查看: 1769|回复: 0
[分享] Non-DWG window in AutoCAD 2015
已领礼包: 859个
发表于 2014-6-10 16:07:19 | 显示全部楼层 |阅读模式
Non-DWG window in AutoCAD 2015 using .NetBy Balaji Ramamoorthy
AutoCAD 2015 enables the creation of Non-DWG document window. The Non-DWG document window appears as a tab just as any other drawing window.
In this blog post, I have attached a C# project to create a Non-DWG document window and demonstrate its usage.
To try it :
1. Build the sample project using Visual Studio 2012 with .Net framework set to 4.5.
2. Start AutoCAD 2015 and netload the dll.
3. Run "MyWnd" command. This command creates a Non-DWG document window that accepts user input for the radius of a smiley.
4. Create another drawing and run the "InsertSmiley" command. This command creates a smiley based on the radius value provided in the Non-DWG document window.
Now, here is a brief description of the steps to create a Non-DWG document window using .Net :
Step-1. Create a WPF usercontrol and customize it as you would create it usually.
Step-2. Create a custom document class. This class will be used to hold the data that are specific to this document window.
Step-3. Create a custom document window class derived from WPFDocumentWindow.
- Override the "OnCreate" method to know when the document window is created.
- Override the "OnLoad" method to associate the custom document with our document window class
- Override the "OnActivate" method to know when the document window gets activated.
Step-4. Create an instance of the custom document window class and add it to the DocumentWindowCollection using Application.DocumentWindowCollection.AddDocumentWindow.
In the attached sample, the steps to associate a custom document have been commented. AutoCAD 2015 at present becomes unstable if a custom document is associated with the custom document window. This behavior has been logged in our internal database for our engineering team to analyze.
So the attached sample project retrieves the document data by directly accessing the usercontrol for the "InsertSmiley" command to access.
Here is the sample project :
Download NonDwgDocWindow_Net
GMT+8, 2024-6-9 05:03 , Processed in 0.234535 second(s), 35 queries , Gzip On.
© 2001-2024 Discuz! Team.
