查看: 15813|回复: 49
[已解决] 批量交点打断
已领礼包: 218个
发表于 2013-4-19 10:01:08 | 显示全部楼层 |阅读模式
各位有批量交点打断!!各自塞下 总有个你觉得很好
本帖被以下淘专辑推荐:
已领礼包: 1757个
财富等级: 堆金积玉
发表于 2013-11-2 12:50:36 | 显示全部楼层
Free-Lancer 发表于 2013-4-19 11:04
贴一个复杂的
(defun c:Ea:ssbrk (/                 THINKING      removedups
                   ybl-pts-sortoncurve               ybl-m ...
{:soso_e113:} 这个是目前见到的打断中 运行最快 得到结果最好的一个 对于使用lisp而言
回复 支持 0 反对 2
已领礼包: 1742个
财富等级: 堆金积玉
发表于 2013-4-19 10:06:36 | 显示全部楼层
遍历各个交点,删除对象,批量生成图元
已领礼包: 218个
 楼主| 发表于 2013-4-19 10:19:06 | 显示全部楼层
已领礼包: 1742个
财富等级: 堆金积玉
发表于 2013-4-19 10:21:20 | 显示全部楼层
我分享个别人的,供参考!
[pcode=lisp,true];;;=======================[ BreakObjects.lsp ]==============================
;;               M A I N   S U B R O U T I N E
(defun break_with (ss2brk ss2brkwith self / cmd intpts lst masterlist ss ssobjs
                   onlockedlayer ssget->vla-list list->3pair
                   get_interpts break_obj
  ;; ss2brk     selection set to break
  ;; ss2brkwith selection set to use as break points
  ;; self       when true will allow an object to break itself
  ;;            note that plined will break at each vertex
  (vl-load-com)
;;                S U B   F U N C T I O N S
  (defun onlockedlayer (ename / entlst)
    (setq entlst (tblsearch "LAYER" (cdr (assoc 8 (entget ename)))))
    (= 4 (logand 4 (cdr (assoc 70 entlst))))
  (defun ssget->vla-list (ss / i ename lst)
    (setq i -1)
    (while (setq ename (ssname ss (setq i (1+ i))))
      (setq lst (cons (vlax-ename->vla-object ename) lst))
    lst
  (defun list->3pair (old / new)
    (while (setq new (cons (list (car old) (cadr old) (caddr old)) new)
                 old (cdddr old))
    (reverse new)
;;  return a list of intersect points
(defun get_interpts (obj1 obj2 / iplist)
  (if (not (vl-catch-all-error-p
             (setq iplist (vl-catch-all-apply
                            'vlax-safearray->list
                            (list
                              (vlax-variant-value
                                (vla-intersectwith obj1 obj2 acextendnone)
    iplist
;;  Break entity at break points in list
(defun break_obj (ent brkptlst / brkobjlst en enttype maxparam closedobj
        minparam obj obj2break p1param p2 p2param
  (setq obj2break ent
brkobjlst (list ent)
enttype (cdr (assoc 0 (entget ent)))
  (foreach brkpt brkptlst        ;  get last entity created via break
           ; in case multiple breaks
    (if brkobjlst
      (progn          ;  if pt not on object x, switch
           ; objects
(if (not (numberp (vl-catch-all-apply 'vlax-curve-getdistatpoint
           (list obj2break brkpt)
   (foreach obj brkobjlst       ; find the one that pt is on
     (if (numberp (vl-catch-all-apply 'vlax-curve-getdistatpoint
          (list obj brkpt)
       (setq obj2break obj)     ; switch objects
    )           ;  handle any objects that can not
           ; be used with the break command
           ;  using one point, gap of 0.000001
           ; is used
    (cond
      ((and
  (= "SPLINE" enttype)        ; only closed splines
  (vlax-curve-isclosed obj2break)
(setq p1param (vlax-curve-getparamatpoint obj2break brkpt)
       p2 (vlax-curve-getpointatparam obj2break (+ p1param 0.000001))
(command "._break" obj2break "_non" (trans brkpt 0 1) "_non"
   (trans p2 0 1)
      ((= "CIRCLE" enttype)        ; break the circle
   (trans p2 0 1)
(setq enttype "ARC")
      ((and
  (= "ELLIPSE" enttype)        ; only closed ellipse
       )          ;  break the ellipse, code borrowed
           ; from joe burke  6/6/2005
       p2param (+ p1param 0.000001)
       minparam (min
    p1param
    p2param
       maxparam (max
    p1param
    p2param
       obj (vlax-ename->vla-object obj2break)
(vlax-put obj 'startparameter maxparam)
(vlax-put obj 'endparameter (+ minparam (* pi 2)))
      (t          ;   objects that can be broken
(setq closedobj (vlax-curve-isclosed obj2break))
   (trans brkpt 0 1)
(if (not closedobj)        ; new object was created
   (setq brkobjlst (cons (entlast) brkobjlst))
  ;;                   S T A R T   H E R E
    (if (and ss2brk ss2brkwith)
    (progn
      ;;  CREATE a list of entity & it's break points
      (foreach obj (ssget->vla-list ss2brk) ; check each object in ss2brk
        (if (not (onlockedlayer (vlax-vla-object->ename obj)))
          (progn
            (setq lst nil)
            ;; check for break pts with other objects in ss2brkwith
            (foreach intobj (ssget->vla-list ss2brkwith)
              (if (and (or self (not (equal obj intobj)))
                       (setq intpts (get_interpts obj intobj))
                (setq lst (append (list->3pair intpts) lst)) ; entity w/ break points
            (if lst
              (setq masterlist (cons (cons (vlax-vla-object->ename obj) lst) masterlist))
      ;;  masterlist = ((ent brkpts)(ent brkpts)...)
      (if masterlist
        (foreach obj2brk masterlist
          (break_obj (car obj2brk) (cdr obj2brk))
(princ)
;;        Break all objects selected
(defun c:breakall (/ cmd ss)
  (command ".undo" "begin")
  (setq cmd (getvar "CMDECHO"))
  (setvar "CMDECHO" 0)
  ;;  get objects to break
  (prompt "\nSelect All objects to break & press enter: ")
  (if (setq ss (ssget '((0 . "LINE,ARC,SPLINE,LWPOLYLINE,POLYLINE,CIRCLE,ELLIPSE"))))
     (Break_with ss ss nil) ; ss2break ss2breakwith (flag nil = not to break with self)
  (setvar "CMDECHO" cmd)
  (command ".undo" "end")
  (princ)
;;  Break a single object with many objects
(defun c:BreakObject (/ cmd ss1 ss2)
  (prompt "\nSelect single object to break: ")
  (if (and (setq ss1 (ssget "+.:E:S" '((0 . "LINE,ARC,SPLINE,LWPOLYLINE,POLYLINE,CIRCLE,ELLIPSE"))))
           (not (redraw (ssname ss1 0) 3))
           (not (prompt "\n***  Select object(s) to break with & press enter:  ***"))
           (setq ss2 (ssget '((0 . "LINE,ARC,SPLINE,LWPOLYLINE,POLYLINE,CIRCLE,ELLIPSE"))))
           (not (redraw (ssname ss1 0) 4)))
     (Break_with ss1 ss2 nil) ; ss2break ss2breakwith (flag nil = not to break with self)
  (princ)
;;  Break many objects with a single object
(defun c:breakwobjects (/ cmd ss1 ss2)
  (defun ssredraw (ss mode / i num)
    (setq i -1)
      (redraw (ssname ss i) mode)
  (prompt "\nSelect object(s) to break & press enter: ")
  (if (and (setq ss1 (ssget '((0 . "LINE,ARC,SPLINE,LWPOLYLINE,POLYLINE,CIRCLE,ELLIPSE"))))
           (not (ssredraw ss1 3))
           (not (prompt "\n***  Select single object to break with:  ***"))
           (setq ss2 (ssget "+.:E:S" '((0 . "LINE,ARC,SPLINE,LWPOLYLINE,POLYLINE,CIRCLE,ELLIPSE"))))
           (not (ssredraw ss1 4))
    (break_with ss1 ss2 nil) ; ss2break ss2breakwith (flag nil = not to break with self)
  (princ)
;;  Break many objects with many object
(defun c:BreakWith (/ cmd ss1 ss2)
    (setq i -1)
  (princ)
;;  Break many objects with a selected objects
;;  Selected Objects create ss to be broken
(defun c:BreakTouching (/ cmd ss1 ss2)
  ;;  get all objects touching entities in the sscross
  ;;  limited obj types to "LINE,ARC,SPLINE,LWPOLYLINE,POLYLINE,CIRCLE,ELLIPSE"
  (defun gettouching (sscros / ss lst lstb lstc objl)
    (and
      (setq lstb (vl-remove-if 'listp (mapcar 'cadr (ssnamex sscros)))
            objl (mapcar 'vlax-ename->vla-object lstb)
      (setq
        ss (ssget "_A" (list (cons 0 "LINE,ARC,SPLINE,LWPOLYLINE,POLYLINE,CIRCLE,ELLIPSE")
                             (cons 410 (getvar "ctab"))))
      (setq lst (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss))))
      (setq lst (mapcar 'vlax-ename->vla-object lst))
      (mapcar
        '(lambda (x)
           (mapcar
             '(lambda (y)
                (if (not
                        (vl-catch-all-apply
                          '(lambda ()
                             (vlax-safearray->list
                               (vlax-variant-value
                                 (vla-intersectwith y x acextendnone)
                  (setq lstc (cons (vlax-vla-object->ename x) lstc))
              ) objl)
         ) lst)
    lstc
  (setq ss1 (ssadd))
  (if (and (not (prompt "\nSelect object(s) to break with & press enter: "))
           (mapcar '(lambda (x) (ssadd x ss1)) (gettouching ss2))
  (princ)
;;  Break selected objects with any objects that touch it
(defun c:BreakSelected (/ cmd ss1 ss2)
    (and
      (setq
      (mapcar
        '(lambda (x)
           (mapcar
             '(lambda (y)
                (if (not
                        (vl-catch-all-apply
                          '(lambda ()
                               (vlax-variant-value
              ) objl)
         ) lst)
    lstc
  (setq ss1 (ssadd))
    (break_with ss2 ss1 nil) ; ss2break ss2breakwith (flag nil = not to break with self)
  (princ)
[/pcode]
打断函数有缺陷,http://bbs.xdcad.net/thread-704397-1-1.html  详情 回复 发表于 2016-6-8 15:04
已领礼包: 218个
 楼主| 发表于 2013-4-19 10:33:03 | 显示全部楼层
炫翔 发表于 2013-4-19 10:21
我分享个别人的,供参考!
;;;=======================[ BreakObjects.lsp ]========================== ...
非常好用的大家踊跃的出来啊
发表于 2013-4-19 11:04:35 | 显示全部楼层
贴一个复杂的
[pcode=lisp,true](defun c:Ea:ssbrk (/                 THINKING      removedups
                   ybl-pts-sortoncurve               ybl-mklwpline
                   ybl-mkellipse ybl-mkline    ybl-mkarc
                   ybl-circletoarc               sstolist
                   lll                 ss               cset
                   eDoc                 n               oldos
                   t1                 sl
  (defun THINKING (prmpt)
    (setq n (1+ n))
    (princ (strcat "\r"
                   (nth (rem n 4) '("|" "/" "-" "\\"))
                   prmpt
  (defun removedups (lst / p pl)
    (while lst
      (setq p (car lst))
      (if (not (equal p (car pl)))
        (setq pl (cons p pl))
      (setq lst (cdr lst))
    (reverse pl)
  ;;端点判断
  (defun ispoint (lst p1 p2)
    (and (= (length pts) 2)
         (or (and (equal (car pts) sp 1e-9)
                  (equal (cadr pts) ep 1e-9)
             (and (equal (car pts) ep 1e-9)
                  (equal (cadr pts) sp 1e-9)
  ;;Break 去除端点
  (defun removepoint (lst p1 p2)
    (if        (equal (car lst) p1 1e-9)
    (if        (equal (last lst) p2 1e-9)
      (setq lst (reverse (cdr (reverse lst))))
    lst
  ;;交点沿曲线排升序
  (defun ybl-pts-sortoncurve (e pts / pl sp ep el typ)
    (if        (and (setq sp (vlax-curve-getstartpoint e)
                   ep (vlax-curve-getendpoint e)
             (ispoint pts sp ep)
        ) ;_ startpoint and endpoint
      (setq pts nil)
      ;;circle ellipse 不一定需要 startpoint endpoint
      (progn
        (if (not (vlax-curve-isclosed e))
          (setq pts (cons sp (cons ep pts)))
        (setq
          pts
           (removedups
             (vl-sort
                          (list        (vlax-curve-getparamatpoint
                                  e
                                  (vlax-curve-getclosestpointto e x)
                                x
                       pts
               '(lambda (e1 e2) (< (car e1) (car e2)))
    ) ;_ remove startpoint
    pts
  ;;断开 spline pline,闭合 spline 不能打断
  (defun ybl-brkspline (lst / e pts p0 pam)
    (setq e   (car lst)
          pts (reverse (mapcar 'cadr
                               (ybl-pts-sortoncurve
                                 e
                                 (cdr lst)
              ) ;_ 逆序)
    (if        pts
      (if (and (vlax-curve-isclosed e) ;_ closed
               (> (length pts) 1)
          ) ;_两个以上交点才断开
        (progn
          (setq        p0  (car pts)
                pts (cdr pts)
                pam (vlax-curve-getparamatpoint
                      e
                      (vlax-curve-getclosestpointto e p0)
          (vl-cmdf ".break"
                   e
                   "_non"
                   p0
                   "_non"
                   (vlax-curve-getpointatparam e (+ pam 0.0000001))
          ) ;_两个交点以上先断开一个小口
          (setq pts (removepoint pts sp ep))
          (if pts
            (foreach p pts
              (vl-cmdf ".break" e p p)
        (progn ;_ opened
                      pts
          (if pts
            (foreach p pts
  (defun ybl-mklwpline (lst  /          e    el   pts         c70  h0   h1        pl
                        vn   i          vp   vvp  v         nnp  tf   p1        b
                        vn   vertexinfo            l         a    bugle        e
                        ew   few  forp fsw  spam sw   x
    (setq e   (car lst)
          el  (entget e '("*"))
          c70 (cdr (assoc 70 el))
    (if        (or (= (logand c70 4) 4) ;_Fit
            (= (logand c70 2) 2) ;_spline
      (progn
        (setq pts (mapcar 'cadr (ybl-pts-sortoncurve e (cdr lst)))
              pts (removepoint
                    pts
        (if pts
          (progn
            (vl-cmdf ".break" e (car pts) (car pts))
            (foreach p (cdr pts)
              (vl-cmdf
                ".break"
                (entlast)
                (setq p1 (vlax-curve-getclosestpointto (entlast) p))
                p1
              ) ;_ 对拟和 pline 断开后均为新实体,原实体消失
      ;;Lwpolyline 非样条化Polyline 3Dpolyline 用 entmake
      (progn
        (setq pts (ybl-pts-sortoncurve e (cdr lst))
              pts (removepoint
                    (mapcar 'cadr pts)
                  ) ;_去除起点、终点
        (if pts
          (progn
            (if        (= (cdr (assoc 0 el)) "LWPOLYLINE") ;_lwpolyline
              (progn
                (setq pts (mapcar
                            '(lambda (x)
                                       e
                                     (list 10 (car x) (cadr x))
                            pts
                          ) ;_((param (10 x1 y1)) ....
                      h0  (list        '(0 . "LWPOLYLINE")
                                '(100 . "AcDbEntity")
                                (assoc 8 el)
                                '(100 . "AcDbPolyline")
                      h1  (vl-remove 'nil
                                     (list '(70 . 0) ;_断开的肯定是非闭合了
                                           (assoc 43 el)
                                           (assoc 38 el)
                                           (assoc 39 el)
                      pl  (member (assoc 10 el) el)
                      vn  (cdr (assoc 90 el))
                      i          0.
                (repeat        vn
                  (setq        vp (cons (list i
                                       (car pl)
                                       (cadr pl)
                                       (caddr pl)
                                       (cadddr pl)
                                 vp
                        pl (cddddr pl)
                        i  (1+ i)
                ) ;_顶点信息表((param vertex startwidth endwidth bugle) ...)
                (setq vp         (reverse vp) ;_(removedups (reverse vp))
                      vertexinfo vp
                (if (vlax-curve-isclosed e)
                  (setq
                    vp (append
                         vp
                         (list
                           (cons (vlax-curve-getendparam e) (cdar vp))
                (setq vp (append pts vp) ;_合并点表
                      vp (vl-sort vp
                ;;分组,子表长度为 2 的是交点
                (while vp
                  (setq        v  (car vp)
                        vp (cdr vp)
                  (if vvp
                    (progn
                      (setq
                        vvp
                         (cons (append (list v) (car vvp)) (cdr vvp))
                      (if (= (length v) 2) ;_ inters
                        (progn
                          (setq vvp (cons (list v) vvp))
                          (if (= (length (car vp)) 1)
                            (setq vp (cdr vp))
                (setq vvp (vl-remove-if
                            '(lambda (x) (= (length x) 1))
                            (reverse (mapcar 'reverse vvp))
                ) ;_方向和原线一致
                ;;对交点增加弧度,首尾宽度
                ;;弧度只和当前段有关
                ;;|起始为交点的时候修改起始宽度
                (foreach l vvp
                  (setq vn (length l)) ;_新线段的顶点数
                  (setq a (car l))
                  (if (= (length a) 2) ;_交点
                    (progn
                      (setq spam (fix (car a))
                            forp (assoc spam vertexinfo) ;_(index point startwidth endwidth bugle)
                            fsw         (nth 2 forp)
                            few         (nth 3 forp)
                            tf         (< (cdr (last forp)) 0.)
                      (if (equal (cdr fsw) (cdr few))
                        (setq sw fsw
                              ew few
                        ) ;_等宽
                        (progn
                          (setq        sw (cons 40
                                         (+ (* (- (car a) spam) ;_前顶点StartWidth
                                               (- (cdr few) (cdr fsw))
                                            ) ;_前顶点Endwidth
                                            (cdr fsw)
                                   ) ;_末端宽度成比例
                          (setq        ew (cons 41
                                         (+ (* (- (car (cadr l)) spam)
                                            ) ;_前顶点Endwidth
                                            (cdr fsw)
                                   ) ;_末端宽度成比例
                      ;;bugle
                      ;;肯定是中间段,Bugle要计算
                      (setq bugle (/ (distance
                                         e
                                         (/ (+ (car a) (caadr l)) 2.)
                                       (ybl-midp (cdadr a)
                                                 (cdr (cadadr l))
                                                 t
                                     (/        (distance (cdadr a)
                                                  (cdr (cadadr l))
                                        2.
                      (if tf
                        (setq bugle (- bugle))
                      (setq l (cons (list (car a) ;_ param
                                          (cadr a) ;_ point
                                          sw ;_startwidth
                                          ew ;_endwidth
                                          (cons 42 bugle) ;_bugle
                                    (cdr l)
                  ;;|末尾是交点的时候要修改前一点的结束宽度
                  (if (= (length (last l)) 2) ;_交点
                    (progn
                            forp (cadr (reverse l))
                                        ; spam vertexinfo) ;_(index point startwidth endwidth bugle)
                            fsw         (nth 2 forp)
                            few         (nth 3 forp)
                        (setq sw fsw
                              ew few
                        ) ;_等宽
                        (setq sw fsw
                              ew (cons 41
                                       (+ (* (- (car (last l)) spam) ;_前顶点StartWidth
                                             (- (cdr few) (cdr fsw)) ;_前顶点Endwidth
                                          (cdr fsw)
                                 ) ;_末端宽度成比例
                      ;;bugle
                      ;;肯定是中间段,Bugle要计算
                      (setq bugle
                             (/        (distance
                                    e
                                    (/ (+ (car (last l))
                                          (car (cadr (reverse l)))
                                       2.
                                  (ybl-midp (cdadr (last l))
                                            (cdadr (cadr (reverse l)))
                                            t
                                (/ (distance (cdadr (last l))
                                   2.
                      (if (< (cdr (assoc 42 (reverse l))) 0.)
                      (setq l (subst (list (car forp) ;_ param
                                           (cadr forp) ;_ point
                                           sw ;_startwidth
                                           ew ;_endwidth
                                     (assoc spam l)
                                     l
                  (entmake
                    (append h0
                            (list (cons 90 vn))
                            h1
                            (apply 'append (mapcar 'cdr l))
                                        ;vp ;_ 210
              ;;polyline
              (progn
                      pts (removepoint
                            pts
                (if pts
                  (progn
                      (vl-cmdf
                        ".break"
                        (entlast)
                        (setq p1
                        p1
                    (entdel e)
            (entdel e)
  ;;Ellipse 分段
  (defun ybl-mkellipse (lst / e el pams pcen an)
    (setq e    (car lst)
          pams (mapcar 'car (ybl-pts-sortoncurve e (cdr lst)))
    (if        pams
      (progn
        (setq el   (entget e '("*"))
              pcen (cdr (assoc 10 el))
              an   (angle pcen (vlax-curve-getstartpoint e))
          (setq pams (append pams (list (+ (car pams) pi pi))))
        (if (> (length pams) 2)
          (progn
            (mapcar
              '(lambda (x y)
                 (entmake (append el (list (cons 41 x) (cons 42 y))))
              (cdr pams)
              (cddr pams)
            (entmod
              (append el
                      (list (cons 41 (car pams)) (cons 42 (cadr pams)))
  ;;Line 分段
  (defun ybl-mkline (lst / sp ep ln el pts)
    (setq ln  (car lst)
          sp  (vlax-curve-getstartpoint ln)
          ep  (vlax-curve-getendpoint ln)
          pts (removedups
                (vl-sort
                  (cons ep (cons sp (cdr lst)))
                  '(lambda (e1 e2)
                     (if (equal (cadr e1) (cadr e2) 1e-9)
                       (< (cadr e1) (cadr e2))
    (if        (> (length pts) 2)
      (progn
        (setq el (entget ln '("*")))
        (mapcar        '(lambda (x y / l)
                   (entmake (append el (list (cons 10 x) (cons 11 y))))
                (cdr pts)
                (cddr pts)
        (entmod
          (append el (list (cons 10 (car pts)) (cons 11 (cadr pts))))
  ;;分段 Arc
  (defun ybl-mkarc (lst / arc pamlst el)
    (setq arc         (car lst)
          pamlst (mapcar 'car (ybl-pts-sortoncurve arc (cdr lst)))
    (if        (> (length pamlst) 2)
      (progn
        (setq el (entget arc))
                   (entmake (append el (list (cons 50 x) (cons 51 y))))
                (cdr pamlst)
                (cddr pamlst)
        (entmod
          (append el
                  (list (cons 50 (car pamlst)) (cons 51 (cadr pamlst)))
  ;;圆转化为 Arc
  (defun ybl-circletoarc (lst / e el pam rs lyr th pcen)
    (setq e   (car lst)
          pam (mapcar 'car (ybl-pts-sortoncurve e (cdr lst)))
    (if        (> (length pam) 1)
      (progn
              rs   (assoc 40 el)
              lyr  (assoc 8 el)
              pcen (assoc 10 el)
              th   (if (setq th (assoc 39 el))
                     th
                     (setq th '(39 . 0.))
                   (setq l (list '(0 . "ARC")
                                 '(100 . "AcDbArc")
                                 pcen
                                 lyr
                                 th
                                 rs
                                 (cons 50 x)
                                 (cons 51 y)
                                 '(210 0. 0. 1.)
                   (entmake l)
                pam
                (append (cdr pam) (list (+ (car pam) pi pi)))
        (entdel e)
  ;;选择集转化为列表
  ;;实体列表、实体类型+句柄列表、Object列表
  ;;三者是一一对应关系
  (defun sstolist (ss / ssl i el typl eel typ c70 key)
    (setq ssl (sslength ss)
          i   -1
    (thinking
      (strcat "\r共 " (itoa ssl) " 个实体排序中,请稍候.....")
    (if        (> ssl 800)
      (progn
        (initget "Y N")
        (setq key
               (getkword
                 "\n本次处理将耗费较多的时间! 建议分区域处理, 是否继续[Y/N]<N>: "
        (if (= key "N")
          (exit)
    (repeat ssl
      (setq e        (ssname ss (setq i (1+ i)))
            typ        (cdr (assoc 0 (setq l (entget e))))
      (if (/= typ "POLYLINE")
        (setq el (cons e el))
        (progn
          (setq c70 (cdr (assoc 70 l)))
          (if (and (zerop (logand c70 16))
                   (zerop (logand c70 32))
                   (zerop (logand c70 64))
    ) ;_速度最快
    (vlax-for obj (vla-get-activeselectionset
                    (vla-get-activedocument (vlax-get-acad-object))
      (if (not (wcmatch (vla-get-objectname obj) "*Mesh"))
        (setq eel (cons obj eel))
    ) ;_ 比 vlax-ename->vla-object 快
    (setq
      typl (mapcar '(lambda (x / l)
                      (setq l (entget x))
                      (strcat (cdr (assoc 0 l)) (cdr (assoc 5 l)))
                   el
    ) ;_ 表出来,取出类型+句柄
    (list el typl eel)
  ;;曲线集交点,将交点分配到实体上
  (defun ybl-ss-inters (ss   /          ll   el   obj         o1   ol   o2        pts
                        ptl  typl typ  e1   yl         zl   e2   typ1        nn
                        cs   lst
    (setq ll   (sstolist ss)
          el   (car ll) ;_ entity
          obj  (last ll) ;_ object list
          typl (cadr ll) ;_ type
          lll  typl
          nn   1
    (mapcar '(lambda (x) (set (read x) nil)) lll)
    (while obj
      (thinking
        (strcat        "\r共 "
                (itoa sl)
                " 个实体, 第 "
                (itoa nn)
                " 求交点,请稍候....."
      (setq o1         (car obj) ;_ object 1
            obj         (cdr obj)
            typ         (car typl)
            typl (cdr typl)
            e1         (car el)
            el         (cdr el)
            zl         el
            ol         obj
            yl         typl
            nn         (1+ nn)
      (while ol
        (setq o2   (car ol) ;_ object 2
              ol   (cdr ol)
              typ1 (car yl)
              yl   (cdr yl)
              e2   (car zl)
              zl   (cdr zl)
        (if (setq pts (safearray-value
                        (variant-value
                          (vla-intersectwith o1 o2 acextendnone)
          (progn
            (setq ptl (ybl-lst-split pts 3))
            (if        (eval (read typ))
              (set (read typ) (append ptl (eval (read typ))))
              (set (read typ) (append ptl (list e1)))
            (if        (eval (read typ1))
              (set (read typ1) (append ptl (eval (read typ1))))
              (set (read typ1) (append ptl (list e2)))
    (if        lll
      (progn
        (setq cs 1)
        ;;断开曲线
        (foreach a (vl-sort lll '<)
          (princ (strcat "\r处理实体 "
                         (itoa sl)
                         " 中第 "
                         (itoa cs)
                         " 个曲线"
          (setq        cs  (1+ cs)
                lst (reverse (eval (read a)))
          (if lst
            (cond
              ((wcmatch a "ARC*")
               (ybl-mkarc (reverse (eval (read a))))
              ((wcmatch a "CIRCLE*")
               (ybl-circletoarc (reverse (eval (read a))))
              ((wcmatch a "ELLIPSE*")
               (ybl-mkellipse (reverse (eval (read a))))
              ((wcmatch a "LINE*")
               (ybl-mkline (reverse (eval (read a))))
              ((wcmatch a "*POLYLINE*")
               (ybl-mklwpline (reverse (eval (read a))))
              (t (ybl-brkspline (reverse (eval (read a)))))
  ;;Main
  ;;kLine kArc kCircle kPline kSpline
             (setq cset
                    (vl-catch-all-apply
                      'vla-item
                      (list
                        (vla-get-selectionsets
                          (setq
                            eDoc (vla-get-activedocument (vlax-get-acad-object))
                        "CURRENT"
    (vla-delete cset)
  (vla-startundomark eDoc)
  (setq oldos (getvar "osmode"))
  (setvar "osmode" 0)
  (princ
    "\n选择Line,ellipse,arc,circle,spline,lwpolyline,polyline....."
  (vl-catch-all-apply
    '(lambda (/ ss)
       (if (setq ss
                  (ssget ":L"
                         '((0 . "ellipse,line,*polyline,arc,circle,spline"))
           ) ;_选择时过滤
         (progn
           (setq t1 (ybl-getutime)
                 sl (sslength ss)
                 n  0
           (ybl-ss-inters ss)
    nil
  (setq lll nil)
  (setvar "osmode" oldos)
  (vla-endundomark eDoc)
  (if t1
    (progn (princ "\rOk, 共耗时")
           (princ (- (ybl-getutime) t1))
           (princ "秒.                       ")
  (princ)
[/pcode]
为何运行不了?  详情 回复 发表于 2021-11-5 11:26
这个是目前见到的打断中 运行最快 得到结果最好的一个 对于使用lisp而言  详情 回复 发表于 2013-11-2 12:50
当年找EA这个程序没找到,想模仿一个也没成功,今天终于见到了!  详情 回复 发表于 2013-5-31 09:10
已领礼包: 344个
发表于 2013-4-19 12:03:31 | 显示全部楼层
批量交点打断,除了Spline曲线外,其他曲线最好都不要用Break命令,以提高效率!
已领礼包: 145个
发表于 2013-4-19 12:51:19 | 显示全部楼层
嗯嗯,不只这个程序,能尽量不用command就尽量不用。
已领礼包: 344个
发表于 2013-4-19 14:12:51 | 显示全部楼层
对于不涉及程序运行效率的时候,其实用哪种方法都无所谓,只要代码简单、能实现目的就OK了!我们的终极目的是提高绘图效率!
发表于 2013-4-19 14:19:56 | 显示全部楼层
6# 楼的代码好像仅Spline用了Break, 其他的都是Entmake新实体
发表于 2013-4-27 09:12:41 | 显示全部楼层
谢谢提供!正需要了!
已领礼包: 188个
发表于 2013-5-7 12:38:20 | 显示全部楼层
贴一个复杂的
试用了一下,没有成功。好象缺少子函数。
发表于 2013-5-7 14:33:59 | 显示全部楼层
SmartStar 发表于 2013-5-7 12:38
试用了一下,没有成功。好象缺少子函数。
那些函数很简单,看名字也能在论坛搜索到
缺哪个函数啊,能指点一点吗  详情 回复 发表于 2013-12-5 16:35
发表于 2013-5-30 05:43:44 | 显示全部楼层
呵呵,又是批量交点打断,好呀
已领礼包: 2个
发表于 2013-5-31 09:10:15 | 显示全部楼层
贴一个复杂的
XDRXapi 升级后一个函数就搞定了 BTW:小道消息,很快就会推出直接支持到 2014 版(包括32位及64位)  详情 回复 发表于 2013-5-31 09:53
GMT+8, 2024-5-29 22:42 , Processed in 0.277096 second(s), 64 queries , Gzip On.
© 2001-2024 Discuz! Team.
