查看: 1595|回复: 4
[必看]:bentley 的产品及lic名称及位置
发表于 2005-4-25 23:14:01 | 显示全部楼层 |阅读模式
Product Nodelocked License Name Default License Directory SELECTserver License Name
Foundation Products
Bentley MicroStation msv8.lic ...\program files\bentley\program\licensing\  msv8.lic
Bentley View N/A ...\bentley\program\licensing\ bentleyview.lic
Bentley Redline bentleyrdl.lic ...\program files\bentley\program\licensing\ bentleyrdl.lic
Bentley PowerDraft draftv8.lic ...\program files\bentley\program\licensing\ draftv8.lic
Discipline-specific Applications
MicroStation GeoGraphics V8 msv8.lic ...\program files\bentley\program\licensing\ msv8.lic
MicroStation TriForma msv8.lic ...\Bentley\program\licensing msv8.lic
GeoSpatial Products
Bentley PowerMap powermap.lic ...\program files\bentley\program\licensing\ powermap.lic
Bentley Water bw.lic ...\program files\bentley\program\licensing\ bw.lic
Bentley Wastewater bww.lic ...\program files\bentley\program\licensing\ bww.lic
Bentley Descartes dcartes.lic ...\program files\bentley\program\licensing\ dcartes.lic
Bentley I/RAS B irasb.lic ...\program files\bentley\program\licensing\ irasb.lic
Content Management & Publishing
Bentley Publisher Not Supported ...\Program Files\Common Files\Bentley Shared\LicenseBroker licbroker.lic
Bentley Facilities Planner 2004 Edition Not Supported ..\Program Files\Bentley\Bentley Facilities\bin\ bfp.lic (On the computer where Bentley Facilities Planner is installed)
Bentley Facilities Inquirer 2004 Edition Not Supported ..\Program Files\Bentley\ProjectWise\WebServer\webapps\BFI\WEB-INF\conf\ bfi.lic (On the server where Bentley Facilities Inquirer is installed)
Projectwise Reports 2004 Edition Not Supported ..\Program Files\Bentley\ProjectWise\Bin pwr.lic
ProjectWise Not Supported ...\Program Files\Common Files\Bentley Shared\LicenseBroker licbroker.lic
ProjectWise Export/Import Not Supported ...\Program Files\Bentley\ProjectWise\Bin pwimpexp.lic
ProjectWise Transmittal Not Supported ...\Program Files\Bentley\ProjectWise\Bin pwtrans.lic
Plotting Products
InterPlot Client ipcli.lic ...\Program Files\Common Files\InterPlot\Licensing\ ipcli.lic
InterPlot Driver Pack ipdrvpck.lic ...\Program Files\Common Files\InterPlot\Licensing\ Not Supported
InterPlot High-Volume Driver Pack iphvpck.lic ...\Program Files\Common Files\InterPlot\Licensing\ Not Supported
InterPlot Mid-Volume Driver Pack ipmvdpk.lic ...\Program Files\Common Files\InterPlot\Licensing\ Not Supported
InterPlot Océ 9800 Driver ipo9800drv.lic ...\Program Files\Common Files\InterPlot\Licensing\ Not Supported
InterPlot Offline Driver Pack ipoffdrv.lic ...\Program Files\Common Files\InterPlot\Licensing\ Not Supported
InterPlot Professional ippro.lic ...\Program Files\Common Files\InterPlot\Licensing\ Not Supported
InterPlot Raster Offline Driver Pack ipoffdrv.lic ...\Program Files\Common Files\InterPlot\Licensing\ Not Supported
InterPlot Server ipsrv.lic ...\Program Files\Common Files\InterPlot\Licensing\ Not Supported
InterPlot Digital Print Room Workgroup ipdprwg.lic ...\Program Files\Common Files\InterPlot\Licensing\ Not Supported
InterPlot Digital Print Room (12 limit ipdpr12.lic ...\Program Files\Common Files\InterPlot\Licensing\ Not Supported
InterPlot Digital Print Room (unlimited) ipdprunl.lic ...\Program Files\Common Files\InterPlot\Licensing\ Not Supported
Digital InterPlot v8.1 Not Supported ...\Program Files\Common Files\Bentley Shared\LicenseBroker licBroker.lic
Building/ Plant /Design Engineering
Bentley Architecture architecture.lic ...\Bentley\program\licensing msv8.lic
Bentley Structural structural.lic ...\Bentley\program\licensing msv8.lic
Bentley HVAC hvac.lic ...\Bentley\program\licensing msv8.lic
EED eed.lic ...\Bentley\program\licensing eed.lic
Bentley Navigator navigator.lic ...\Bentley\program\licensing navigator.lic
Bentley Plant Portfolio - Physical Design (3D) for MicroStation v8.1 MSV8.LIC ...\Program Files\Bentley\Program\Licensing\ MSV8.LIC
Bentley Plant Portfolio - Physical Design (3D) for MicroStation v8.1 w/MicroStation MSV8.LIC ...\Program Files\Bentley\Program\Licensing\ MSV8.LIC
Bentley PlantSpace Equipment Modeler V8.1 TFEQMOD.LIC ...\Program Files\Bentley\Program\Licensing\ TFEQMOD.LIC
Bentley PlantSpace HVAC V8.1 hvac.lic ...\Program Files\Bentley\Program\Licensing\ hvac.lic
Bentley PlantSpace IsoExtractor V8.1 IsoExtPS.lic ...\Program Files\Bentley\Program\Licensing\ IsoExtPS.lic
Bentley PlantSpace Isometrics V8.1 LISO.LIC ...\Program Files\Bentley\Program\Licensing\ LISO.LIC
Bentley PlantSpace Orthographics PSOrthographics.lic ...\Bentley\Program\Licensing\ PSOrthographics.lic
Bentley PlantSpace P&ID V8.1 pspid.lic ...\Program Files\Bentley\Program\Licensing\ pspid.lic
Bentley PlantSpace Piping V8.1 PSPIPING.LIC ...\Program Files\Bentley\Program\Licensing\ PSPIPING.LIC
Bentley PlantSpace Raceways V8.1 tfrace.lic ...\Program Files\Bentley\Program\Licensing\ tfrace.lic
Bentley PlantSpace SupportModeler V8.1 pssupmod.lic ...\Program Files\Bentley\Program\Licensing\ pssupmod.lic
Bentley Structural V8.1 msv8.lic ...\Program Files\Bentley\Program\Licensing\
Note that if the structural is part of a the BIM Competitive Upgrade, the license is contained in the "msv8.lic", and Structural does not require a separate license file.
structural.lic
Interference Manager ifmeng.lic ...\Bentley\program\licensing ifmeng.lic
Civil Products
Bentley InRail 8.4 bentleycivil.lic ...\bentley\civil\licensing\ bentleycivil.lic
Bentley InRoads 8.4 bentleycivil.lic ...\bentley\civil\licensing\ bentleycivil.lic
Bentley InRoads Bridge 8.4 bentleycivil.lic ...\bentley\civil\licensing\ bentleycivil.lic
Bentley InRoads Site 8.4 bentleycivil.lic ...\bentley\civil\licensing\ bentleycivil.lic
Bentley InRoads Storm & Sanitary 8.4 bentleycivil.lic ...\bentley\civil\licensing\ bentleycivil.lic
Bentley InRoads Survey 8.4 bentleycivil.lic ...\bentley\civil\licensing\ bentleycivil.lic
Bentley PowerSurvey v8.1 Powersurvey.lic ...\Program Files\Bentley\Program\Licensing\ Powersurvey.lic
GEOPAK Bridge geopak.lic ...\Bentley\Program\Licensing\ geopak.lic
GEOPAK Civil Suite geopak.lic ...\Bentley\Program\Licensing\ geopak.lic
GEOPAK Rebar geopak.lic ...\Bentley\Program\Licensing\ geopak.lic
GEOPAK Site geopak.lic ...\Bentley\Program\Licensing\ geopak.lic
GEOPAK Survey geopak.lic ...\Bentley\Program\Licensing\ geopak.lic
InRail v8.3 bentleycivil.lic ...\bentley\civil\licensing\ bentleycivil.lic
InRoads Bridge v8.3 bentleycivil.lic ...\bentley\civil\licensing\ bentleycivil.lic
InRoads Site v8.3 bentleycivil.lic ...\bentley\civil\licensing\ bentleycivil.lic
InRoads Storm & San v8.3 bentleycivil.lic ...\bentley\civil\licensing\ bentleycivil.lic
InRoads Survey v8.3 bentleycivil.lic ...\bentley\civil\licensing\ bentleycivil.lic
InRoads v8.3 bentleycivil.lic ...\bentley\civil\licensing\ bentleycivil.lic
InRoads Suite 8.4 bentleycivil.lic* ...\program files\bentley\civil\licensing bentleycivil.lic*
Imaging and Conversion Products
CloudWorx (AutoCAD) CLWXAP2.lic ...\Program Files\Cyra Technologies\Cyclone\Bentley CloudWorx\ACAD 2000\ CLWXAP2.lic
CloudWorx (MicroStation) CLWX2.lic ...\Program Files\Bentley\Program\License CLWX2.lic
MicroStation Descartes v8.0, v8.1 Dcartes.lic ...\Program Files\Bentley\Program\Licensing\ Dcartes.lic
MicroStation I/RAS B v8, v8.1 irasb.lic ...\Program Files\Bentley\Program\Licensing\ irasb.lic
Integration and Simulation Products
Bentley Navigator 8.1 navigator.lic ...\Program Files\Bentley\Program\Licensing\ navigator.lic
发表于 2005-4-26 09:57:20 | 显示全部楼层
有点意思,我的理想是能够得到它们,至少要能够得到Building/ Plant /Design Engineering 就好啦。
发表于 2006-2-28 14:00:54 | 显示全部楼层
那里有这么多的LIC呢????请问楼主在那里下载呢????谢谢
发表于 2006-2-28 14:40:08 | 显示全部楼层
要是有ProjectWise的下就好了!
发表于 2006-7-29 08:59:42 | 显示全部楼层
谢谢,这样就知道需要何种license了
GMT+8, 2024-5-29 22:58 , Processed in 0.386971 second(s), 39 queries , Gzip On.
© 2001-2024 Discuz! Team.
