查看: 1560|回复: 2
[VBA程序]:文字为何不能设置居中?
发表于 2005-5-16 12:10:57 | 显示全部楼层 |阅读模式
为什么文字不能设置居中?
Sub labelpnt()
   Dim Ent As AcadBlockReference
   Dim Height As Double
   Dim pickedp1 As Variant
   Dim pickedp2 As Variant
   Dim OffsetValue As Double
   Dim MidPos(0 To 2) As Double
   Dim FromPnt, Topnt As Variant
   Dim ppt As Variant
   Dim NoObj As AcadText
   Dim ElevObj As AcadText
     Dim line1 As AcadLine
    Dim line2 As AcadLine
     Dim Group1 As AcadGroup
     Dim objgroup(0 To 3) As AcadEntity
     Dim sPnt As Variant
     Dim ePnt As Variant
Const pi = 3.1415926
   On Error Resume Next
RETRY:
     Call ThisDrawing.Utility.GetEntity(Ent, pnt, vbCrLf & "选符号...")
     If Err Then
        Err.Clear
        End
     End If
         LblLen = 5
     Height = 1
     OffsetValue = 0.5
     FromPnt = Ent.InsertionPoint
     Topnt = ThisDrawing.Utility.GetPoint(FromPnt, "指定标注位置...")
     If Err <> 0 Then
        Err.Clear
        Exit Sub
     End If
       Set line1 = ThisDrawing.ModelSpace.AddLine(FromPnt, Topnt)
     If pd(FromPnt, Topnt) = True Then
        ppt = ThisDrawing.Utility.PolarPoint(Topnt, pi, LblLen)
     Else
        ppt = ThisDrawing.Utility.PolarPoint(Topnt, 0, LblLen)
     End If
       Set line2 = ThisDrawing.ModelSpace.AddLine(Topnt, ppt)
     sPnt = line2.StartPoint
     ePnt = line2.EndPoint
     '''&Iuml;中点坐标
     MidPos(0) = (sPnt(0) + ePnt(0)) / 2
     MidPos(1) = (sPnt(1) + ePnt(1)) / 2
     MidPos(2) = 0
     '''文字注记位置
     pickedp1 = ThisDrawing.Utility.PolarPoint(MidPos, pi / 2, OffsetValue)
     pickedp2 = ThisDrawing.Utility.PolarPoint(MidPos, 0 - pi / 2, Height + OffsetValue)
     '''标注文字
     Set NoObj = ThisDrawing.ModelSpace.AddText("JS121", pickedp1, Height)
'''以下这句总不对
     NoObj.Alignment = acAlignmentCenter
     '''文字
     Set ElevObj = ThisDrawing.ModelSpace.AddText("2.12", pickedp2, Height)
     '''&para;&Ocirc;&Iuml;ó±à×é
     Set objgroup(0) = line1
     Set objgroup(1) = line2
     Set objgroup(2) = NoObj
     Set objgroup(3) = ElevObj
     Set Group1 = ThisDrawing.Groups.Add("*")
     Group1.AppendItems objgroup
GoTo RETRY
End Sub
Function pd(p1 As Variant, p2 As Variant) As Boolean
    If p1(0) > p2(0) Then
       pd = True
    Else
       pd = False
    End If
End Function
以上语句不知为何不能设置居中,加入居中语句后文字会跑到老远的地方,这是为什么?请指教red[/COLOR]
发表于 2005-5-16 17:19:52 | 显示全部楼层
当中这样修改:
'''标注文字
'''以下这句总不对
NoObj.TextAlignmentPoint = pickedp1
'''文字
ElevObj.Alignment = acAlignmentCenter
ElevObj.TextAlignmentPoint = pickedp2
 楼主| 发表于 2005-5-16 19:20:09 | 显示全部楼层
ljpnb ,谢谢。我调试出来了。你是宁波的吧?我也是。
GMT+8, 2024-6-10 07:27 , Processed in 0.539972 second(s), 35 queries , Gzip On.
© 2001-2024 Discuz! Team.
