查看: 839|回复: 2
[他山之石] 构造ActiveX方式的过滤选择
发表于 2013-5-27 07:50:29 | 显示全部楼层 |阅读模式
Making a filtered selection set using Visual LISP (ActiveX functions)                                                        By Balaji Ramamoorthy
The ActiveX method SelectionSet.Select to create a filtered set of database objects that meet this criteria:
Block references, such as INSERT entities, and that have extended entity data that is registered under application name "MYAPP"
The plain AutoLISP expression is:  (ssget "X" '((0 . "INSERT") (-3 ("MYAPP"))))
Here is the code using the ActiveX call :
  1. (defun c:myappSet ()
  2.     (vl-load-com)
  3.     (setq loAcad    (vlax-get-acad-object)
  4.           loDoc        (vla-get-activedocument loAcad)
  5.           loSelectionSet (vla-add (vla-get-selectionsets loDoc) "filtSet")
  6.     )
  7.     (setq filtArray (vlax-make-safearray vlax-vbInteger '(0 . 1))
  8.           filtVar   (vlax-safearray-fill filtArray (list 0 1001))
  9.           filtType  (vlax-make-variant
  10.                         filtVar
  11.                         (logior vlax-vbarray vlax-vbInteger)
  12.                     )
  13.     )
  14.     (setq filtArray (vlax-make-safearray vlax-vbVariant '(0 . 1))
  15.           filtVar   (vlax-safearray-fill filtArray (list "INSERT" "MYAPP"))
  16.           filtData  (vlax-make-variant
  17.                         filtVar
  18.                         (logior vlax-vbarray vlax-vbVariant)
  19.                     )
  20.     )
  21.     (vla-select
  22.                 loSelectionSet
  23.                 acSelectionSetAll
  24.                 nil
  25.                 nil
  26.                 filtType
  27.                 filtData
  28.     )
  29.     (setq count (vla-get-count loSelectionSet))
  30.     (princ count)
  31.     (setq ssets (vla-get-selectionsets loDoc))
  32.     (vla-delete (vla-item ssets "filtSet"))
  33.     (princ)
  34. )
It is tempting for a Visual LISP developer to supply list arguments for the parameters filtType and filtData in the vla-select call, but ActiveX does not comprehend lists. The filtType parameter requires an array of integers while filtData is permitted to be a array of variant types.
For a closer examination of safearrays and variants, see the Visual LISP Developer's Guide. Refer to the section entitled "Converting AutoLISP Data Types to ActiveX Data Types".
Also, the group code designating xdata is 1001 instead of -3. This is different, of course, from the Visual LISP approach to filtering xdata, which makes use of the -3 extended data sentinel rather than group code.
评分
参与人数 1D豆 +4 收起 理由
xshrimp + 4 很给力!经验;技术要点;资料分享奖!
查看全部评分
已领礼包: 3255个
发表于 2013-5-27 19:45:04 | 显示全部楼层
英语没学好的  表示压力很大
已领礼包: 5个
发表于 2020-3-17 01:01:59 | 显示全部楼层
困扰好久天,终于找到了,万分感谢!
GMT+8, 2024-6-8 14:44 , Processed in 0.309841 second(s), 34 queries , Gzip On.
© 2001-2024 Discuz! Team.
