查看: 981|回复: 0
[每日一码] 关闭包括当前文档在内的所有文档
已领礼包: 13个
发表于 2016-12-25 08:15:00 | 显示全部楼层 |阅读模式
By Balaji Ramamoorthy
The sample code closes all documents, including the current one by first closing all documents except the current one in the document context. The current document is then closed from the application context using the executeInApplicationContext API. This allows the current document to be closed from the same command which is running in the document context.
// Close the other documents
AcApDocumentIterator *Iter
                    = acDocManager->newAcApDocumentIterator();
while(!Iter->done())
    if (Iter->document()!=acDocManager->curDocument())
        acDocManager->closeDocument(Iter->document());
    Iter->step();
delete Iter;
// Now close the current document
::acDocManagerPtr()->appContextCloseDocument(acDocManager->curDocument());
GMT+8, 2024-5-24 05:14 , Processed in 0.165122 second(s), 32 queries , Gzip On.
© 2001-2024 Discuz! Team.
