查看: 3314|回复: 10
[编程申请] 求一个自动计算面积和的程序
发表于 2013-4-19 09:19:43 | 显示全部楼层 |阅读模式
想在cad里实现几个图像的面积和自动计算并统计的程序,求高手指点
已领礼包: 1742个
财富等级: 堆金积玉
发表于 2013-4-19 09:26:16 | 显示全部楼层
贴截图,以及测试图档,方便对症下药
 楼主| 发表于 2013-4-19 09:39:19 | 显示全部楼层
入图请指教
发表于 2013-4-19 09:46:24 | 显示全部楼层
这程序论坛搜一下会无数个。
装个晓东工具箱吧,有你所要的。
已领礼包: 1742个
财富等级: 堆金积玉
发表于 2013-4-19 10:24:25 | 显示全部楼层
VLA-GET-AREA
已领礼包: 837个
发表于 2013-4-19 11:43:47 | 显示全部楼层
又看到了熟悉的界面还有晓东的屏幕菜单
已领礼包: 593个
发表于 2013-4-19 22:44:18 | 显示全部楼层
以前写的一个面积反应器DCL( 6年前的了{:soso_e100:})
[pcode=lisp,false]area : dialog {
label = "Area Setting By Eachy";
: column {
  : row {
    : edit_box {
      label = "字高";
      width = 10;
      key = "h";
    : popup_list {
      list = "2.0\n2.5\n3.0\n3.5\n4.0\n4.5\n5.0\n7.0";
      key = "kh";
  : row {
    : edit_box {
      label = "系数";
      key = "s";
      width = 8;
    : popup_list {
      list = "\n1e-6\n1.0\n1/666.667\n1000.0";
      key = "ks";
  : row {
    : edit_box {
      label = "后缀";
      key = "u";
      width = 8;
    : popup_list {
      list = "\n㎡\n亩\nh㎡";
      key = "ku";
  : row {
    : edit_box {
      label = "精度";
      key = "d";
      width = 8;
    : popup_list {
      list = "\n0\n1\n2\n3\n4\n5\n6\n7\n8\n9\n10";
      key = "kd";
ok_only;
}[/pcode]
已领礼包: 593个
发表于 2013-4-19 22:45:23 | 显示全部楼层
Lisp文件
[pcode=c,true];; Author: Eachy 2006.10.21
;;对实体增加字串类扩展数据
(defun ybl-addxdata (obj str / xType Value)
  (setq        xType (vlax-safearray-fill
                (vlax-make-safearray vlax-vbInteger '(0 . 1))
                (list 1001 1000)
        Value (vlax-safearray-fill
                (vlax-make-safearray vlax-vbVariant '(0 . 1))
                (list str str)
  (vla-setXdata obj xType Value)
;; 功能:增加面积标注字段,精度曲系统设置,后缀为 \U+33a1,
;;       面积系数可以指定,回车为 1
(defun area_reactor (txtobj objlst)
  (setq        area-reactor
         (vlr-object-reactor
           objlst
           (vla-get-handle txtobj)
           '((:vlr-modified . chg-area-txt-reaction))
  ;;(foreach x objlst (vlr-owner-add area-reactor))
(defun chg-area-txt-reaction (notifier reactor arg_list)
  (chg-area-txt (vlr-data reactor))
(defun chg-area-txt (handle / hl doc lst tx)
  (vl-catch-all-apply
    '(lambda ()
       (setq doc (vla-get-activedocument (vlax-get-acad-object)))
       (if (not        (vl-catch-all-error-p
                  (setq        tx (vl-catch-all-apply
                             'vla-handletoobject
                             (list doc handle)
         (progn
           (setq
             hl        (vlax-ldata-get
                  (setq tx (vla-handletoobject doc handle))
                  "Area_obj"
           (setq lst (vlax-ldata-get "Area_setting" "Setting"))
           (vla-put-textstring
             tx
             (strcat
               (rtos
                 (* (cadr lst)
                    (apply '+
                           (mapcar
                             '(lambda (x / aa)
                                           (setq aa (vl-catch-all-apply
                                                      'vla-handletoobject
                                                      (list doc x)
                                  (vla-get-area aa)
                                  0.
                             hl
                 2
                 (last lst)
               (caddr lst)
(vl-catch-all-apply
  'vla-eval
  (list        (vlax-get-acad-object)
        "Thisdrawing.ActiveSelectionset.delete"
(vl-catch-all-apply
  '(lambda (/ doc lst objlst tf)
     (if (ssget "X" '((-3 ("Ea_Area_Object"))))
       (vlax-for x (vla-get-activeselectionset doc)
         (setq lst (vlax-ldata-get x "Area_obj"))
         (if (setq objlst
                    (vl-remove
                      nil
                      (mapcar '(lambda (a / tx)
                                                       'vla-handletoobject
                                                       (list doc a)
                                   tx
                                   nil
                              lst
           (progn (setq tf t)
                  (area_reactor x objlst)
     (if tf
       (princ "\nFind Area Reactor Objects, It's associated!")
(defun getarea (/     *acad*          doc        ms    ss    pcen  area        bp
                up    grps  str          txt        grp   scl   pcen  txth        diff
                kd    kh    ks          ku        kw    or_lst          prc        scl
                scll  sub   th          txth        code  curlst          kd        kh
                ks    ku    ppt          prc        scl   scll  sub          tf        txth
                zarea
  (defun area_setting (/      _area_id            kh           ks          ku         d
                       dimscale             th            dimflac          diff         lst
                       or_lst prc    scl    sub           txth          kd
    (setvar "dimzin" 0)
    (if        (not _area_id)
      (setq _area_id (load_dialog "area.dcl"))
    (if        (not (new_dialog "area" _area_id))
      (exit)
    (setq kh '("2.0" "2.5" "3.0" "3.5" "4.0" "4.5" "5.0" "7.0")
          ks '("1e-6" "1.0" "0.145" "1000.0")
          kd '("0" "1" "2" "3" "4" "5" "6" "7" "8" "9" "10")
          ku '("㎡" "亩" "h㎡")
    ;; Setting (texthigh scalefactor sub diff)
    (if        (vlax-ldata-list "Area_setting")
      (setq or_lst (vlax-ldata-get "Area_setting" "Setting")
            th           (vl-princ-to-string (car or_lst))
            scl           (vl-princ-to-string (cadr or_lst))
            sub           (caddr or_lst)
            diff   (itoa (last or_lst))
      (setq dimscale (getvar "dimscale")
            dimflac  (getvar "dimflac") ;_线形因子
            th             (vl-princ-to-string (getvar "dimtxt"))
            scl             (if (or (and (> dimscale 1.)
                                  (>= dimflac 1.)
                                  (<= dimflac 1.)
                       "1e-6"
                       "1.0"
            scll     scl
            diff     (vl-princ-to-string (getvar "luprec"))
            sub             "㎡"
    (mode_tile "d" 1)
    (set_tile "s" scl)
    (set_tile "h" th)
    (set_tile "d" diff)
    (set_tile "u" sub)
    (action_tile
      "accept"
      "(setq txth (get_tile \"h\"))(setq scl (get_tile \"s\"))(setq sub (get_tile \"u\"))(setq prc (get_tile \"d\"))(done_dialog 0)"
    (action_tile "h" "(setq txth $value)")
    (action_tile "s" "(setq scl $value)")
    (action_tile "u" "(setq sub $value)")
    (action_tile "d" "(setq prc $value)")
    (action_tile "kh" "(set_tile \"h\" (nth (atoi $value) kh))")
    (action_tile "ks" "(set_tile \"s\" (nth (atoi $value) ks))")
    (action_tile "ku" "(set_tile \"u\" (nth (atoi $value) ku))")
    (action_tile "kd" "(set_tile \"d\" (nth (atoi $value) kd))")
    (start_dialog)
    (unload_dialog _area_id)
    (if        (or (not (distof txth)) (zerop (distof txth)))
      (setq txth th)
      (setq txth (distof txth))
    (if        (or (not (distof scl)) (zerop (distof scl)))
      (setq scl (read scll))
      (setq scl (distof scl))
    (if        (or (not (distof prc)) (zerop (distof prc)))
      (setq prc (getvar "luprec"))
      (setq prc (atoi prc))
    (vlax-ldata-put
      "Area_setting"
      "Setting"
      (list txth scl sub prc)
    (princ)
  (setq *acad* (vlax-get-acad-object))
  (vla-eval *acad* "Thisdrawing.ActiveSelectionset.delete")
  (setq        doc  (vla-get-activedocument *acad*)
        ms   (vla-get-modelspace doc)
        grps (vla-get-groups doc)
          sub         (caddr or_lst)
    (vlax-ldata-put
      "Area_setting"
      "Setting"
      (list (* (getvar "dimscale") (getvar "dimtxt"))
            1.0
            (getvar "luprec")
  (area_setting)
  (princ "\nSelect Pline,Circle,Ellipse,Spline,Hatch....")
  (if (setq ss (ssget '((0 . "lwpolyline,circle,ellipse,spline,hatch"))))
    (progn
      (vla-put-color (vla-add (vla-get-layers doc) "_$Area") 5)
            th           (car or_lst)
            scl           (strcat "%ct8["
            sub           (caddr or_lst)
            diff   (last or_lst)
            $area  0.
      (vlax-for        obj (vla-get-activeselectionset doc)
        (vla-getboundingbox obj 'bp 'up)
                                        ;(princ bp )
                                        ;(princ up)
        (setq pcen   (vlax-3d-point
                       (mapcar
                         '(0.5 0.5 0.5)
                         (mapcar '+
                                 (safearray-value bp)
                                 (safearray-value up)
              $area  (+        $area
                        (vla-get-area obj)
              curlst (cons obj curlst)
                                        ;(princ pcen)
        (setq txt
               (vla-addtext
                 ms
                 (setq
                   str (strcat "%<\\AcObjProp Object(%<\\_ObjId "
                               (itoa (vla-get-objectid obj))
                               ">%).Area \\f \"%lu2%pr"
                               (itoa diff)
                               "%ps[,"
                               sub
                               scl
                 pcen
                 th
                                        ;(princ str)
        (vla-put-alignment txt acAlignmentMiddleCenter)
        (vla-put-textalignmentpoint txt pcen)
        (vla-put-layer txt "_$Area")
        (setq grp (vla-add grps "*"))
        (vla-appenditems
          grp
          (vlax-make-variant
              (vlax-make-safearray vlax-vbobject '(0 . 1))
              (list txt obj)
      (setq zarea (vla-addtext
                    ms
                    (rtos (* (cadr or_lst) $area) 2 diff)
                    (vlax-3d-point (cadr (grread nil 13 2)))
                    th
            tf          t
      (princ "\nPick Point: ")
      (while tf
        (setq ppt  (grread nil 13 2)
              code (car ppt)
        (cond
          ((= code 3)
           (vla-put-insertionpoint zarea (vlax-3d-point (cadr ppt)))
           (vlax-ldata-put
             zarea
             "Area_obj"
             (mapcar 'vla-get-handle curlst)
           (area_reactor zarea curlst)
           (ybl-addxdata zarea "Ea_Area_Object")
           (setq tf nil)
          ((= code 5)
          (t (vla-delete zarea) (setq tf nil))
  (princ)
(defun c:getarea ()
  (vl-catch-all-apply 'getarea nil)
  (princ)
(defun c:gat ()   (vl-catch-all-apply 'getarea nil)
  (princ)
(princ
  "\nStart Command with Getarea & Gat, Author: eachy. 2006.11.22!"
(princ)[/pcode]
评分
参与人数 1D豆 +4 收起 理由
XDSoft + 4 技术引导讨论和指点奖!
查看全部评分
已领礼包: 145个
发表于 2013-4-19 22:54:13 | 显示全部楼层
看到这种对话框,好远古的感脚。:P
已领礼包: 3394个
发表于 2013-5-3 20:49:57 | 显示全部楼层
XDSoft 发表于 2013-4-19 22:54
看到这种对话框,好远古的感脚。
不错,学习学习:lol
发表于 2013-7-16 09:01:31 | 显示全部楼层
我也想要一个
GMT+8, 2024-6-7 18:37 , Processed in 0.395636 second(s), 60 queries , Gzip On.
© 2001-2024 Discuz! Team.
