005-3-18 20:02:50 | 显示全部楼层
类是不是就是一种数据类型,自定义的?
发表于 2005-6-7 18:41:30 | 显示全部楼层
doc1.CopyObjects ToArray(acadselect)
Public Function ToArray(ByVal osel As AcadSelectionSet)
'转化选择集为对象数组输出
    Dim i
    nCount = osel.Count - 1
    ReDim objs(nCount)
    For i = 0 To nCount
        Set objs(i) = osel(i)
    Next i
    ToArray = objs
End Function
toarry拿出来放到其它的程序中调用时,执行到toarry=objs时就出错,提示“对象不在数据库中”是怎么回事?
发表于 2009-3-7 11:10:15 | 显示全部楼层
ddddddddddddd
发表于 2009-7-24 16:50:21 | 显示全部楼层
好顶一个
GMT+8, 2024-5-14 22:59 , Processed in 0.239943 second(s), 47 queries , Gzip On.
© 2001-2024 Discuz! Team.
