查看: 1650|回复: 0
[其他] Mathworks Matlab R2013a ISO-NoGrp | 5.63 GB
发表于 2013-4-11 22:30:04 | 显示全部楼层 |阅读模式
Developer: Mathworks | Version: 2013a (8.01), build 604, 32 bit & 64 bit
System requirements:
Operating System: WinXP SP3, WinXP x64 SP2, Win2003 Server R2 SP2, Win Vista
SP2, Win 2008 Server SP2 or R2, Win 2012 Server, Win7, Win8
Processor: must support SSE2
Disk Space: Maximum 9GB
Memory: 1GB, (better 2GB) or more (depending on the task)
Installation:
The simplest way to setup Matlab is to run "SetupSimple.exe".
At the end of setup process when you will be asked for activation - select
"Cancel".
If this activation question will appear again when you start Matlab program
please activate Matlab manually according to steps 5-6 in the list below.
If simplified setup does not work for you - just execute steps 1-6 manually:
1) run "setup.exe" (or "bin\win32\setup.exe" to install 32-bit Matlab under
64-bit Windows)
2) choose "install manually without using the internet"
3) set the "file installation key" to be
4) setup Matlab with required components
5) when asked to activate the product select Activate manually without internet
6) select "X:\serial\license.lic" when asked for license file
(where "X" is drive letter for your burnt/mounted MATLAB image)
登录/注册后可看大图
Download From RapidGator Links
GMT+8, 2024-5-29 15:37 , Processed in 0.190917 second(s), 27 queries , Gzip On.
© 2001-2024 Discuz! Team.
