查看: 1084|回复: 0
[教学] API应用 快速休整Pline
已领礼包: 1268个
发表于 2013-12-8 11:03:21 | 显示全部楼层 |阅读模式
  1. (defun c:tt (/ p pts pl sp ep npl ptl nnpl)
  2.   (while (setq p (if pts
  3.                    (getpoint (car pts) "\nPoint: ")
  4.                    (getpoint "\nPoint: ")
  5.                  )
  6.          )
  7.     (setq pts (cons p pts))
  8.     (if        (> (length pts) 1)
  9.       (mapcar '(lambda (p1 p2) (grdraw p1 p2 1)) pts (cdr pts))
  10.     )
  11.   )
  12.   (if
  13.     (and pts
  14.          (setq
  15.            ss (xdrx_pickset_getatpoint (last pts) '((0 . "lwpolyline")))
  16.          )
  17.     )
  18.      (progn
  19.        (setq ptl  (list (car pts) (last pts))
  20.              pl          (ssname ss 0)
  21.              sp          (xdrx_curve_getparamatpoint pl (car ptl))
  22.              ep          (xdrx_curve_getparamatpoint pl (cadr ptl))
  23.              nnpl (xdrx_pickset->ents (xdrx_curve_getsplitcurves pl sp ep))
  24.        )
  25.        (if (vlax-curve-isclosed pl)
  26.          (xdrx_entity_delete
  27.            (car
  28.              (vl-sort
  29.                nnpl
  30.                '(lambda        (x1 x2)
  31.                   (< (cadr (xdrx_getarea x1)) (cadr (xdrx_getarea x2)))
  32.                 )
  33.              )
  34.            )
  35.          )
  36.          (mapcar '(lambda (x / info ppl)
  37.                     (setq info (xdrx_curve_getpoint x)
  38.                           ppl  (list (car info) (caddr info))
  39.                     )
  40.                     (if        (or (equal ppl ptl 1e-5)
  41.                             (equal ppl (reverse ptl) 1e-5)
  42.                         )
  43.                       (xdrx_entity_delete x)
  44.                     )
  45.                   )
  46.                  nnpl
  47.          )
  48.        )
  49.        (setq npl  (apply 'xdrx_polyline_make pts)
  50.              nnpl (vl-remove-if-not '(lambda (x) (entget x)) nnpl)
  51.        )
  52.        (vl-cmdf ".pedit" pl "j" npl)
  53.        (if nnpl
  54.          (foreach x nnpl (vl-cmdf x))
  55.        )
  56.        (vl-cmdf "")
  57.        (vl-cmdf "")
  58.      )
  59.   )
  60.   (princ)
  61. )
GMT+8, 2024-5-29 06:52 , Processed in 0.180055 second(s), 29 queries , Gzip On.
© 2001-2024 Discuz! Team.
