查看: 2160|回复: 4
[每日一码] Converting unsupported variant data types for use by visual LISP
发表于 2016-5-12 16:50:57 | 显示全部楼层 |阅读模式
Question
My database field contains a Variant, which has ActiveX VarType as vbDate. For
example, the constant value is 14. How do I use the actual data value returned
from my database function ?
Answer
AutoLISP does not support all the Variant Data types made available to it though
the ActiveX COM inte**ce. For purposes of this solution, AutoLISP only supports
the following traditional types:
AutoLISP Reference -> type
Data type         Description
ENAME             Entity names
INT                   Integers
REAL                Floating-point numbers
STR                  Strings
SYM                  Symbols
In addition, AutoLISP supports these new data types for AutoCAD 2000:
SAFEARRAY       Safearray
VARIANT          Variant
VLA-object       ActiveX objects
(Please note that there are additional AutoLISP types listed in the
documentation.)
Several functions have been added to Visual Lisp for AutoCAD 2000 that will
assist you in converting from the Variant Data Type returned by ActiveX to
standard AutoLISP data types:
SAFEARRAY:
            (vlax-make-safearray type '(l-bound . u-bound)
            (vlax-safearray-fill var 'element-values)
            (vlax-safearray-get-dim var)
            (vlax-safearray-get-element var element...)
            (vlax-safearray-get-l-bound var dim)
            (vlax-safearray-get-u-bound var dim)
            (vlax-safearray-put-element var index... value)
            (vlax-safearray-type var)
            (vlax-safearray->list var)
VARIANT:
            (vlax-make-variant [value] [type])
            (vlax-variant-change-type var type)
            (vlax-variant-type var)
            (vlax-variant-value var)
VLA-object:
            (vlax-ename->vla-object entname)
            (vlax-vla-object->ename obj)
To convert from a Variant Data value, you could use a genericLISP function as in
the following code that  handles several variant data types, and converts the
variants into strings:
游客,如果您要查看本帖隐藏内容请回复
The vlax-vbDate variant type is not a supported AutoLISP data type, but the code
converts the variant value directly into a string.
For more information on this topic, refer to the following sections of the
documentation:
Visual Lisp Developer's Guide -> Chapter 6 -- Working with ActiveX -> Using
Visual LISP Functions with ActiveX Methods -> Converting AutoLISP Data Types to
ActiveX Data Types -> Working with Variants
ActiveX Data Types -> Converting Other AutoLISP Data Types for ActiveX Methods
See DevNote #53398 for additional AutoLISP code that demonstrates the
supported Variant Data Types and their values.
);odtoxd
评分
参与人数 1D豆 +10 收起 理由
/db_自贡黄明儒_ + 10 很给力!经验;技术要点;资料分享奖!
查看全部评分
已领礼包: 604个
发表于 2016-5-12 19:12:24 来自手机 | 显示全部楼层
看起来费劲呀。。。
已领礼包: 5589个
发表于 2016-5-13 07:57:31 | 显示全部楼层
回复,向版主学习
已领礼包: 216个
发表于 2020-1-19 15:35:00 | 显示全部楼层
向版主学习
发表于 2023-11-3 20:21:13 | 显示全部楼层
666666666666
GMT+8, 2024-5-15 03:09 , Processed in 0.302346 second(s), 41 queries , Gzip On.
© 2001-2024 Discuz! Team.
