查看: 7745|回复: 74
[LISP程序]:自己编的一些小程序
发表于 2008-6-8 10:59:40 | 显示全部楼层 |阅读模式
自己编的一些小程序,或许对大家有点帮助
发表于 2008-6-15 16:29:55 | 显示全部楼层
不错,值得学习借鉴。。。
(Defun c:add  ()
     (setq gp (ssget))
     (command "_layer" "s"  gp ""))
(DEFUN C:dss() (COMMAND "osnap" "END,CEN,QUI,MID,QUA,PER,APP,INS,NOD,INT")
(princ))
(DEFUN C:dss1() (COMMAND "osmode" "175")(princ))
(defun c:oo()(Setvar"osmode"7095)(princ))
(Defun c:chh  ()  (setq gp (ssget)) (command "change" gp "" "p" "la" "lvtry"  ""))
(Defun c:ghh  ()  (setq gp (ssget)) (command "change" gp "" "p" "la" "0"  ""))
(Defun c:00  ()  (command "-layer" "s" "0" ""))
(Defun c:11  ()  (command "-layer" "off" "tk,tkk,t1" ""))
(Defun c:111  ()  (command "-layer" "off" "tk" ""))
;(Defun c:es  ()  (command "erase" "p" ""))
(Defun c:ss2  ()  (command "offset" "200" pause))
(Defun c:ze  ()  (command "zoom" "e"))
(Defun c:qd  ()  (command "pline"))
(Defun c:ss1  ()  (command "offset" "100"))
(Defun c:ss4  ()  (command "offset" "400"))
(Defun c:ss2  ()  (command "offset" "200"))
(Defun c:ar  ()  (command "array"))
;(Defun c:q  ()  (command "'pan"))
(Defun c:CDC  ()  (command "win_bat_modw"))
(Defun c:RR  ()  (command "MIRROR"))
(Defun c:v  ()  (command "Move"))
(Defun c:EX ()  (command "EXTEND"))
(Defun c:ds  ()  (command "dist"))
(Defun c:H  ()  (command "dimlinear"))
(Defun c:vq  ()  (command "move" "p" "" pause pause "" ))
(Defun c:ey  ()  (command "erase" "l"))
(Defun c:mi  ()  (setq gp (ssget)) (command "mirror" gp "" pause pause "y"))
(Defun c:dq  ()  (setq gp (ssget)) (command "change" gp  "" "Properties" "lt" "dashdot" ""))
(Defun c:dA  ()  (setq gp (ssget)) (command "change" gp  "" "Properties" "lt" "dasH" ""))
(Defun c:dda  ()  (setq gp (ssget)) (command "change" gp  "" "Properties" "lt" "dasH"
                  "Properties" "s" ".65" ""))
(Defun c:ddaa  ()  (setq gp (ssget)) (command "change" gp  "" "Properties" "lt" "dasH"
                  "Properties" "s" ".4" ""))
(Defun c:ddq  ()  (setq gp (ssget)) (command "change" gp  "" "Properties" "lt" "dasHdot"
                  "Properties" "s" ".5" ""))
(Defun c:vd  ()  (setq gp (ssget)) (command "change" gp  "" "Properties" "s" ".15" ""))
(Defun c:gd1  ()  (command "change" {"p"  "" "Properties" "s" ".3" ""))
(Defun c:gd ()  (setq gp (ssget)) (command "change" gp  "" "Properties" "s" ".3" ""))
(Defun c:yd  ()  (setq gp (ssget)) (command "change" gp  "" "Properties" "s" ".5" ""))
(Defun c:vc  ()  (setq gp (ssget)) (command "change" gp  "" "Properties" "s" "3" ""))
(Defun c:rs  ()
     (setq gp (ssget))
     (setq g (ssget))
     (command "MATCHPROP" gp  g ""))
(Defun c:EB  ()
     (command "ERASE" "L"  ""))
(Defun c:za  ()  (command "zoom" "a" ""))
(Defun c:us  ()  (command "ucsicon" "n"))
(Defun c:rga  ()  (command "regenauto" "of" ""))
;(Defun c:zw  ()  (command "zoom" "w"))
(Defun c:zd  ()  (command "zoom"  "d"))
(Defun c:z1  ()  (command "'zoom"  ".1x"))
(Defun c:zQ  ()  (command "'zoom"  ".001x"))
(Defun c:z2  ()  (command "'zoom"  ".2x"))
(Defun c:vw  ()  (command "move"  "w"))
(Defun c:3   ()  (command "zoom" ".3xp"))
(Defun c:y1   ()  (command "zoom" ".01xp"))
(Defun c:x   ()  (command "zoom" ".08xp"))
(Defun c:w   ()  (command "zoom" ".25xp"))
(Defun c:ss5  ()  (command "offset" "50"))
(Defun c:1   ()  (command "zoom" ".1xp"))
(Defun c:VG  ()  (command "UCS" "S" "ORG"))
(Defun c:VR  ()  (command "UCS" "R" "ORG"))
(Defun c:dn1  (/ a)
  (setq a (getstring "\nEnter dim of dimstyle to restore:"))
    (command "dimstyle" "restore" dimn150))
(Defun c:dd1  (/ a)
  (setq s1(ssget ))
      (command "dimstyle" "restore" "dimn150"  "DIM" "UP" S1 "" "DIM"
"EXIT" ""))
(Defun c:1d  (/ a)
;  (setq a (getstring "\nEnter dim of dimstyle to restore:"))
(Defun c:2d  (/ a)
    (command "dimstyle" "restore" "dimn200"))
(Defun c:d2  ()
      (setq s1(ssget ))
      (command "dimstyle" "restore" "dimn200" "DIM" "UP" S1 "" "DIM" "EXIT" ""))
(Defun c:d15  ()
      (setq s1(ssget ))
      (command "dimstyle" "restore" "dimn150" "DIM" "UP" S1 "" "DIM" "EXIT" ""))
(Defun c:d5  ()
      (setq s1(ssget ))
      (command "dimstyle" "restore" "dimn50" "DIM" "UP" S1 "" "DIM" "EXIT" ""))
(Defun c:d25  ()
      (setq s1(ssget ))
      (command "dimstyle" "restore" "dimn25" "DIM" "UP" S1 "" "DIM" "EXIT" ""))
(Defun c:d22  ()
      (setq s1(ssget ))
      (command "dimstyle" "restore" "dimn20" "DIM" "UP" S1 "" "DIM" "EXIT" ""))
(Defun c:dJ  ()
      (setq s1(ssget ))
(Defun c:JD  ()
      (setq s1(ssget ))
      (command "dimstyle" "restore" "dimn25A" "DIM" "UP" S1 "" "DIM" "EXIT" ""))
(Defun c:5da  ()
      (setq s1(ssget ))
      (command "dimstyle" "restore" "dimn50a" "DIM" "UP" S1 "" "DIM" "EXIT" ""))
(Defun c:d0  ()
      (setq s1(ssget ))
      (command "dimstyle" "restore" "dimn" "DIM" "UP" S1 "" "DIM" "EXIT" ""))
(Defun c:d20  ()
      (setq s1(ssget ))
      (command "dimstyle" "restore" "DIMN200" "DIM" "UP" S1 "" "DIM" "EXIT" ""))
(Defun c:d2a  ()
      (setq s1(ssget ))
      (command "dimstyle" "restore" "dimn250a" "DIM" "UP" S1 "" "DIM" "EXIT" ""))
(Defun c:5d  ()
      (setq s1(ssget ))
(Defun c:d20  ()
      (setq s1(ssget ))
(Defun c:d15 ()
      (setq s1(ssget ))
(Defun c:d11  ()
      (setq s1(ssget ))
      (command "change" s1 "" "Properties" "la" "pub_dim" "" "dimstyle" "restore" "dimn" "DIM" "UP" s1  "" "DIM" "EXIT" ""))
(Defun c:d1 ()
      (setq s1(ssget ))
(Defun c:1d  ()
      (setq s1(ssget ))
(Defun c:dmn  ()
      (setq s1(ssget ))
      (command "change" s1 "" "Properties" "la" "pub_dim" "" "dimstyle" "restore" "DIMN" "DIM" "UP" s1  "" "DIM" "EXIT" ""))
(Defun c:nd  ()
      (setq s1(ssget ))
      (command "change" s1 "" "Properties" "la" "axis" "" "dimstyle" "restore" "dimn" "DIM" "UP" s1  "" "DIM" "EXIT" ""))
(Defun c:d10  ()
      (setq s1(ssget ))
      (command "dimstyle" "restore" "dimn10" "DIM" "UP" S1 "" "DIM" "EXIT" ""))
;(Defun c:dY  ()
;      (setq s1(ssget ))
;      (command "change" S1 "" "Properties" "la" "pub_dim" "" "dimstyle" ;"restore" "dimn1" "DIM" "UP" S1 "" "DIM" "EXIT" ""))
(Defun c:d00  ()  (command "dimstyle" "restore" "dimn1000"))
(Defun c:d3  ()  (command "dimstyle" "restore" "dimn500"))
(Defun c:hd  ()  (setvar "snapang" 0))
(Defun c:vv  () (command "move" "p"))
(Defun c:cf  () (command "copy" "" "l" "@" "@"))
(Defun c:vx  () (command "move" "p" "nea" "per"))
(Defun c:ff  () (command "fillet" "r" "0" "fillet"))
(Defun c:f8  () (command "fillet" "r" "80" "fillet"))
(Defun c:ff3  () (command "fillet" "r" "3" "fillet"))
(Defun c:ff2  () (command "fillet" "r" "2" "fillet"))
(Defun c:ff9  () (command "fillet" "r" "9" "fillet"))
(Defun c:ff6  () (command "fillet" "r" "6" "fillet"))
(Defun c:6f () (command "fillet" "r" "6000" "fillet"))
(Defun c:9f  () (command "fillet" "r" "9000" "fillet"))
(Defun c:f12  () (command "fillet" "r" "12000" "fillet"))
(Defun c:f13  () (command "fillet" "r" "13000" "fillet"))
(Defun c:ff12  () (command "fillet" "r" "12" "fillet"))
(Defun c:ff13  () (command "fillet" "r" "13" "fillet"))
(Defun c:f2  () (command "fillet" "r" "20" "fillet"))
(Defun c:f1  () (command "fillet" "r" "150" "fillet"))
(Defun c:sv  () (command "setvar" "osmode" "1727"))
(Defun c:vs  () (command "setvar" "osmode" "0"))
(Defun c:qq  () (command "purge" "al" "" "n" "qsave"))
(Defun c:cs  () (command "scale" "p" "" "int" "0.5" ""))
(Defun c:va  (/ gp) (setq gp(ssget)) (command "move" gp "" "@"))
(Defun c:cq  (/ gp) (setq gp(ssget)) (command "copy" gp "" "0,0,0" "@" ""))
(Defun c:cv  (/ gp) (setq gp(ssget)) (command "change" gp "" "p" "la"))
(Defun c:a   ()  (command "zoom" "p"))
(Defun c:vf  ()  (command "ucsfollow" "1"))
(Defun c:t1  ()  (command "mirrtext" "1"))
(Defun c:qy  ()  (command "blipmode" "off"))
(Defun c:f3  ()  (command "fillet" "r" "3000")
               (command "fillet"))
(Defun c:f6  ()  (command "fillet" "r" "6000")
               (command "fillet"))
(Defun c:f9  ()  (command "fillet" "r" "9000")
               (command "fillet"))
(Defun c:r7  ()  (command "fillet" "r" "70")
               (command "fillet"))
(Defun c:r5  ()  (command "fillet" "r" "50")
               (command "fillet"))
(Defun c:f0  ()  (command "fillet" "r" "100")
               (command "fillet"))
(Defun c:f22  ()  (command "fillet" "r" "120")
               (command "fillet"))
(Defun c:rf  ()
        (setq a(getstring "\nEnter Current fillet radius:"))
        (setq s1(ssget ))
        (setq s2(ssget ))
        (command "fillet" "r" a)
        (command "fillet" s1 "" s2 "" ))
(Defun c:kb ()
    (setq layr(getstring "\nEnter target layer name:"))
    (setq a(ssget))
    (command "copy" a "" "0,0" "0,0")
    (command "change" a "" "p" "la" layr ""))
(Defun c:sz ()
    (setq s1(ssget )))
(Defun c:cn (/ ent)
    (setq ent(ssget ))
    (command "copy" ent "m"))
(Defun c:sb (/ n)
    (setq n(getstring "\nEnter name of VIEW and UCS to restore:"))
    (command "ucs" "r" n)
    (command "view" "r"  n))
(Defun c:bs (/ n)
    (command "ucs" "s" n)
    (command "view" "s"  n))
(Defun c:am  (/ os pt1)
   (setq os(getvar "cmdecho"))
   (setvar "cmdecho" 1)
   (setq pt1(getpoint "nPick a point between the lines:"))
   (command "dim" "angular" pause pause pt1 ^c ^c)
   (setvar "cmdecho" os)
   (textscr))
(Defun c:ga ()
    (setvar "orthomode" 1)
    (setq ang (getorient "\nAngle for ortho:\n"))
    (setvar "snapang" ang))
(Defun c:rw (/ a)
    (setq a (getstring "\nEnter angle of ucs to rotate:"))
    (command "ucs" "z" a))
(Defun c:dr  (/ a)
    (command "dimstyle" "restore" a)
    (command "dim" "UP" "all")
(Defun c:du  (/ a)
    (setq pt1 (getpoint "\nFirst corner:"))
    (setq pt2 (getcorner pt1 "nSecond corner:"))
    (command "dim" "UP" "c" pt1 pt2 "")
    (command "dim" "e"))
(Defun c:dh ()
    (setq e1(entget(car(entsel))))
    (setq pt1(cdr(assoc 10 e1)))
    (setq pt2(cdr(assoc 11 e1)))
    (setvar "snapang" (angle pt1 pt2))
(Defun c:dl ()
    (command "line"  pause pause "")
    (setq l(entget(car(entsel))))
    (setq pt1(cdr(assoc 10 l)))
    (setq pt2(cdr(assoc 11 l)))
    (command "erase" "l"  "")
(Defun c:dh1 (/ a b)
    (setq a (angle pt1 pt2))
    (setq pt3(cdr(assoc 10 e2)))
    (setq pt4(cdr(assoc 11 e2)))
    (setq b (angle pt3 pt4))
    (setvar "snapang" (- a b))
(Defun c:xd ()
(Defun c:cn (/ ent)
    (setq ent (ssget ))
(defun c:bb (/ bloc d a n)
    (setq bloc (getstring"\nEnter name of block you want counted:"))
    (setq d (cons 2 bloc))
    (setq a (ssget "x" (list d)))
    (if (/ = a nil)
       (progn
          (setq n (sslength a))
           (prompt "There are")(prin1 n)(prompt "in the database \n")))
   (if  ( = a nil)
     (prompt "There are none in the database \n")))
(Defun c:rz  (/ a b)
    (setq s1(ssget ))
    (setq pt1 (getpoint "\nEnter the basepoint:"))
    (setq a (getstring "\nEnter angle to rotate:"))
    (command"rotate"  s1 pt1 a))
(Defun c:cj  ()
    (setq e1 (entget (car (entsel))))
    (setq pt1 (cdr (assoc 10 e1)))
    (setq pt2 (cdr (assoc 11 e1)))
(Defun c:jc  ()
(Defun c:hh  ()
    (setq s1(ssget ))
    (command "dimtedit" s1 "C"))
(Defun c:hl  ()
    (setq s1(ssget ))
    (command "dimtedit" s1 "l"))
(Defun c:ha  ()
    (setq s2(getstring "\nEnter angle to edit:"))
    (setq s1(ssget ))
    (command "dimtedit" s1 "a" s2))
(Defun c:vb  ()
    (setq s1(ssget ))
    (command "ucsfollow" "1" "ucs" "ob" s1))
(Defun c:hr  ()
    (setq s1(ssget ))
    (command "dimtedit" s1 "r"))
(Defun c:s2  (/ a b)
    (setq s1(ssget ))
    (command "scale" s1 "" pt1 "0.2" ""))
(Defun c:2s  (/ a b)
    (setq s1(ssget ))
    (command "scale" s1 "" pt1 "2" ""))
(Defun c:s3  (/ a b)
    (setq s1(ssget ))
    (command "scale" s1 "" pt1 "0.3" ""))
(Defun c:s13  (/ a b)
    (setq s1(ssget ))
    (command "scale" s1 "" pt1 "1/3" ""))
(Defun c:3s  (/ a b)
    (setq s1(ssget ))
    (command "scale" s1 "" pt1 "3" ""))
(Defun c:s1  (/ a b)
    (setq s1(ssget ))
    (command "scale" s1 "" pt1 2 ""))
(Defun c:s4  (/ a b)
    (setq s1(ssget ))
    (command "scale" s1 "" pt1 "0.4" ""))
(Defun c:s14  (/ a b)
    (setq s1(ssget ))
    (command "scale" s1 "" pt1 "1/4" ""))
(Defun c:4s  (/ a b)
    (setq s1(ssget ))
    (command "scale" s1 "" pt1 "4" ""))
(Defun c:s32  (/ a b)
    (setq s1(ssget ))
    (command "scale" s1 "" pt1 "3/2" ""))
(Defun c:s54  (/ a b)
    (setq s1(ssget ))
    (command "scale" s1 "" pt1 "1.25" ""))
(Defun c:s45  (/ a b)
    (setq s1(ssget ))
    (command "scale" s1 "" pt1 "4/5" ""))
(Defun c:s23  (/ a b)
    (setq s1(ssget ))
    (command "scale" s1 "" pt1 "2/3" ""))
(Defun c:s34  (/ a b)
    (setq s1(ssget ))
    (command "scale" s1 "" pt1 "3/4" ""))
(Defun c:s43  (/ a b)
    (setq s1(ssget ))
    (command "scale" s1 "" pt1 "4/3" ""))
(Defun c:qr  (/ a b)
    (setq s1(ssget ))
    (command "scale" s1 "" pt1 "1.6" ""))
(Defun c:s44  (/ a b)
    (setq s1(ssget ))
(Defun c:s56  (/ a b)
    (setq s1(ssget ))
    (command "scale" s1 "" pt1 "5/6" ""))
(Defun c:s5  (/ a b)
    (setq s1(ssget ))
    (command "scale" s1 "" pt1 "0.5" ""))
(Defun c:5s  (/ a b)
    (setq s1(ssget ))
    (command "scale" s1 "" pt1 "5" ""))
(Defun c:s6  (/ a b)
    (setq s1(ssget ))
    (command "scale" s1 "" pt1 "0.6"  ""))
(Defun c:6s  (/ a b)
    (setq s1(ssget ))
    (command "scale" s1 "" pt1 "6"  ""))
(Defun c:s7  (/ a b)
    (setq s1(ssget ))
    (command "scale" s1 "" pt1 0.7 ""))
(Defun c:s8  (/ a b)
    (setq s1(ssget ))
    (command "scale" s1 "" pt1 0.8 ""))
(Defun c:ee  (/ a b)
    (setq s1(ssget ))
    (command "measure" s1 "b" "A" "y" "500" ""))
(Defun c:w1  (/ a b)
    (setq pt3 (getpoint "\nEnter New angle:"))
    (setq pt2 (getpoint "\nEnter seccond point:"))
    (setq pt (getpoint "\nEnter reference point:"))
    (setq pt1 (getpoint "\nEnter base point:"))
    (command "rotate" "p" "" pt1   "re" ""  pt pt2 pt3))
(Defun c:EW1  (/ a b)
    (command "rotate" "p" "" "535744,296187" "re" "535744,296187"   pt3 pt2))
(Defun c:EW  (/ a b)
    (setq p (ssget ))
(Defun c:WW  (/ a b)
    (command "rotate" "p" "" "535632,219811" "re" "535644,219811"   pt3 pt2))
(Defun c:WW1  (/ a b)
    (setq p (ssget ))
(Defun c:WW3  (/ a b)
    (command "point" pt1))
(Defun c:WW2  (/ a b)
    (setq p (ssget ))
    (command "rotate" "p" "" pt1 "re" pt1   pt3 pt2))
(Defun c:ba  ()
    (command "-layer" "s" "bh" "" "-bhatch" "p" "ANSI31" "700" "" ))
(Defun c:bba ()
    (command "-layer" "s" "bh" "" "-bhatch" "p" "ANSI31" "500" "" ))
(Defun c:bC  ()
    (command "-layer" "s" "bh" "" "-bhatch" "p" "AN31C" "650" "" ))
(Defun c:bCc  ()
    (command "-layer" "s" "bh" "" "-bhatch" "p" "AN31C" "450" "" ))
(Defun c:Cb  ()
    (command "-layer" "s" "bh" "" "-bhatch" "p" "AN31C" "300" "" ))
(Defun c:bF  ()
    (command "-layer" "s" "bh" "" "-bhatch" "p" "AR-SAND" "20" "" ))
(Defun c:bV  ()
    (command "-layer" "s" "bh" "" "-bhatch" "p" "AR-CONC" "20" "" ))
(Defun c:bd  ()
    (command "-layer" "s" "bh" "" "-bhatch" "p" "SOLID" ))
(Defun c:RY  ()
    (setq p (ssget ))
    (command "MIRROR" "p"  "" pause pause "y"))
(Defun c:Rq  ()
    (setq p (ssget ))
    (setq pt1 (getpoint "\nEnter basepoint:"))
    (command "rotate" "p"  ""  "" pt1   "-90" ""))
(Defun c:C1  ()
      (command "change" "LAST" "" "Properties" "la" "pub_dim" ""))
(Defun c:Cc1  ()
      (command (load"dmtool.lsp")))
(Defun c:ss3  ()
      (command "offset"  "300" pause pause ""))
(Defun c:ss2  ()
      (command "offset"  "200" pause pause ""))
(Defun c:dY  ()
    (setq a (getstring "Dimension text <0.0000>:"))
    (setq p (ssget ))
    (command "dim"  "n"  a  p  "" "dim" "exit" ""))
(Defun c:ta  ()
    (command "-layer" "of"  "tk" ""))
(Defun c:v4  (/ a b)
    (setq p (ssget ))
    (command "copy" "p" "" "0,0"   "@0,400" "" ))
(Defun c:4v  (/ a b)
    (setq p (ssget ))
    (command "copy" "p" "" "0,0"   "@0,-400" "" ))
(Defun c:c4  (/ a b)
    (setq p (ssget ))
    (command "copy" "p" "" "0,0"   "@400,0" "" ))
(Defun c:4c  (/ a b)
    (setq p (ssget ))
    (command "copy" "p" "" "0,0"   "@-400,0" "" ))
(Defun c:v8  (/ a b)
    (setq p (ssget ))
    (command "copy" "p" "" "0,0"   "@0,800" "" ))
(Defun c:8v  (/ a b)
    (setq p (ssget ))
    (command "copy" "p" "" "0,0"   "@0,-800" "" ))
(Defun c:c8  (/ a b)
    (setq p (ssget ))
    (command "copy" "p" "" "0,0"   "@800,0" "" ))
(Defun c:8c  (/ a b)
    (setq p (ssget ))
    (command "copy" "p" "" "0,0"   "@-800,0" "" ))
(Defun c:v2  (/ a b)
    (setq p (ssget ))
    (command "copy" "p" "" "0,0"   "@0,200" "" ))
(Defun c:2v  (/ a b)
    (setq p (ssget ))
    (command "copy" "p" "" "0,0"   "@0,-200" "" ))
(Defun c:c2  (/ a b)
    (setq p (ssget ))
    (command "copy" "p" "" "0,0"   "@200,0" "" ))
(Defun c:2c  (/ a b)
    (setq p (ssget ))
(command "copy" "p" "" "0,0"   "@-200,0" "" ))
(Defun c:gs  (/ a b)
    (setq s1(ssget ))
(Defun c:rb  ()
    (command "MATCHPROP"  PAUSE PAUSE l ""))
(load "brk.lsp" "")
(VMON)
(DEFUN C:AA  () (COMMAND "AREA"))
;;(DEFUN C:Ar   () (COMMAND "ARc"))
(DEFUN C:AL  () (COMMAND "ARRAY" "L" "" "R"))
(DEFUN C:bl   () (COMMAND "BLOCK"))
(DEFUN C:BB ()
(SETVAR "BLIPMODE" 1)
(setq sset1 (entsel))
(setq sset (car sset1))
(setq pt1 (getpoint "\n Select the point to break"))
(command "break" sset pt1   "@")
(SETVAR "BLIPMODE" 0)
(prin1)
(defun c:k   () (command "copy"))
(defun c:y   () (command "move"))
(defun c:chl () (command "ddchprop"))
(DEFUN C:yy  () (COMMAND "CIRCLE"))
(DEFUN C:km  (/ GP)(SETQ GP (SSGET)) (COMMAND "COPY" GP "" "M"))
(DEFUN C:DT  () (COMMAND "DTEXT"))
(DEFUN C:E   () (COMMAND "ERASE"))
(DEFUN C:Ep  () (COMMAND "EXPLODE"))
(DEFUN C:Et  () (COMMAND "EXTEND"))
(DEFUN C:F  () (COMMAND "FILLET"))
(DEFUN C:I   () (COMMAND "INSERT"))
(DEFUN C:L=  () (COMMAND "LAYER" "ON"))
(DEFUN C:L-  () (COMMAND "LAYER" "OFF"))
(DEFUN C:LF  () (COMMAND "LAYER" "F"))
(DEFUN C:LTt  () (COMMAND "LAYER" "T"))
(DEFUN C:LC  () (COMMAND "LAYER" "C"))
(DEFUN C:d   () (COMMAND "LINE"))
(DEFUN C:LTP () (COMMAND "LINETYPE"))
(DEFUN C:LI  () (COMMAND "LIST"))
(DEFUN C:LTS () (COMMAND "LTSCALE"))
(DEFUN C:MU  () (COMMAND "MEASURE"))
(DEFUN C:MI  () (COMMAND "MIRROR"))
;(DEFUN C:M   () (COMMAND "MOVE"))
(defun c:vv  () (command "move"))
(DEFUN C:ML  () (COMMAND "MOVE" "L" ""))
(DEFUN C:Mm  () (COMMAND "MOVE" "W"))
(DEFUN C:O  () (COMMAND "OFFSET"))
(DEFUN C:OO  () (COMMAND "OSNAP" "CENT"))
(DEFUN C:OE  () (COMMAND "OSNAP" "ENDP"))
(DEFUN C:OB  () (COMMAND "OSNAP" "INSERT"))
(DEFUN C:OI  () (COMMAND "OSNAP" "INTER"))
(DEFUN C:OM  () (COMMAND "OSNAP" "MIDP"))
(DEFUN C:On  () (COMMAND "OSNAP" "NEAR"))
(DEFUN C:Od  () (COMMAND "OSNAP" "NODE"))
(DEFUN C:OP  () (COMMAND "OSNAP" "PERP"))
(DEFUN C:PE  () (COMMAND "PEDIT"))
(DEFUN C:PL  () (COMMAND "PLINE"))
(DEFUN C:RG  () (COMMAND "REGENauto" "of"))
;(DEFUN C:RR  () (COMMAND "ROTATE"))
(DEFUN C:SA  () (COMMAND "QSAVE"))
(DEFUN C:Sc  () (COMMAND "SCALE"))
(DEFUN C:ST () (COMMAND "STRETCH"))
(DEFUN C:SN  () (COMMAND "SNAP"))
(DEFUN C:sd  () (COMMAND "SOLID"))
(DEFUN C:Ss1 () (COMMAND "STRETCH" "CROSS"))
(DEFUN C:T   () (COMMAND "TRIM"))
(DEFUN C:U  () (COMMAND "UNDO"))
(DEFUN C:VD  () (COMMAND "VIEW" "D"))
(DEFUN C:VR  () (COMMAND "VIEW" "R"))
(DEFUN C:VS  () (COMMAND "VIEW" "S"))
(DEFUN C:VW  () (COMMAND "VIEW" "W"))
(DEFUN C:VP  () (COMMAND "VPOINT"))
(DEFUN C:ZA  () (COMMAND "ZOOM" "A"))
(DEFUN C:ZZ  () (COMMAND "ZOOM" "P"))
;(DEFUN C:ZW  () (COMMAND "ZOOM" "W"))
(DEFUN C:ZD  () (COMMAND "ZOOM" "D"))
(DEFUN C:ZC  () (COMMAND "ZOOM" "C"))
(DEFUN C:ZE  () (COMMAND "ZOOM" "E"))
(DEFUN C:ZL  () (COMMAND "ZOOM" "L"))
(DEFUN C:zX  () (COMMAND "PAN"))
(defun c:zq  () (command "zoom" "p"))
(defun c:zZZ () (command "zoom" "c" pause "0.3x") (prin1) )
(defun c:xz () (command "zoom" ".51x")(prin1))
(defun c:cc (/ ss e n )
    ;; Version number. Reset this local if you make a change.
    (setq cl_ver " 2.01")
    (princ (strcat "\nChange layer, Version"cl_ver
                      ", (c) 1994-1996 by Pro-Team (China) CO.,LTD. "))
    (princ "\nSelect objects to be changed...\n")
    (setq ss(ssget))
    (if ss (progn
    (setq e (car (entsel "pick an object on the desired layer:")))
    (if e (progn
    (setq e(entget e))
    (setq n(cdr(assoc 8 e)))
    (command "change" ss"" "prop" "layer" n "color" "bylayer" "p" "lt"
        "bylayer" "")
(princ
   "\n\tC:CHLayer loaded.  Start command with CC.")
(princ)
;(LOAD "CC")
(defun c:r90 (/ gp) (setq gp (ssget)) (command "rotate" gp
"" pause "90"))
(defun c:r09 (/ gp) (setq gp (ssget)) (command "rotate" gp
"" pause "270"))
(defun c:rqa (/ gp) (setq gp (ssget)) (command "rotate" gp
"" pause "90"))
(defun c:rqb (/ gp) (setq gp (ssget)) (command "rotate" gp
"" pause "270"))
(defun c:r1 (/ gp) (setq gp (ssget)) (command "rotate" gp
"" pause "180"))
(defun c:1r (/ gp) (setq gp (ssget)) (command "rotate" gp
"" pause "-180"))
(defun c:r45 (/ gp) (setq gp (ssget)) (command "rotate" gp
"" pause "45"))
   (defun c:r54 (/ gp) (setq gp (ssget)) (command "rotate" gp
"" pause "315"))
(defun c:ff1( / e n )
        (setq e (car (entsel "\nPick an object on the desired layer:")))
        (if e
                (progn
                        (setq n (cdr (assoc 8 (entget e ))))
                        (command "layer" "f" n "")
                (princ "\nError!")
(defun c:rw ( / rr f ed l j c r )
        (setq f (car (entsel "Select a circle:")))
        (setq ed (entget f ))
        (setq j (cdr (assoc 0 ed )))
        (if
                ( = "CIRCLE" j )
        (progn  (setq c (cdr (assoc 10 ed)))
                (setq r (cdr (assoc 40 ed)))
                (setq rr ( + r r ))
                (command "donut" "0" rr c "" )
                (setq l (getvar "clayer"))
                (command "change" "l" "" "p" "la" l "" )
        (progn  (princ "Shit....."))
(defun c:ww ( / la rr f w l ww e ed j c r bk )
        (setq w (getvar "offsetdist"))
        (setq ww (+ w w ))
        (princ "\nEnter width(")
        (prin1  ww )
        (princ "):")
        (setq ww (getdist ))
        (if (= ww nil) (progn (setq ww (+ w w ))))
        (setq w (/ ww 2))
        (setq rr 1)
        (setq la (entsel))
        (if (= la nil) (setq rr 0))
        (while (= rr 1)
                (setq f (car la))
                (setq ed (entget f))
                (setq j (cdr (assoc 0 ed)))
                (command "offset" w la pause "" )
                (if
                        ( = "CIRCLE" j )
                (progn  (setq ed (entget (entlast)))
                        (setq bk1 (polar c 0 r))
                        (setq bk2 (polar c 1.57 r))
                        (command "break" bk1 bk2)
                 (if
                      ( = "POLYLINE" j )
               (progn (command "pedit" "l" "w" ww "" ))
               (progn (command "pedit" "l" "" "w" ww "" ))
                  (if ( = "CIRCLE" j ) (command "pedit" "l" "c" ""))
                  (command "change" "l" "" "p" "la" l "")
                  (setq  la (entsel))
                  (if (= la nil) (prin1 "shit!   shit!    shit......"))
(defun c:R9 () (command"rotate"pause "" "@" "90"))
(defun c:9R () (command"rotate"pause "" "@" "-90"))
(defun c:R0 () (command"rotate"pause "" "@" "180"))
(defun c:0R () (command"rotate"pause "" "@" "-180"))
(defun c:r6 () (command"rotate"pause "" "@" "60"))
(defun c:r0 () (command"rotate"pause "" "@" "180"))
(defun c:r45 () (command"rotate"pause "" "@" "45"))
(defun c:zd () (command"zoom" "d"))
(defun c:za () (command"zoom" "a"))
(defun c:zq () (command"zoom" "p"))
(defun c:ze () (command"zoom" "e"))
;(defun c:fd () (command"zoom" "2x"))
;(defun c:sx () (command"zoom" ".5x"))
(defun c:sa () (command"'_ddlmodes" ))
(defun c:eerR () (command"chval" ))
;(defun c:sd2 () (command"lengthen" "dy" ))
(defun c:UE () (command"UCS" "E" ))
(defun c:UP () (command"UCS" "P" ))
(defun c:arxx () (command"arx" "l" "E:/Program Files/Tangent/TArch7/asdehk/2002/asdehk.arx"))
发表于 2008-6-16 16:41:47 | 显示全部楼层
什么意思,,我看不懂,,,呵呵,,说说看
发表于 2008-6-16 23:58:59 | 显示全部楼层
好深奥的东西,呵呵
发表于 2008-6-17 14:18:33 | 显示全部楼层
好东西,但是为啥非要爱心币
发表于 2008-6-18 13:33:42 | 显示全部楼层
好复杂呀
发表于 2008-6-18 14:27:29 | 显示全部楼层
干什莫用的
 楼主| 发表于 2008-6-18 14:33:42 | 显示全部楼层
自己编的一些小东西,不过水平有限,只会一点点,所以,只能算刚学lso的水平,谢谢
发表于 2008-6-19 08:09:39 | 显示全部楼层
好东西,值得学习
发表于 2008-6-21 10:06:47 | 显示全部楼层
谢谢,学习一下
发表于 2008-6-24 11:57:03 | 显示全部楼层
说了半天 没看懂有什么用
看不懂程序
发表于 2008-6-24 13:12:44 | 显示全部楼层
谢谢楼主,值得学习借鉴。
发表于 2008-6-24 14:03:30 | 显示全部楼层
学习学习
发表于 2008-6-30 10:01:31 | 显示全部楼层
楼主最好是能够给些介绍就好了
发表于 2008-7-1 18:21:22 | 显示全部楼层
不错,是个好东东
GMT+8, 2024-6-10 18:33 , Processed in 0.366465 second(s), 61 queries , Gzip On.
© 2001-2024 Discuz! Team.
