查看: 2411|回复: 20
[每日一码] ARX常用代码总结
已领礼包: 13个
发表于 2016-10-24 16:11:29 | 显示全部楼层 |阅读模式
////将图形加载显示到CAD===================
static AcDbObjectId LoadEntity(AcDbEntity* entity){
        AcDbBlockTable* pBlockTable;
        acdbHostApplicationServices()->workingDatabase()->getBlockTable(pBlockTable,AcDb::kForRead);
        AcDbBlockTableRecord* pBlockTableRecord;
        pBlockTable->getAt(ACDB_MODEL_SPACE,pBlockTableRecord,AcDb::kForWrite);
        AcDbObjectId Id;
        pBlockTableRecord->appendAcDbEntity(Id,entity);
        pBlockTable->close();
        pBlockTableRecord->close();
        entity->close();
        return Id;
////为图形添加标注
static void AddOrdinate(AcGePoint3d ptStart,AcGePoint3d ptEnd,
                                                CString text)
        AcDbOrdinateDimension* pDim = new
                AcDbOrdinateDimension(true,ptStart,ptEnd,text);
        LoadEntity(pDim);
////画线====================
static void TESTlineCmd()
        //acutPrintf(_T("\nHello"));
        ads_point inputStart;
        ads_point inputEnd;
        AcGePoint3d ptStart;
        AcGePoint3d ptEnd;
        ////用户输入要画的坐标
        if(acedGetPoint(NULL,_T("start point"),inputStart) != RTNORM){
                return;
        ptStart[X] = inputStart[X];
        ptStart[Y] = inputStart[Y];
        ptStart[Z] = inputStart[Z];
        if(acedGetPoint(NULL,_T("end point"),inputEnd) != RTNORM){
                return;
        ptEnd[X] = inputEnd[X];
        ptEnd[Y] = inputEnd[Y];
        ptEnd[Z] = inputEnd[Z];
        AcDbLine* pLine = new AcDbLine(ptStart,ptEnd);
        pLine->setColorIndex(2);
        LoadEntity(pLine);
        AddOrdinate(ptStart,ptEnd,_T("hi"));
        //AfxMessageBox(_T("命令画了一条线"));
////画圆形==========================
static void TESTcirclecmd(){
        ////垂直平面法向量
        AcGeVector3d vec(0,0,1);
        ////圆心
        AcGePoint3d ptCenter(100,100,100);
        AcDbCircle* pCircle = new AcDbCircle(ptCenter,vec,1000);
        LoadEntity(pCircle);
////画圆弧================================
static void TESTarccmd(){
        AcGePoint3d ptCenter(500,500,500);
        AcDbArc* pArc = new AcDbArc(ptCenter,vec,700,0,90);
        LoadEntity(pArc);
////画多线段============================
static void TESTpolycmd(){
        ////构造多点数组
        AcGePoint2dArray points;
        AcGePoint2d pt1(1000, 1000);
        AcGePoint2d pt2(2000, 1800);
        AcGePoint2d pt3(500, 2000);
        AcGePoint2d pt4(3000, 5000);
        points.append(pt1);
        points.append(pt2);
        points.append(pt3);
        points.append(pt4);
        ////绘制多点线段
        AcDbPolyline* pl = new AcDbPolyline(points.length());
        for(int i = 0;i < points.length();i ++){
                pl->addVertexAt(i,points.at(i),0,0.5,0.5);
        LoadEntity(pl);
////绘制POLY3d线段====================
static void TESTpoly3dcmd(){
        ////构造多点数组
        AcGePoint3dArray points;
        AcGePoint3d pt1(10, 10,10);
        AcGePoint3d pt2(20, 10,20);
        AcGePoint3d pt3(20, 20,30);
        points.append(pt1);
        points.append(pt2);
        points.append(pt3);
        ////绘制多点线段
        AcDb3dPolyline* pl = new AcDb3dPolyline(AcDb::Poly3dType::k3dSimplePoly,points);
        LoadEntity(pl);
////绘制椭圆=========================
static void TESTellipsecmd(){
        ////椭圆焦点
        /* AcGePoint2d p1(400,400);
        AcGePoint2d p2(800,400);*/
        ////中心点
        AcGePoint3d ptCenter(600,400,0);
        AcGeVector3d vecNormal(0,0,1);
        ////长轴
        AcGeVector3d majorAxis(1000,0,0);
        ////通过曲率确定短轴长度
        double ratio = 0.6;
        AcDbEllipse* ae = new AcDbEllipse(/*AcGePoint3d::kOrigin*/ptCenter,vecNormal,majorAxis,
                ratio);
        LoadEntity(ae);
////创建样条曲线================
static void TESTsplinecmd(){
        AcGePoint3d p1(0,0,0),p2(200,600,0),p3(1200,1600,0),
                p4(2000,2000,0);
        points.append(p1);
        points.append(p2);
        points.append(p3);
        points.append(p4);
        AcDbSpline* as = new AcDbSpline(points);
        LoadEntity(as);
////创建面域(把用直线创建的闭合图形,生成一个图形的对象)
static void TESTregioncmd(){
        ads_name ss;
        ////提示用户选择对象
        int rt = acedSSGet(NULL,NULL,NULL,NULL,ss);
        AcDbObjectIdArray ids;
        if(rt == RTNORM){
                long len;
                ////获得对象个数
                acedSSLength(ss,&len);
                for(int i = 0;i < len;i ++){
                        ////先从对象中得到名字
                        ads_name ent;
                        acedSSName(ss,i,ent);
                        ////再从名字中取出ID
                        AcDbObjectId objId;
                        acdbGetObjectId(objId,ent);
                        ids.append(objId);
        acedSSFree(ss);
        ////得到objId数组之后,开始画区域
        CreateRegion(ids);
////绘制面域
static AcDbObjectIdArray  CreateRegion(AcDbObjectIdArray ids){
        AcDbObjectIdArray regionIds;
        AcDbVoidPtrArray curves;
        AcDbVoidPtrArray regions;
        AcDbEntity* pEnt;
        AcDbRegion* pRegion;
        for(int i = 0;i < ids.length();i ++){
                acdbOpenAcDbEntity(pEnt,ids.at(i),AcDb::kForRead);
                if(pEnt->isKindOf(AcDbCurve::desc())){
                        curves.append(static_cast<void*>(pEnt));
        Acad::ErrorStatus es = AcDbRegion::createFromCurves(curves,regions);
        if(es == Acad::eOk){
                for(int i = 0;i < regions.length();i ++){
                        pRegion = static_cast<AcDbRegion*>(regions[i]);
                        pRegion->setDatabaseDefaults();
                        AcDbObjectId regionId = LoadEntity(pRegion);
                        regionIds.append(regionId);
                CString tipStr ;
                tipStr.Format(_T("\n已成功创建面域:%d个"),regions.length());
                acutPrintf(tipStr);
        else{
                        delete (AcRxObject*)regions[i];
                pEnt = static_cast<AcDbEntity*>(curves[i]);
                pEnt->close();
        return regionIds;
//绘制文字===================
static void TESTtextcmd(){
        AcGePoint3d ptInsert(0,400,0);
        AcDbMText* pMText = new AcDbMText();
        ////设置多行文字特性
        pMText->setContents(_T("hello!!"));
        pMText->setLocation(ptInsert);
        pMText->setTextHeight(1000);
        pMText->setWidth(1000);
        pMText->setAttachment(AcDbMText::kBottomLeft);
        LoadEntity(pMText);
[it618postdisplay>0]
////创建填充======================
static void TESThatchcmd(){
        ////提示用户选择填充边界
        ads_name ss;
        AcDbObjectIdArray objIds;
        if(rt == RTNORM){
                long len;
                        ads_name ent;
                        AcDbObjectId objId;
                        objIds.append(objId);
        acedSSFree(ss);
        ////选择完毕,绘制填充
        Acad::ErrorStatus es;
        AcDbHatch* pHatch = new AcDbHatch();
        ////选择填充平面
        AcGeVector3d normal(0,0,1);
        pHatch->setNormal(normal);
        pHatch->setElevation(0);
        ////设置关联性
        pHatch->setAssociative(true);
        ////设置填充图案
        pHatch->setPattern(AcDbHatch::kPreDefined,_T(/*"SOLID"*/"ANSI31"));
        ////设置填充角度
        pHatch->setPatternAngle(45);
        ////设置填充边界
        es=pHatch->appendLoop(AcDbHatch::kExternal,objIds);
        ////显示填充对象
        es=pHatch->evaluateHatch();
        LoadEntity(pHatch);
[/it618postdisplay]
//获得一层的所有对象,变色===============
static void TESTgetlayerobjcmd(){
        AcDbLayerTable *pLayerTbl;
        acdbHostApplicationServices()->workingDatabase()->getSymbolTable(
                pLayerTbl,AcDb::kForRead);
        if(!pLayerTbl->has(_T("测试"))){
                acutPrintf(_T("\n当前图形未包含'测试'图层"));
                pLayerTbl->close();
                return;
        AcDbObjectId layerId;
        pLayerTbl->getAt(_T("测试"),layerId);
        pLayerTbl->close();
        ////获得当前数据库的块表
        AcDbBlockTable* pBlkTbl;
                pBlkTbl,AcDb::kForRead);
        ////获得模型空间的块表记录
        AcDbBlockTableRecord* pBlkTblRcd;
        pBlkTbl->getAt(ACDB_MODEL_SPACE,pBlkTblRcd,AcDb::kForRead);
        pBlkTbl->close();
        ////创建块表记录遍历器
        AcDbBlockTableRecordIterator* pIter;
        pBlkTblRcd->newIterator(pIter);
        AcDbEntity* pEnt;
        for(pIter->start();!pIter->done();pIter->step()){
                pIter->getEntity(pEnt,AcDb::kForWrite);
                if(pEnt->layerId() == layerId){
                        /*AcDbLine* pLine = AcDbLine::cast(pEnt);
                        if(pLine != NULL){*/
                        pEnt->setColorIndex(1);
                pEnt->close();
        delete pIter;
        pBlkTblRcd->close();
已领礼包: 769个
发表于 2016-10-24 18:05:25 | 显示全部楼层
回的人少,我来小顶一下
发表于 2016-11-28 17:21:24 | 显示全部楼层
正需要,支持楼主大人了!适合初学的内容,支持
已领礼包: 187个
发表于 2016-12-6 16:01:05 | 显示全部楼层
努力学习代码
发表于 2016-12-7 16:35:19 | 显示全部楼层
顶 好东西 灰常感谢
发表于 2017-3-19 08:52:38 | 显示全部楼层
收藏备用 谢谢
发表于 2017-9-6 14:48:09 | 显示全部楼层
非常感谢楼主
发表于 2017-9-6 16:37:18 | 显示全部楼层
学习学习学习学习
已领礼包: 2409个
发表于 2017-9-9 21:45:31 | 显示全部楼层
学习!!!!!!!!!!!!!!!!!!
发表于 2017-9-15 14:16:42 | 显示全部楼层
非常感谢楼主
发表于 2017-12-22 15:57:24 | 显示全部楼层
谢谢分享,会分享的人都好人啊 !!!!
已领礼包: 33个
发表于 2017-12-28 19:14:34 | 显示全部楼层
看看看看看看看看看看
发表于 2018-1-1 19:48:59 | 显示全部楼层
学习学习,学习学习
发表于 2018-1-11 08:46:49 | 显示全部楼层
常用的基本都在这了
发表于 2018-1-30 15:32:01 | 显示全部楼层
学习学习。。。
GMT+8, 2024-5-29 15:01 , Processed in 0.425880 second(s), 55 queries , Gzip On.
© 2001-2024 Discuz! Team.
