查看: 1157|回复: 4
[分享] dcl_SlideView_VectorImage初始化时显示VectorImage
发表于 2014-12-31 16:28:11 | 显示全部楼层 |阅读模式
  1. (defun c:testsld  (/ dcl dclid)
  2.   (setq dcl '("YWt6AyoGAACUEdccBuIL7TUx7T9q+KHxygpSZGxsGr249rTYegS9xOvmVrZL7zY2dspbX58c0m+d"
  3.         "uNsJo5f44d7ed5Tga5CCf4J+fNxB/jUHGSTAl4lYMkyNsw2w502ZBRnYywQse4Wbf6K8SjiOdhtS"
  4.         "HX7JTzoAPNQO0h5vW4oO0k78j/fWWX6OWX8inqnExZjvPUGFM7Jfs0/7QPB7LHQnsPTmmRLoqCCa"
  5.         "40kxEfA3rSLpOfjoYlPQwtSz5t9Ts8sHpBmnLbIrGjqoG1LN9vLNa5aTm9K6tgCwtfI0RRXh1dp3"
  6.         "U0jX0+b31Zb+dxbSScScCc78uSYcwqc4pefZYBy4bz09TVEiVKkI57HS38fw/6O5YnVBaxCNldEN"
  7.         "cc1dgKt2CWgHMC+TGZ514J93UJ1QhXyDdYKXO/CxZxEAhwMio0H6AXQRdGE0I7H65f1WYQfjElyN"
  8.         "bPcuGtWtqw07oTzCH1+ykTZaMgkqTwniY/poFbeUD1hZ4nhbFI7+oUwosUemWOaOGWVwC7FoZXU1"
  9.         "DJ8YuoVjIWxPnFy4O48B7TWKI7qk7oYLn9G8Ifrt7DFbE8YK44isA+yGKewRMAYsxqOZzWXnL7Ep"
  10.         "EoBX9wFWgieG3Y55n4m8kfqhdMFvAFNCmJUzpITZuwFslG1GA4AHCARg+inQaMFRKYgB5sFogUkC"
  11.         "ckuQ7IupOrEfrw0uYJnujgOfBbyE2hC2hwk5kfkT2bitjGY="))
  12.   (command "opendcl")
  13.   (setq dclid (dcl_project_import dcl))
  14.   (dcl_Form_Show dclid "Form1")
  15.   (princ)
  16.   )
  17. (defun c:testsld_Form1_OnInitialize ()
  18.   (if (dcl_Form_Show dclid "Form1")
  19.     (progn
  20.       (dcl_SlideView_VectorImage testsld_Form1_SlideView1 (mode1_up_vectors))
  21.       (dcl_SlideView_EndImage testsld_Form1_SlideView1)
  22.       )
  23.     )
  24. )
  25. (defun mode1_up_vectors ()
  26.   (mapcar 'list
  27.       (list 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 13 18 22 27 31 36 40 45 49 54 58 63 67 72 76 81 85 90 10 10 10 27  8  8 93  8 90 10 8 10  8 15  8 19  8 24  8 28  8 33  8 37  8 42  8 46  8 51  8 55  8 60  8 64  8 69  8 73  8 78  8 82  8 87  8 90  9 90 13 90 18 90 22 90 27 90 31 90 36 90 40 90 44 90 49 90 53 90 58 90 62 90 67 90 71 90 76 90 80 90 85 89)
  28.       (list 88 83 79 74 70 65 61 56 52 47 43 38 34 29 25 20 16 11 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 90 28  8  8  8 93 10 90 8 10 13 10 17 10 22 10 26 10 31 10 35 10 40 10 44 10 49 10 53 10 58 10 62 10 67 10 71 10 76 10 80 10 85 10 89 11 93 16 93 20 93 25 93 29 93 34 93 38 93 43 93 47 93 51 93 56 93 60 93 65 93 69 93 74 93 78 93 83 93 87 93 93)
  29.       (list 11 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 30 34 37 41 44 48 51 55 58 62 65 69 72 76 79 83 86 90 90 10 27 90  8 93 93 93 90 90 8 13 10 17 10 22 10 26 10 31 10 35 10 40 10 44 10 49 10 53 10 58 10 62 10 67 10 71 10 76 10 80 10 85 10 89 10 93 11 93 16 93 20 93 25 93 29 93 34 93 38 93 43 93 47 93 51 93 56 93 60 93 65 93 69 93 74 93 78 93 83 93 87 93)
  30.       (list 88 85 81 77 74 70 67 63 60 56 53 49 46 42 38 35 31 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 10 90 28 10 93  8 93 93 90 90 8  8 10  8 15  8 19  8 24  8 28  8 33  8 37  8 42  8 46  8 51  8 55  8 60  8 64  8 69  8 73  8 78  8 82  8 87  9 90 13 90 18 90 22 90 27 90 31 90 36 90 40 90 44 90 49 90 53 90 58 90 62 90 67 90 71 90 76 90 80 90 85 90 89)
  31.       (list  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6 6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6  6)
  32.       )
  33.   );defun
效果图
效果图
testsld1.LSP
3.11 KB, 下载次数: 11
测试程序
 楼主| 发表于 2014-12-31 16:32:14 | 显示全部楼层
做这个测试程序得到newer的帮助,非常感谢。要达到初始化显示VectorImage,最重要是对话框先显示出来。
已领礼包: 1268个
发表于 2014-12-31 17:37:27 | 显示全部楼层
ODCL 的所有控件都要显示出来时才可以操作
 楼主| 发表于 2014-12-31 18:06:51 | 显示全部楼层
没错,这步要放在最后。
已领礼包: 1268个
发表于 2014-12-31 18:25:48 来自手机 | 显示全部楼层
海天风云 发表于 2014-12-31 18:06
没错,这步要放在最后。
初始化无需判断show,OnInitlized只有在显示的时候执行
GMT+8, 2024-5-29 13:40 , Processed in 0.180239 second(s), 38 queries , Gzip On.
© 2001-2024 Discuz! Team.
