查看: 663|回复: 0
[教学] API应用 Insert内实体的框选操作
已领礼包: 1268个
发表于 2016-2-23 17:35:46 | 显示全部楼层 |阅读模式
  1. (defun c:tt (/ p1 p2 ss lst s)
  2.   (if (and (setq p1 (getpoint "\nFirset Corner: "))
  3.            (setq p2 (getcorner p1 "\nOrther Corner: "))
  4.            (setq ss (ssget "C" p1 p2 '((0 . "insert"))))
  5.       )
  6.     (progn
  7.       (setq lst
  8.              (mapcar '(lambda (x / l ll)
  9.                         (setq l         (xdrx_getpropertyvalue
  10.                                    x
  11.                                    "BlockTableRecord"
  12.                                    "BlockTransform"
  13.                                  );_获取块定义和 Insert 的变换矩阵
  14.                               ll (vl-remove-if
  15.                                    '(lambda (a)
  16.                                       (and
  17.                                         (/=
  18.                                           (xdrx_getpropertyvalue
  19.                                             a
  20.                                             "IsA"
  21.                                           )
  22.                                           "AcDbText"
  23.                                         );_判断是否是需要类型
  24.                                         (not
  25.                                           (apply
  26.                                             'xdrx_point_isinside
  27.                                             (list
  28.                                               (xdrx_point_transform
  29.                                                 (xdrx_getpropertyvalue
  30.                                                   a
  31.                                                   "Position"
  32.                                                 )
  33.                                                 p1
  34.                                                 p2
  35.                                               )
  36.                                             )
  37.                                           );_条件筛选
  38.                                         )
  39.                                       )
  40.                                     )
  41.                                    (xdrx_getpropertyvalue
  42.                                      (cadar l)
  43.                                      "allEntities"
  44.                                    );_块定义内所有实体
  45.                                  )
  46.                         )
  47.                         (if ll
  48.                           (progn
  49.                             (xdrx_entity_setcolor
  50.                               (xdrx_entity_transformedcopy ll (cadr l));_将符合条件的实体复制一份到模型空间,注意有些实体不支持非等比矩阵变换
  51.                               1
  52.                             )
  53.                           )
  54.                         )
  55.                       )
  56.                      (xdrx_pickset->ents ss)
  57.              )
  58.       )
  59.     )
  60.   )
  61.   (princ)
  62. )
GMT+8, 2024-5-29 07:50 , Processed in 0.212129 second(s), 29 queries , Gzip On.
© 2001-2024 Discuz! Team.
