查看: 2160|回复: 3
[求助] 批量替换对应文本,如何加入功能“完全匹配”、“指定图层” 大家都来帮帮忙吧
发表于 2014-8-19 09:15:16 | 显示全部楼层 |阅读模式
  1. '打开文件
  2.   Private Declare Function ShellExecute Lib "shell32.dll" Alias "ShellExecuteA" (ByVal hwnd As Long, ByVal lpOperation As String, ByVal lpFile As String, ByVal lpParameters As String, ByVal lpDirectory As String, ByVal nShowCmd As Long) As Long
  3. Private Const SW_SHOW = 5
  4. '-------------------切换线程-------------
  5. Private Declare Function GetWindowThreadProcessId Lib "user32" _
  6.     (ByVal hwnd As Long, lpdwProcessId As Long) As Long
  7. Private Declare Function AttachThreadInput Lib "user32" _
  8.     (ByVal idAttach As Long, ByVal idAttachTo As Long, ByVal fAttach As Long) As Long
  9. Private Declare Function GetForegroundWindow Lib "user32" () As Long
  10. Private Declare Function SetForegroundWindow Lib "user32" (ByVal hwnd As Long) As Long
  11. Private Declare Function IsIconic Lib "user32" (ByVal hwnd As Long) As Long
  12. Private Declare Function ShowWindow Lib "user32" _
  13.     (ByVal hwnd As Long, ByVal nCmdShow As Long) As Long
  14. 'Private Const SW_SHOW = 5  '与打开文件里面的重复了,这里取消
  15. Private Const SW_RESTORE = 9
  16. '-------------------切换线程-------------
  17. Sub 批量替换()
  18. Dim i As Integer
  19. On Error Resume Next
  20.   FileCopy ThisDrawing.Path & "\PiLiangTiHuan.dll", "C:\WINDOWS\system32\PiLiangTiHuan.dll"
  21.   Shell "regsvr32   /s   PiLiangTiHuan.dll"
  22.
  23.    Err.Clear
  24.
  25.    Dim xlApp As Object, xlSheet As Object
  26.
  27.
  28.    Set xlApp = GetObject(, "Excel.Application")
  29.
  30.    If Err Then
  31.      Err.Clear
  32.     Set xlApp = GetObject(, "ET.Application")
  33.
  34.      End If
  35.
  36.     If Err Then
  37.        Err.Clear
  38.
  39.       ShellExecute Me.hwnd, "open", ThisDrawing.Path & "\TT_AutoCAD文字自动替代.xls", vbNullString, vbNullString, SW_SHOW
  40.       GoTo QueDingSheet
  41.
  42.     End If
  43.
  44.     If xlApp.Workbooks.Count > 0 Then
  45.     For i = 1 To xlApp.Workbooks.Count
  46.
  47.
  48.         If InStr(xlApp.Workbooks(i).Name, "TT_AutoCAD文字自动替代") > 0 Then
  49.           Set xlSheet = xlApp.Workbooks(i).ActiveSheet
  50.           GoTo QueDingSheet
  51.
  52.         End If
  53.      Next
  54.
  55.     End If
  56.
  57.     Err.Clear
  58.
  59.     ShellExecute Me.hwnd, "open", ThisDrawing.Path & "\TT_AutoCAD文字自动替代.xls", vbNullString, vbNullString, SW_SHOW
  60.
  61.
  62. QueDingSheet:
  63.
  64.
  65.
  66.     ForceForegroundWindow Application.hwnd
  67.
  68.    Dim objForm As Object      ' New PiLiangTiHuan.TiHuan
  69.
  70.    Set objForm = CreateObject("PiLiangTiHuan.TiHuan")
  71.     Set objForm.Application = Application
  72.
  73.     DoEvents
  74.
  75.     objForm.ShowFormMain
  76.
  77.   Err.Clear
  78.
  79. End Sub
  80. Private Sub AcadDocument_Activate()
  81.   On Error Resume Next
  82. FileCopy ThisDrawing.Path & "\PiLiangTiHuan.dll", "C:\WINDOWS\system32\PiLiangTiHuan.dll"
  83.   Shell "regsvr32   /s   PiLiangTiHuan.dll"
  84.
  85.    Err.Clear
  86.   批量替换
  87. End Sub
  88. Public Function ForceForegroundWindow(ByVal hwnd As Long) As Boolean
  89.    Dim ThreadID1 As Long    ' 线程ID
  90.    Dim ThreadID2 As Long    ' 线程ID
  91.    Dim nRet As Long
  92.
  93.    ' 如果指定的窗体已经在前台,不做任何操作
  94.    If hwnd = GetForegroundWindow() Then
  95.       ForceForegroundWindow = True
  96.    Else
  97.       ' 首先获得指定窗体相关的线程和当前前台窗口所在的线程
  98.       ThreadID1 = GetWindowThreadProcessId(GetForegroundWindow, ByVal 0&)
  99.       ThreadID2 = GetWindowThreadProcessId(hwnd, ByVal 0&)
  100.
  101.       ' 通过共享输入状态,两个线程分享当前窗口
  102.       If ThreadID1 <> ThreadID2 Then
  103.          Call AttachThreadInput(ThreadID1, ThreadID2, True)
  104.          nRet = SetForegroundWindow(hwnd)
  105.          Call AttachThreadInput(ThreadID1, ThreadID2, False)
  106.       Else
  107.          nRet = SetForegroundWindow(hwnd)
  108.       End If
  109.
  110.       ' 恢复和重画
  111.       If IsIconic(hwnd) Then
  112.          Call ShowWindow(hwnd, SW_RESTORE)
  113.       Else
  114.          Call ShowWindow(hwnd, SW_SHOW)
  115.       End If
  116.
  117.       ' 精确地返回函数执行结果
  118.       ForceForegroundWindow = CBool(nRet)
  119.    End If
  120. End Function
  121. 'Private Sub AcadDocument_EndCommand(ByVal CommandName As String)
  122.
  123. '  On Error GoTo errhand
  124.
  125. 'If CommandName = "VBALOAD" Or CommandName = "VBAMAN" Or CommandName = "APPLOAD" Or CommandName = "COMMANDLINE" Then
  126. '   Dim objForm As New PiLiangTiHuan.TiHuan
  127. '   Set objForm.Application = Application
  128. '   objForm.ShowFormMain
  129. 'End If
  130. 'errhand:
  131. 'If Err.Number = 0 Then
  132. ' Else
  133.
  134.   '  MsgBox Err.Description & Err.Number
  135.
  136.   '  Err.Clear
  137.
  138. 'End If
  139. 'End Sub
  140. Private Sub AcadDocument_BeginDoubleClick(ByVal PickPoint As Variant)
  141.   批量替换
  142. End Sub
已领礼包: 859个
发表于 2014-8-19 09:33:14 来自手机 | 显示全部楼层
回帖奖励 +1 D豆
高大上程序,牛刀很厉害
发表于 2014-8-19 15:25:27 | 显示全部楼层
这是求助,还是分享?
求助 希望加入“完全匹配”和”指定图层“的过滤条件  详情 回复 发表于 2014-8-20 20:11
 楼主| 发表于 2014-8-20 20:11:00 | 显示全部楼层
newer 发表于 2014-8-19 15:25
这是求助,还是分享?
GMT+8, 2024-5-30 00:08 , Processed in 0.265245 second(s), 38 queries , Gzip On.
© 2001-2024 Discuz! Team.
