查看: 1337|回复: 0
[每日一码] API应用 检查坐标
已领礼包: 1268个
发表于 2014-7-27 04:51:29 | 显示全部楼层 |阅读模式
校对一位老兄的总图,老同志只会一笔笔画,坐标是一根线一个字样的画出来,没办法不习惯用新东西,这样的图校对起来就非常麻烦,好在可以把标注筛选出来,而且绝大部分的单个标注中的实体是顺序生成的,于是花几分钟写了个校对程序
  1. (defun c:tt (/ ss lst nl)
  2.   (if (setq ss (ssget '((0 . "text,line"))))
  3.     (progn
  4.       (setq lst (xdrx_pickset->ents ss))
  5.       (while lst
  6.         (setq nl  (cons        (list (car lst)
  7.                               (cadr lst)
  8.                               (caddr lst)
  9.                               (cadddr lst)
  10.                         )
  11.                         nl
  12.                   )
  13.               lst (cddddr lst)
  14.         )
  15.       )
  16.       (mapcar
  17.         '(lambda (x / ln tn tl)
  18.            (setq ln (apply
  19.                       'append
  20.                       (mapcar
  21.                         '(lambda (b)
  22.                            (mapcar
  23.                              '(lambda (c)
  24.                                 (mapcar        '(lambda (d)
  25.                                            (rtos d 2 3)
  26.                                          )
  27.                                         c
  28.                                 )
  29.                               )
  30.                              (list
  31.                                (cdr
  32.                                  (reverse (vlax-curve-getstartpoint b))
  33.                                )
  34.                                (cdr (reverse (vlax-curve-getendpoint b))
  35.                                )
  36.                              )
  37.                            )
  38.                          )
  39.                         (vl-remove-if
  40.                           '(lambda (a)
  41.                              (/= (xdrx_getpropertyvalue a "IsA")
  42.                                  "AcDbLine"
  43.                              )
  44.                            )
  45.                           x
  46.                         )
  47.                       )
  48.                     )
  49.                  tn (mapcar '(lambda (c)
  50.                                (vl-string-trim "XY= " c)
  51.                              )
  52.                             (acad_strlsort
  53.                               (mapcar
  54.                                 '(lambda (b)
  55.                                    (xdrx_getpropertyvalue b "Textstring")
  56.                                  )
  57.                                 (setq
  58.                                   tl (vl-remove-if
  59.                                        '(lambda        (a)
  60.                                           (/= (xdrx_getpropertyvalue a "IsA")
  61.                                               "AcDbText"
  62.                                           )
  63.                                         )
  64.                                        x
  65.                                      )
  66.                                 )
  67.                               )
  68.                             )
  69.                     )
  70.            )
  71.            (if (not (member tn ln))
  72.              (mapcar '(lambda (a)
  73.                         (xdrx_entity_setcolor a 7)
  74.                       )
  75.                      tl
  76.              )
  77.              (mapcar '(lambda (a)
  78.                         (xdrx_entity_setcolor a 1)
  79.                       )
  80.                      tl
  81.              )
  82.            )
  83.          )
  84.         nl
  85.       )
  86.     )
  87.   )
  88.   (princ)
  89. )
GMT+8, 2024-5-29 09:38 , Processed in 0.306873 second(s), 28 queries , Gzip On.
© 2001-2024 Discuz! Team.
