查看: 3068|回复: 9
[原创] 再发一个绿化标注程序
已领礼包: 593个
发表于 2013-5-27 11:31:52 | 显示全部楼层 |阅读模式
老早在晓东工具箱中的程序,用DCL写的,可能有个别通用函数,请自行搜索论坛
Lisp  部分[pcode=lisp,true]
;;; 本代码仅提供作为应用上的参考, 而未声明或隐含任何保证; 对于任何特殊
;;  用途之适应性, 以及商业销售所隐含作出的保证, 在此一概予以否认.
                    ;  作者:Eachy,
;; 命令:Ea_LhBZ     标注命令
;; 命令:Ea_EdLH     标注编辑
;; 命令:Ea_SetScale 比例设置
;; 命令:Ea_MKTitle  统计表表头及表格生成
;; 命令: TXT_TJ      统计图中相同字串的个数
;; 命令: Ea_EraLh    删除本程序生成的图元
;|;比例控制
(if (not (vlax-ldata-list "ea_sys_scale"))
  (vlax-ldata-put "ea_sys_scale" "scale" 1.)
|;                    ;(setvar "cmdecho" 0)
;;设定字体
(defun $ea_setfont (/ oldsty)
  (if (null (tblsearch "style" "yb_lhbz"))
    (progn
      (setq oldsty (getvar "textstyle"))
      (command "style" "yb_lhbz" "gbenor,gbcbig" "" "1"    "" "" "")
      (setvar "textstyle" oldsty)
  (princ)
($ea_setfont)
;;检查当前字体,setvar 设置当前字体时出错
(defun $chk_curfont ()
  (= (strcase (getvar "textstyle")) "YB_LHBZ")
;|;设置比例
(defun c:Ea_setScale (/ scl)
  (setq    scl
     (getreal
       (strcat
         "\n出图比例<"
         (vl-prin1-to-string (vlax-ldata-get "ea_sys_scale" "scale"))
  (if (and (/= scl "") scl)
    (vlax-ldata-put "ea_sys_scale" "scale" scl)
;;空字串(nil 或 "" "   ")检查
(defun $ea:string_check    (str)
  (cond
    ((or (= str "") (= str nil)) nil)
    (t
     (not (equal '((0. 0. 0.) (0. 0. 0.))
         (textbox (list (cons 1 str)))
;;去除名称中的数字
(defun $ea:chk_name (str / num)
  (setq num (rtos (atof (ea:string_reverse str)) 2 0))
  (vl-string-right-trim num str)
;;测量两字串的最大长度
(defun $ea_textlength (str)
  (caadr
    (textbox
      (list (cons 40 (* 3.5 (vlax-ldata-get "ea_sys_scale" "scale")))
        (cons 1
          (if str
            str
        '(7 . "YB_LHBZ")
;;bz      名称|数量|说明|高度|冠幅|胸径;
;;control 名称|数量|说明|高度|冠幅|胸径|文件标志|绘线标志
(if (not (vlax-ldata-list "ea_lhbz"))
  (mapcar '(lambda (x y) (vlax-ldata-put "ea_lhbz" x y))
      '("bz" "control")
      '("0|0|0|0|0|0" "1|1|1|1|1|1|0|1")
;;; 读取植物名称文件放入txt_tb中 frutex 灌木 arbor 乔木
(defun ea:do_init (tf / fname fp txt1 txt_tb)
  (setq    fname (findfile    (if (= tf "0")
              "frutex.txt"
              "arbor.txt"
  (setq fp (open fname "r"))
  (setq txt_tb '())
  (while (setq txt1 (read-line fp))
    (setq txt_tb (cons txt1 txt_tb))
  (close fp)
  (reverse txt_tb)
建立文件或对文件追加字串;
参数说明   tf    T    追加 ;
                 nil  新建
           str   "0"  灌木词典;
                 "1"  乔木词典;
           str1  字串或字串表,往文件追加的字串
(defun ea:write_file (tf str str1 / f fp)
  (setq    f (if (= str "0")
        "frutex.txt"
        "arbor.txt"
  (if tf
    (setq f (findfile f))
  (setq fp (open f "a"))
  (if (= (type str1) 'STR)
    (write-line str1 fp)
    (mapcar '(lambda (x) (write-line x fp)) str1)
  (close fp)
;;检查词典文件,没有-》自动生成
(if (not (findfile "frutex.txt"))
  (ea:write_file
    nil
    "0"
    '("杜鹃"        "连翘"      "洒金珊瑚"    "金叶女贞"
      "红花继木"    "茶梅"      "月季"    "云南黄馨"
      "栀子"        "龟背冬青"      "金丝桃"    "贴梗海棠"
      "六月雪"        "小叶黄杨"      "八角金盘"    "小腊"
      "龙柏"        "金边绣线菊"  "南天竹"
(if (not (findfile "arbor.txt"))
  (ea:write_file
    nil
    "1"
    '("无患子"     "雪松"        "日本柳杉" "香樟"      "日本早樱" "广玉兰"
      "桂花"     "杜英"        "银杏"     "合欢"      "马褂木"   "水杉"
      "垂柳"     "白玉兰"   "深山含笑" "乐昌含笑" "榉树"     "七叶树"
      "油松"     "黑松"        "白皮松"   "湿地松"      "南洋杉"   "侧柏"
      "圆柏"     "金钱松"   "赤松"     "池杉"      "白兰花"   "青冈轹"
      "榕树"     "女贞"        "棕榈"     "鹅掌秋"      "国槐"     "枫香"
      "悬铃木"     "青杨"        "朴树"     "旱柳"      "乌桕"     "白桦"
      "枫杨"     "楝树"        "元宝枫"   "三角枫"      "樱花"     "栾树"
      "臭椿"     "白蜡"
;;对实体增加字串类扩展数据
(defun ea:addxdata (obj str / TypeArray xType TypeValue Value)
  (setq TypeArray (vlax-make-safearray vlax-vbInteger '(0 . 1)))
  (setq
    xType (vlax-safearray-fill TypeArray (list 1001 1000))
  (setq TypeValue (vlax-make-safearray vlax-vbVariant '(0 . 1)))
  (setq    Value (vlax-safearray-fill
        TypeValue
        (list str str)
  (vla-setXdata obj xType Value)
;;对话框设定
(defun ea:setlhbz (/          $do_default     do_setvarriant
           do_help9      _ealh_id     do_seltype
           do_what      txt_tb     $chk_display
  (defun $chk_display ()
    (mode_tile "nn" 1)
    (if    (not ($ea:string_check (get_tile "sm")))
      (mode_tile "ss" 1)
      (mode_tile "ss" 1)
    (if    (not ($ea:string_check (get_tile "num")))
      (mode_tile "aa" 1)
      (mode_tile "aa" 1)
    (if    (not ($ea:string_check (get_tile "hig")))
      (mode_tile "hh" 1)
      (mode_tile "hh" 1)
    (if    (not ($ea:string_check (get_tile "wih")))
      (mode_tile "ww" 1)
      (mode_tile "ww" 1)
    (if    (not ($ea:string_check (get_tile "ro")))
      (mode_tile "rr" 1)
      (mode_tile "rr" 1)
  ;;对话框默认值
  (defun $do_default (/    _$tr _$ctr name    num sm hig wih ro tf nn    aa ss hh
              ww rr fl plctr)
    (setq _$tr    (ea:string_parse (vlax-ldata-get "ea_lhbz" "bz") "|")
      _$ctr    (ea:string_parse (vlax-ldata-get "ea_lhbz" "control") "|")
    (setq name    ($ea:chk_name (car _$tr))
      num    (cadr _$tr)
      sm    (nth 2 _$tr)
      hig    (nth 3 _$tr)
      wih    (nth 4 _$tr)
      ro    (last _$tr)
      nn    (car _$ctr)
      aa    (cadr _$ctr)
      ss    (nth 2 _$ctr)
      hh    (nth 3 _$ctr)
      ww    (nth 4 _$ctr)
      rr    (nth 5 _$ctr)
      fl    (nth 6 _$ctr)        ;乔灌木记录 "0" 灌木 "1" 乔木
      plctr    (last _$ctr)        ;"0" 绘引线 "1" 不绘
    (start_list "what")            ;将词组显示到列表框内
    (mapcar 'add_list (ea:do_init fl))
    (end_list)
    (set_tile (if (= fl "0")
        "fs"
        "as"
          "1"
    ;;可变标签
    (if    (= fl "1")
      (progn
    (set_tile "num_label" "")
    (set_tile "num_label" "株数")
    (set_tile "wih_label" "")
    (set_tile "wih_label" "地径")
      (progn
    (set_tile "num_label" "面积")
    (set_tile "wih_label" "胸径")
           (if (/= y "0")
         (set_tile x y)
        '("name" "num" "sm" "hig" "wih" "ro")
        _$tr
    (mapcar '(lambda (x y) (set_tile x y))
        '("nn" "aa" "ss" "hh" "ww" "rr" "pl")
        (list nn aa ss hh ww rr plctr)
                    ;(mode_tile "nn" 0)
                    ;($chk_display)
    (setq txt_tb (ea:do_init fl))
  ;;设定
  (defun do_setvarriant    (str / va tile _$tr _$ctr string mark)
    (cond ((= str 0) (setq tile "name"))
      ((= str 1) (setq tile "num") (setq mark "aa"))
      ((= str 2) (setq tile "sm") (setq mark "ss"))
      ((= str 3) (setq tile "hig") (setq mark "hh"))
      ((= str 4) (setq tile "wih") (setq mark "ww"))
      ((= str 5) (setq tile "ro") (setq mark "rr"))
      ((= str 6) (setq tile "nn"))
      ((= str 7) (setq tile "aa"))
      ((= str 8) (setq tile "ss"))
      ((= str 9) (setq tile "hh"))
      ((= str 10) (setq tile "ww"))
      ((= str 11) (setq tile "rr"))
      ((= str 13) (setq tile "pl"))
      ;;((= str 13) (setq tile "pl"))
    (setq va (get_tile tile))
                    ;(if (< str 6) (set_tile mark "1"))
                    ;($chk_display)
    (setq _$tr (ea:string_parse (vlax-ldata-get "ea_lhbz" "bz") "|"))
    (if    (> str 5)
      (setq
    (setq string (ea:string_unparse
           (ea:subst-n
             (if (<= str 5)
               str
               (- str 6)
             (if ($ea:string_check $value)
               $value
               "0"
             _$tr
    (vlax-ldata-put
      "ea_lhbz"
      (if (< str 6)
    "bz"
    "control"
      string
  (defun do_seltype (tf / _$ctr fl)
    (setq
    (setq fl (nth 6 _$ctr))        ;乔灌木记录 "0" 灌木 "1" 乔木
    (setq txt_tb (ea:do_init tf))
    (mapcar 'add_list txt_tb)
    (end_list)
    ;;改变标签
    (if    (= tf "0")
      (progn
      (progn
    (set_tile "name" "")
                    ;($chk_display)
    (vlax-ldata-put
      "ea_lhbz"
      "control"
      (ea:string_unparse
    (ea:subst-n 6 tf _$ctr)
  (defun do_what (/ txt _$tr i)
    (setq i (atoi $value))        ;选中词组
    (setq txt (nth i txt_tb))
    (set_tile "name" txt)
                    ;($chk_display)
    (vlax-ldata-put
      "ea_lhbz"
      "bz"
      (ea:string_unparse
    (ea:subst-n 0 txt _$tr)
  (defun do_help9 ()
    (alert
      "\n绿化标注  作者:Eachy
         \n=======================================
         \n  1 名 称 植物名称
         \n  2 数 量 植物的株数或面积,数字或数字加 m
         \n  3 说 明 植物造型说明
         \n  4 高 度 植物高度,文字、数字或连字符数字"
  ;; 主程序开始
  (if (not _ealh_id)
    (setq _ealh_id (load_dialog "ea_lhbz.dcl"))
  (if (not (new_dialog "ea_lhbz" _ealh_id))
    (exit)
  ($do_default)
  (action_tile "accept" "(done_dialog 1)")
  (action_tile "what" "(do_what)")
  (action_tile "name" "(do_setvarriant 0)")
  (action_tile "num" "(do_setvarriant 1)")
  (action_tile "sm" "(do_setvarriant 2)")
  (action_tile "hig" "(do_setvarriant 3)")
  (action_tile "wih" "(do_setvarriant 4)")
  (action_tile "ro" "(do_setvarriant 5)")
  (action_tile "nn" "(do_setvarriant 6)")
  (action_tile "aa" "(do_setvarriant 7)")
  (action_tile "ss" "(do_setvarriant 8)")
  (action_tile "hh" "(do_setvarriant 9)")
  (action_tile "ww" "(do_setvarriant 10)")
  (action_tile "rr" "(do_setvarriant 11)")
  (action_tile "pl" "(do_setvarriant 13)")
  (action_tile "fs" "(do_seltype \"0\")") ;灌木
  (action_tile "as" "(do_seltype \"1\")") ;乔木
  (action_tile "help" "(do_help9)")
  (start_dialog)
  (unload_dialog _ealh_id)
  (princ)
;;创建标注块
(defun ea:lhblk_make (p2    ang      /    blkang        por      _$tr    _$ctr
              name  sm      wih    hig   num   ro      nn    aa
              ss    hh      rr    ww    pn    ps      ph    pw
              len   p3      blkdef      blkref      str1    str2
              len   c      plctr    pr
  (if (or (<= ang (/ pi 2))
      (> ang (* 1.5 pi))
    (setq blkang 0.)
    (setq blkang pi)
  (setq $yb_global_scale (* (car (ea:init)) (cadr (ea:init))));vlax-ldata-get "ea_sys_scale" "scale"))
  (setq por '(0. 0. 0.))
  (setq    name  (car _$tr)
    num   (cadr _$tr)
    sm    (nth 2 _$tr)
    hig   (nth 3 _$tr)
    ro    (nth 4 _$tr)
    wih   (last _$tr)
    nn    (car _$ctr)
    aa    (cadr _$ctr)
    ss    (nth 2 _$ctr)
    hh    (nth 3 _$ctr)
    rr    (nth 4 _$ctr)
    ww    (nth 5 _$ctr)
  (if (/= name "0")
    (progn
      (if (/= num "0")
    (if (vl-string-search "M" (strcase num))
      (setq num (strcat num "%%178"))
    (setq num nil)
      (if (/= hig "0")
    (if (numberp (read hig))
      (setq hig (strcat "H" hig))
    (setq hig nil)
      (if (/= wih "0")
    (setq wih (strcat "W" wih))
    (setq wih nil)
      (if (/= ro "0")
    (setq ro (strcat "%%C" ro))
    (setq ro nil)
      (if (= sm "0")
    (setq sm nil)
      (setq str1 (ea:string_unparse
           (vl-remove nil
                  (list name
                    (if    (= aa "0")
                      nil
                      num
                    (if    (= ss "0")
                      nil
                      sm
        str2 (vl-remove nil
                (list (if (= hh "0")
                    nil
                    hig
                  (if (= ww "0")
                    nil
                    wih
                  (if (= rr "0")
                    nil
                    ro
      (if str2
    (setq str2 (ea:string_unparse str2 ","))
    (setq str2 " ")
      ;;决定画线的长度
      (setq len
           (apply
         'max
         (mapcar
           '$ea_textlength
           (list str1
             str2
           (* 1.5 $yb_global_scale)
      (setq p3 (polar por blkang len))
      (setq p3 (mapcar '(lambda (x) (EA:ZEROSMALLNUM x)) p3))
      (setq pn (if (= blkang 0.0)
         (list $yb_global_scale $yb_global_scale 0.)
         (mapcar '+ p3 (list $yb_global_scale $yb_global_scale 0.))
        ph (mapcar '+ pn (list 0. (- (* 4.5 $yb_global_scale)) 0.))
      ;;建立匿名块
      (setq BLKDEF
         (vla-add (vla-get-blocks
            (vla-get-activedocument (vlax-get-acad-object))
              (vlax-3d-point por)
              ;;要 '(0. 0. 0.)为原点
              "*U"
      ;;是否画线
      (if (= plctr "1")
    (vla-addline
      blkdef
      (vlax-3d-point por)
      (vlax-3d-point p3)
      ;;tag prompt cont 值为空时分解块文字消失
         (vla-addattribute
           blkdef
           (* 3.5 $yb_global_scale)
           acAttributeModePreset
           x
           (vlax-3d-point pn)
           x
           x
      )                    ;植物属性
      (setq blkref (vla-insertblock
             (vla-get-modelspace
             (vlax-3d-point p2)
             (vla-get-name BLKDEF)
             (vlax-make-variant 1 vlax-vbdouble)
             (vlax-make-variant
               (ea:angle_format blkang)
               vlax-vbdouble
      )                    ;将块插入到模型空间
      (setq c 1)
      (setq pn (mapcar '+ pn p2)    ;属性在图纸空间的插入点
        pa (polar pn 0. ($ea_textlength name))
        ps (if (and num (= aa "1"))
         (polar
           pa
           0.
           ($ea_textlength
             (strcat "," num)
         pa
        ph (mapcar '+ ph p2)
        pw (if (and hig (= hh "1"))
         (polar    ph
            0.
            ($ea_textlength hig)
         ph
        pr (polar
         pw
         0.
         (if (= ww "1")
           ($ea_textlength
             (strcat ","
                 (if wih
                   wih
           0.
      ;;对插入的块赋予 tag 值,getattributes 得到的属性顺序与加入时的一致
      (mapcar
    '(lambda (x)
       (cond
         ((= c 1)
          (vla-put-tagstring x "名称")
          (vla-put-textstring x name)
         ((= c 2)
          (vla-put-tagstring x "数量")
          (if num
        (progn
          (vla-put-textstring
            x
            (if    (numberp num)
              (strcat "," (rtos num 2 0))
              (strcat "," num)
          (vla-put-insertionpoint
            x
            (vlax-3d-point pa)
          (if (= aa "0")
            (vla-put-visible x :vlax-false) ;属性是否显示,下同
         ((= c 3)
          (vla-put-tagstring x "说明")
          (if sm
        (progn
          (vla-put-textstring x (strcat "," sm))
            x
            (vlax-3d-point ps)
          (if (= ss "0")
         ((= c 4)
          (vla-put-tagstring x "高度")
          (if hig
        (progn
          (vla-put-textstring
            x
            hig
          (vla-put-insertionpoint x (vlax-3d-point ph))
          (if (= hh "0")
         ((= c 5)
          (vla-put-tagstring x "冠幅")
          (if (and wih (= ww "1"))
        (progn
          (vla-put-textstring
            x
              (strcat "," wih)
              wih
            x
            (vlax-3d-point pw)
          (if (= ww "0")
        (setq pw ph)
         ((= c 6)
          (vla-put-tagstring x "地径")
          (if ro
        (progn
          (vla-put-textstring
            x
            (if    (and (or hig wih) (or (= hh "1") (= ww "1")))
              (strcat "," ro)
              ro
            x
            (vlax-3d-point pr)
          (if (= rr "0")
         (t)
       (setq c (1+ c))
    (vlax-safearray->list
      (vlax-variant-value (vla-getattributes blkref))
      ;;对块增加Xdata,方便选择处理
      (ea:addxdata blkref "YB_LHBZ")
(defun c:Ea_lhbz (/       tf        p0         p00      ang      $fl_mark
          $txt_tb  _name    _conlst  $plctr   HostAcad oldos
          oldor       oldsty   xln
  ;;主程序
  (ea:begin '("osmode" "orthomode"))
  (setq oldsty ($chk_curfont))
  (setvar "osmode" 0)
  (setvar "orthomode" 1)
  (if (not ($chk_curfont))
    (progn
      (setvar "textstyle" "yb_lhbz")
  (setq tf t)
  (if (= (car (ea:string_parse (vlax-ldata-get "ea_lhbz" "bz") "|"))
     "0"
    (ea:setlhbz)
  (while tf
    (initget "S")
    (if    (setq p0 (getpoint "\n第一点[S - 设置]<退出>: "))
      (cond
    ((= p0 "S")
     (ea:setlhbz)
    ((= (type p0) 'LIST)
     (progn
       (setq _conlst (ea:string_parse
       (setq $fl_mark (nth 6 _conlst)
         $plctr      (last _conlst)
         $txt_tb  (ea:do_init $fl_mark)
       (setq _name
          ($ea:chk_name
       (if (and (/= _name "0") (not (member _name $txt_tb)))
         ;;检查ldata中的名称是否在 $txt_tb ,没有->写入
         (ea:write_file t $fl_mark _name)
       (if (= $plctr "1")
         (progn
           (setq p00 (getpoint p0 "\n第二点: "))
           (if (and    (/= (angle p0 p00) 0.0)
            (/= (angle p0 p00) pi)
         (setq ang (getangle p00 "\n角  度: "))
         (setq ang (angle p0 p00))
         (setq p00 p0
           ang 0.
       (if (and p0 p00 ang)
         (progn
           (setq xln (vla-addline
               (model-space)
               (vlax-3d-point p0)
               (vlax-3d-point p00)
           (ea:addxdata xln "YB_LHBZ1")
           ;;引线加xdata
           (ea:lhblk_make p00 ang)
    (t (setq tf nil))
      (setq tf nil)
  (if (= (type oldsty) 'STR)
  (ea:end)
  (princ)
(defun c:Ea_Edlh (/      HostAcad      tf      e      obj
          pl      name      lst      plctr      txt_tb  txtlst
          elst      conlst  fl      oldos      oldor      oldsty
          ang
  ;;主程序
  (setvar "orthomode" 0)
    (progn
      (setvar oldsty (getvar "textstyle"))
  (setq tf t)
  (while tf
    (setq e (ea:entself "\n选择绿化标注: " '((-3 ("yb_lhbz")))))
    (if    e
      (progn
    (setq obj (vlax-ename->vla-object (car e))
          pl  (vla-item
            (vla-item
              (vla-get-blocks
              (vla-get-name obj)
            0
    (if (= (vla-get-objectname pl) "AcDbLine")
      (progn
        (setq plctr "1")
        (setq ang (vla-get-angle pl))
      (progn (setq plctr "0") (setq ang 0.0))
    (setq lst    (ea:getattributes obj)
          name   (caar lst)
          txt_tb (ea:do_init "0")
          fl     (if (member name txt_tb)
               "0"
               "1"
          elst   (mapcar '(lambda (x) (last x)) lst)
          txtlst (mapcar '(lambda (x / y)
                (setq y    (if (= (cadr x) "")
                      "0"
                      (cadr x)
                (setq y (vl-string-left-trim "," y))
                (setq y (vl-string-right-trim "%%178" y))
                (setq y (vl-string-left-trim "H" y))
                (setq y (vl-string-left-trim "W" y))
                (setq y (vl-string-left-trim "%%C" y))
                 lst
          conlst (mapcar '(lambda (x)
                (cond
                  ((= (vla-get-textstring
                    (vlax-ename->vla-object x)
                   "0"
                  ((= (vla-get-visible
                      :vlax-false
                   "0"
                  (t "1")
                 elst
    (vlax-ldata-put
      "ea_lhbz"
      "control"
      (strcat (ea:string_unparse conlst "|") "|" fl "|" plctr)
    (vlax-ldata-put
      "ea_lhbz"
      "bz"
      (ea:string_unparse txtlst "|")
    (ea:setlhbz)
    (ea:lhblk_make
      (ea:lisp-value (vla-get-insertionpoint obj))
      ang
    (vla-delete obj)
      (setq tf nil)
  (ea:end)
  (princ)
(defun c:TXT_TJ    (/ ss e string txtlst)
  (setq e (ea:entself "\n点选统计文字:" '((0 . "text"))))
  (if e
    (progn
      (princ "\n拾取选择范围[ALL - 全选]...")
      (setq ss (ssget (list '(0 . "text") (assoc 8 (entget (car e))))))
      (foreach e (ea:ssgettoentitylist ss)
    (setq string (ea:dxf e 1))
    (if txtlst
      (progn
        (if    (assoc string txtlst)
          (setq
        txtlst (subst
             (append (list string) (assoc string txtlst))
             txtlst
          (setq txtlst (append (list (list string)) txtlst))
      (setq txtlst (list (list string)))
         (princ (strcat (car x) " " (itoa (length x)) " | "))
          txtlst
  (princ)
;;定义苗木表表头及表格, 块定义以 '(0 0 0) 为基点定义
(defun ea:mk_title (/ BLKDEF_title pl BLKDEF_Cel c )
  (if (not (tblsearch "block" "Yb_LH_Title"))
    (progn
      (setq BLKDEF_title
              (vlax-3d-point '(0. 0. 0.))
              "Yb_LH_Title"
      (setq pl (vla-AddLightweightPolyline
         BLKDEF_title
         (list->VariantArray
           '(0. 0. 14.2 0. 14.2 1.2 0. 1.2)
           vlax-vbDouble
      (vla-put-closed pl :vlax-true)
      (mapcar '(lambda (x y / txt)
         (setq txt (vla-AddText
                 BLKDEF_title
                 x
                 (vlax-3d-point y)
                 0.4
         (vla-put-alignment txt acAlignmentMiddleCenter)
         (vla-put-TextAlignmentPoint txt (vlax-3d-point y))
          '("序号" "名  称"  "备   注")
          '((0.5 0.6 0.) (2.2 0.6 0.) (12.6 0.6 0.))
                 BLKDEF_title
                 x
                 (vlax-3d-point y)
                 0.36
          '("规    格" "高度(M)" "冠幅(M)")
          '((6.1 0.9 0.) (4.3 0.3 0.) (7.9 0.3 0.))
      (mapcar '(lambda (pt / txt)
         (setq txt (vla-addattribute
                 BLKDEF_title
                 0.38
                 (vlax-3d-point pt)
         (vla-put-TextAlignmentPoint txt (vlax-3d-point pt))
         ;|(if tf
           (progn
             (vla-put-tagstring txt "数量")
             (vla-put-textstring txt "数量(株)")
           (progn
             (vla-put-tagstring txt "面积")
             (vla-put-textstring txt "面积(m%%178)")
          '((9.9 0.6 0.)
        (6.1 0.3 0.)
         (vla-addline
           BLKDEF_title
           (vlax-3d-point (car x))
           (vlax-3d-point (cadr x))
          '(((1. 0. 0.) (1. 1.2 0.))
        ((3.4 0. 0.) (3.4 1.2 0.))
        ((8.8 0. 0.) (8.8 1.2 0.))
        ((11. 0. 0.) (11. 1.2 0.))
        ((5.2 0. 0.) (5.2 0.6 0.))
        ((7. 0. 0.) (7. 0.6 0.))
        ((3.4 0.6 0.) (8.8 0.6 0.))
  (if (not (tblsearch "block" "Yb_LH_Cel"))
    (progn
      (setq BLKDEF_Cel
              "Yb_LH_Cel"
         (vla-addline
           BLKDEF_Cel
          '(((1. 0. 0.) (1. -0.8 0.))
        ((3.4 0. 0.) (3.4 -0.8 0.))
        ((5.2 0. 0.) (5.2 -0.8 0.))
        ((7. 0. 0.) (7. -0.8 0.))
        ((8.8 0. 0.) (8.8 -0.8 0.))
        ((11. 0. 0.) (11. -0.8 0.))
        ((14.2 0. 0.) (14.2 -0.8 0.))
        ((1. -0.8 0.) (14.2 -0.8 0.))
      (setq c 1)
      (mapcar '(lambda (x pt / txt)
                 BLKDEF_Cel
                 0.38
                 (vlax-3d-point pt)
                 x
         (vla-put-alignment
           txt
           (if (= c 1)
             acAlignmentMiddleLeft
         (setq c (1+ c))
          '("名称" "高度" "胸径" "冠幅" "数量")
          '((1.25 -0.4 0.)
        (4.3 -0.4 0.)
        (6.1 -0.4 0.)
        (7.9 -0.4 0.)
        (9.9 -0.4 0.)
  (princ)
(defun c:Ea_MKTitle (/ txt pt pcen ptxt)
  (ea:begin '("osmode" "textstyle"))
  (setvar "osmode" 0)
  (setq pt (getpoint "\n输出点: "))
  (if pt
    (progn
      (setq pcen         (getvar "viewctr")
        $yb_global_scale (vlax-ldata-get
                   "ea_sys_scale"
                   "scale"
      (ea:mk_title)
      (mapcar
    '(lambda (x)
       (vla-insertblock
         (vla-get-modelspace
         (vlax-3d-point pt)        ;insertpoint
         x                ;block name
         (vlax-make-variant (* 10 $yb_global_scale) vlax-vbdouble)
                    ;x 比例
                    ;Y
                    ;Z
         (vlax-make-variant 0 vlax-vbdouble) ; rotation
    '("Yb_LH_Title" "Yb_LH_Cel")
      (setq ptxt (mapcar '+
             (list (* 71 $yb_global_scale)
                   (* 16 $yb_global_scale)
                   0.
             pt
          (model-space)
          "苗木统计一览表"
          (vlax-3d-point ptxt)
          (* 7 (vlax-ldata-get "ea_sys_scale" "scale"))
      (vla-put-alignment txt acAlignmentCenter)
      (vla-put-TextAlignmentPoint txt (vlax-3d-point ptxt))
      (vla-addline
    (model-space)
    (vlax-3d-point pt)
    (vlax-3d-point
      (polar pt (- (/ pi 2)) (* 8 $yb_global_scale))
      ;|(vla-zoomcenter
    (vla-get-Application
    (vlax-3d-point (getvar "viewctr"))
    (vlax-make-variant (* 300 $yb_global_scale) vlax-vbdouble)
  (ea:end)
  (princ)
(defun c:ea_EraLh (/ ss)
  (princ "\n选择范围[All - 全选].....")
  (setq ss (ssget '((-3 ("YB_LHBZ*")))))
  (if ss
    (vl-cmdf ".erase" ss "")
  (princ)
(defun c:ea_lhtj (/ ss ssobj lst l1 l2 ll1 ln $yb_global_scale)
  (ea:begin '("osmode" "celayer"))
  (setvar "osmode" 0)
  (setq ss (ssget '((-3 ("yb_lhbz")))))
  (setq $yb_global_scale (vlax-ldata-get "ea_sys_scale" "scale"))
  (if ss
    (progn
      (setq pt (getpoint "\n表格输出点: "))
      (setq ssobj (ea:selectionsetToArray ss))
      (setq lst    (mapcar
          '(lambda (x)
             (mapcar '(lambda (a) (vl-string-trim "," a))
                 (reverse (cdr (reverse (ea:GetAttributes x))))
          (vlax-safearray->list ssobj)
        l1    nil
      ;;按名称分类
      (foreach ll lst
    (setq ln (cadar ll)
          l2 l1
    (while (and (setq ll1 (car l2))
            (not (equal ln (cadar ll1)))
      (setq l2 (cdr l2))
    (setq l1 (if ll1
           (subst (append ll1 (list ll)) ll1 l1)
           (cons (list ln ll) l1)
  (ea:end)
  (princ)
)[/pcode]
配套DCL文件
  1. ea_lhbz : dialog {
  2.   label = " 绿化标注";
  3.   : row {
  4.     : column {
  5.       : boxed_column {
  6.         label = "植物名称";
  7.         : row {
  8.           : radio_button {
  9.             label = "乔木A";
  10.             key = "as";
  11.             mnemonic = "A";
  12.             }
  13.           : radio_button {
  14.             label = "灌木F";
  15.             key = "fs";
  16.             mnemonic = "F";
  17.             }
  18.         }
  19.         : list_box {
  20.           key = "what";
  21.           height = 14;
  22.           width = 18;
  23.           allow_accept = true; // 可双击鼠标选取
  24.           }
  25.         }
  26.       }
  27.     : column {
  28.       : boxed_column {
  29.         label = "植物" ;
  30.          : row {
  31.          : edit_box {
  32.             key = "name";
  33.             label = "名称";
  34.             fixed_width = true;
  35.             edit_width = 12;
  36.             width = 4;
  37.             }
  38.           : toggle {
  39.             key = "nn" ;
  40.             }}
  41.         : row {
  42.           : text {
  43.             label = "" ;
  44.             key   = "num_label";
  45.             width = 4;
  46.             }
  47.           : edit_box {
  48.             key = "num";
  49.             fixed_width = true;
  50.             edit_width = 12;
  51.             }
  52.           : toggle {
  53.             key = "aa" ;
  54.             }
  55.           }
  56.         : row {
  57.           : edit_box {
  58.             key = "sm";
  59.             label = "说明";
  60.             fixed_width = true;
  61.             edit_width = 12;
  62.             width = 4;
  63.             }
  64.           : toggle {
  65.             key = "ss" ;
  66.            }
  67.          }
  68.       }
  69.     : column {
  70.     : boxed_column {
  71.         label = "特性" ;
  72.         : row {
  73.           : edit_box {
  74.             key = "hig";
  75.             label = "高度";
  76.             fixed_width = true;
  77.             edit_width = 12;
  78.             width = 4;
  79.             }
  80.           : toggle {
  81.             key = "hh" ;
  82.            }
  83.           }
  84.         : row {
  85.           : edit_box {
  86.             key = "ro";
  87.             label = "冠幅";
  88.             fixed_width = true;
  89.             edit_width = 12;
  90.             width = 4;
  91.             }
  92.           : toggle {
  93.             key = "rr" ;
  94.             }
  95.           }
  96.         : row {
  97.           : text {
  98.             label = "" ; //可变
  99.             key   = "wih_label";
  100.              width = 4;
  101.             }
  102.           : edit_box {
  103.             key = "wih";
  104.             fixed_width = true;
  105.             edit_width = 12;
  106.             }
  107.           : toggle {
  108.             key = "ww" ;
  109.            }
  110.           }}
  111.        : row {
  112.          : toggle {
  113.            label = "  绘制引线P";
  114.            key = "pl" ;
  115.            mnemonic = "P";
  116.           }
  117.         }
  118.      }
  119.     }
  120.   }
  121.   ok_cancel_help;
  122. }
  123. ea_LhList : dialog {
  124.   label = " 统计查询 By Eachy";
  125.   : column {
  126.     : boxed_column {
  127.       label = "查询条件" ;
  128.       : row {
  129.         : edit_box {
  130.           key = "name";
  131.           label = "名称";
  132.           fixed_width = true;
  133.           edit_width = 15;
  134.           }
  135.         //: toggle {
  136.         //  key = "nn" ;
  137.         //  mnemonic = "n";
  138.         //  }
  139.       }
  140.       //: row {
  141.         //: edit_box {
  142.         //  key = "sm";
  143.         //  label = "说明";
  144.         //  fixed_width = true;
  145.         //  edit_width = 15;
  146.         //  }
  147.         //: toggle {
  148.         //  key = "ss" ;
  149.         //  mnemonic = "s";
  150.         //  }
  151.       //}
  152.       : button {
  153.         label = "拾取实体:<";
  154.         key = "pick";
  155.         }
  156.     }
  157.     : row {
  158.       : column {
  159.         : toggle {
  160.           label = "完全匹配A";
  161.           key = "all" ;
  162.           mnemonic = "A";
  163.           }
  164.         : toggle {
  165.           label = "全部统计T";
  166.           key = "tol" ;
  167.           mnemonic = "T";
  168.           }
  169.         }
  170.       : column {
  171.         : radio_button {
  172.           label = "输出表格E";
  173.           key = "excl" ;
  174.           mnemonic = "E";
  175.           }
  176.         : radio_button {
  177.           label = "屏幕显示S";
  178.           key = "scr" ;
  179.           mnemonic = "S";
  180.           }
  181.        }
  182.      }
  183.    }
  184.    ok_cancel;
  185. }
评分
参与人数 2D豆 +10 收起 理由
xshrimp + 5 很给力!经验;技术要点;资料分享奖!
牢固 + 5 很给力!经验;技术要点;资料分享奖!
查看全部评分
已领礼包: 51个
发表于 2013-5-27 12:11:21 | 显示全部楼层
有演示图片吗,副站长。
发表于 2013-6-9 17:11:25 | 显示全部楼层
如何使用?请说明一下
发表于 2013-7-2 21:48:29 | 显示全部楼层
园林插件论坛很少,不愧是佳作啊,谢谢,测试后收藏
发表于 2013-7-4 23:30:17 | 显示全部楼层
关注一下!留个印记……
发表于 2013-8-4 18:43:23 | 显示全部楼层
关注学习中,顶起
发表于 2013-8-6 21:52:54 | 显示全部楼层
不知道lisp程序在哪?
已领礼包: 363个
发表于 2013-10-24 11:41:58 | 显示全部楼层
那位把程序理一下,再传上来。:P
发表于 2014-11-14 21:49:04 | 显示全部楼层
正需要,谢谢楼主分享
发表于 2023-7-7 08:25:20 | 显示全部楼层
GMT+8, 2024-5-29 10:36 , Processed in 0.221574 second(s), 51 queries , Gzip On.
© 2001-2024 Discuz! Team.
