- UID
- 1
- 积分
- 15879
- 精华
- 贡献
- 威望
- 活跃度
- D豆
- 在线时间
- 小时
- 注册时间
- 2002-1-3
- 最后登录
- 1970-1-1
ActiveX/VBA Technical Newsletter - December 1999
This document is part of AutoCAD VB(A) Newsletter Archive
/Note: the URLs in this posting may be broken into several lines by the
transmission media. Please make sure that you have the full URL before
trying to access it./
/Note: Have you missed a Newsletter issue? Visit our Newsletter archive at
the following URL:/
http://adn.autodesk.com/techsupp/docs/newsletters.htm
Dear AutoCAD ActiveX/VBA Developer,
Table of Contents
(1) Zero Doc State and ActiveX
(2) New or Updated Solutions
Question
I'm writing an ActiveX out-of-proc client app. I know that IAcadDocuments
exposes Add() and Open() methods. But when Acad is in the zero doc state, I
can get to the IAcadDocuments interface thus I can't programmatically call Add()
or Open().
How do I workaround this problem?
Answer
What you mentioned is true. When Acad is in the zero doc state, you can only
have access to IAcadApplication interface but not other objects down the
hierarchy.
As you have probably noticed that when Acad is in the zero doc state, there
is a file menu with which you can still open or create a new dwg.
What we can do here is to simulate that programmatically as if the user has
clicked the file new or file open menu items (ID_FILE_NEW and ID_FILE_OPEN
respectively).
HWND HWND_ACAD; // acad main frame window's handle
// create a new dwg
if(FindAcadFrameWnd() == TRUE)
::SendMessage(HWND_ACAD, WM_COMMAND, LOWORD(ID_FILE_NEW), NULL);
// open an exist dwg
::SendMessage(HWND_ACAD, WM_COMMAND, LOWORD(ID_FILE_OPEN), NULL);
// the following code snippets are all
// for finding the Acad's window on the desktop
CString GetWindowTitle(HWND &hwnd)
char s[256];
if (!::GetWindowText(hwnd, s, sizeof(s)))
return ""; // ignore empty titles
else
return s;
void SendCmdToAcad(CString& cmd)
COPYDATASTRUCT cmdMsg;
cmdMsg.dwData = (DWORD)1;
cmdMsg.cbData = (DWORD)_tcslen(cmd) + 1;
cmdMsg.lpData = cmd.GetBuffer(cmd.GetLength()+1) ;
SendMessage(HWND_ACAD, WM_COPYDATA, NULL, (LPARAM)&cmdMsg);
BOOL CALLBACK EnumWindowsProc(HWND hwnd, LPARAM lParam)
CString title = GetWindowTitle(hwnd);
if(title == "")
return TRUE;
if(title.Find("AutoCAD") != -1)
HWND_ACAD = hwnd;
return FALSE;
else
return TRUE;
BOOL FindAcadFrameWnd()
if(EnumWindows((WNDENUMPROC) EnumWindowsProc, NULL) == FALSE)
return TRUE;
else
return FALSE;
Question
When Acad is in the zero doc state, In my ARX app, I tried to use
ads_queueexpr("(command \"_QUIT\")"); to quit acad, it did not work.
SendMessage() with the same string can't do it either.
Also, when I want to the same thing from an ActiveX client app,
SendMessage()
with the quit string above didn't work.
How do I close the Acad window (quit, exit Acad) when it is at a zero doc
state?
Answer
When Acad is in the zero doc state, it will not accept any command line
commands
because the command line window doesn't exist. Thus any request for closing
the
Acad window, has to be sent to the Acad main frame window.
In you ARX app, the following line of code will close Acad. It may ask you
to
save your VBA macro if you have the VBA IDE window open.
::SendMessage(adsw_acadMainWnd(), WM_CLOSE, NULL, NULL);
In an ActiveX client app, even that IAcadApplication has a method Quit(), it
doesn't work when there is no document. So you'll need to use SendMessage().
The
only difference here is that you don't have the Acad main frame handle.
You'll
need to use some Win32 functions to achieve that, as shown below.
// a global variable for your client project
HWND HWND_ACAD;
char s[256];
else
return s;
if(title == "")
return TRUE;
HWND_ACAD = hwnd;
return FALSE;
else
// to keep the loop going
return TRUE;
return TRUE;
else
return FALSE;
DETERMINE PRODUCT FROM DESIGN 2000 FAMILY
/cgi-bin/solution.pl?SID=46582
HOW CAN I CALL VBA FUNCTIONS THAT HAVE ARGUMENTS
/cgi-bin/solution.pl?SID=46019
REPLACE OPEN/INSERT/SAVE SCRIPT WITH ACTIVEX CODE
/cgi-bin/solution.pl?SID=45466
ADD ENTITIES INTO LAYOUT2
/cgi-bin/solution.pl?SID=45318
HOW TO AVOID THE SAVE DRAWING DIALOG BOX AFTER A SAVEAS WHEN QUITING
/cgi-bin/solution.pl?SID=45308
SET THE PAPER SIZE OF A LAYOUT
/cgi-bin/solution.pl?SID=45278
MAKING A VB FORM AS IF IT IS A CHILD WINDOW OF ACAD
/cgi-bin/solution.pl?SID=45175
To subscribe or unsubscribe, go to
You received this message as a result of your registration
on the ADN List Server subscription page. If you no longer wish
to receive these messages, read the next section, How to use this
mailing list.
How to use this mailing list:
You may unsubscribe from this e-mail newsletter, or subscribe to
a variety of other informative e-mail newsletters, by returning
to the ADN List Server subscription page at
and changing your subscription preferences.
Alternatively, from the subscribed account you can send an e-mail to
<Majordomo-partnersys@autodesk.com> with the following command in the
body of your email message:
unsubscribe <list-name>
Autodesk Developer Network (ADN) information and events:
For information on all ADN topics, please visit:
http://www.autodesk.com/adn
THIS DOCUMENT IS PROVIDED FOR INFORMATIONAL PURPOSES ONLY. The
information contained in this document represents the current view of
Autodesk Inc. on the issues discussed as of the date of publication.
Because Autodesk must respond to change in market conditions, it
should not be interpreted to be a commitment on the part of Autodesk
and Autodesk cannot guarantee the accuracy of any information
presented after the date of publication.
INFORMATION PROVIDED IN THIS DOCUMENT IS PROVIDED 'AS IS' WITHOUT
WARRANTY OF ANY KIND, EITHER EXPRESS OR IMPLIED, INCLUDING BUT NOT
LIMITED TO THE IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A
PARTICULAR PURPOSE AND FREEDOM FROM INFRINGEMENT.
The user assumes the entire risk as to the accuracy and the use of
this document. This document may be copied and distributed subject to
the following conditions:
1. All text must be copied without modification and all pages must
be included
2. All copies must contain Autodesk's copyright notice and any other
notices provided therein
3. This document may not be distributed for profit
