查看: 675|回复: 2
[分享] 旋转卡壳法求点集的最小覆盖矩形面积以及周长
发表于 2017-1-21 01:28:00 | 显示全部楼层 |阅读模式
#include"string.h"
#include"stdio.h"
#include"math.h"
#include"stdlib.h"
#define M 100009
#define inf 999999999
#define eps 1e-10
typedef struct node
    double x,y,cos,dis;
}E;
E p[M],q[M],pp[M];
double max(double a,double b)
    return a>b?a:b;
double min(double a,double b)
    return a<b?a:b;
int cmp(const void *a,const void *b)
    if(fabs((*(struct node*)a).cos-(*(struct node*)b).cos)<eps)
        return (*(struct node*)a).dis>(*(struct node*)b).dis?1:-1;
    else
        return (*(struct node*)b).cos>(*(struct node*)a).cos?1:-1;
double angle(node p1,node p2)
    double x1=p2.x-p1.x;
    double y1=p2.y-p1.y;
    double x2=1;
    double y2=0;
    return (x1*x2+y1*y2)/sqrt((x1*x1+y1*y1)*(x2*x2+y2*y2));
double pow(double x)
    return x*x;
double Len(node p1,node p2)
    return pow(p2.x-p1.x)+pow(p2.y-p1.y);
double cross(node p0,node p1,node p2)//叉积
    double x1=p1.x-p0.x;
    double y1=p1.y-p0.y;
    double x2=p2.x-p0.x;
    double y2=p2.y-p0.y;
    return x1*y2-x2*y1;
double dot(node p0,node p1,node p2)//点积
    double x2=p2.x-p1.x;
    double y2=p2.y-p1.y;
    return x1*x2+y1*y2;
int main()
    int n,i,j;
    while(scanf("%d",&n),n)
        int tep;
        E start;
        start.x=start.y=inf;
        for(i=0;i<n;i++)
            scanf("%lf%lf",&p[i].x,&p[i].y);
            if(p[i].y<start.y)
                start=p[i];
                tep=i;
            else if(fabs(p[i].y-start.y)<eps)
                if(p[i].x<start.x)
                    start=p[i];
                    tep=i;
        p[tep].dis=0;
        p[tep].cos=1.0;
        for(i=0;i<n;i++)
            if(i!=tep)
                if(fabs(p[i].x-start.x)<eps&&fabs(p[i].y-start.y)<eps)
                    p[i].dis=0;
                    p[i].cos=1.0;
                else
                    p[i].cos=angle(start,p[i]);
                    p[i].dis=Len(start,p[i]);
        qsort(p,n,sizeof(p[0]),cmp);//按极角进行快排
        int tt=0;
        for(i=0;i<n;i++)//除重点
            if(fabs(p[i].dis-p[(i+1)%n].dis)>eps||fabs(p[i].cos-p[(i+1)%n].cos)>eps)
                pp[tt++]=p[i];
        if(tt==0)
            printf("0.00 0.00\n");
            continue;
        if(tt==2)
            printf("%.2lf %.2lf\n",0.0,2*sqrt(Len(pp[0],pp[1])));
            continue;
        q[0]=pp[tt-1];
        q[1]=pp[0];
        q[2]=pp[1];
        int cnt=2;
        for(i=2;i<tt;i++)
            while(cross(q[cnt-1],q[cnt],pp[i])<0)
                cnt--;
            q[++cnt]=pp[i];
        }//求凸包
        j=1;
        int k1,k2;
        k1=k2=1;
        double S=inf,C=inf;
        for(i=0;i<cnt;i++)
            double w=sqrt(Len(q[i],q[(i+1)%cnt]));
            while(cross(q[i],q[(i+1)%cnt],q[(j+1)%cnt])>cross(q[i],q[(i+1)%cnt],q[j%cnt]))
                j++;
            double high=cross(q[i],q[(i+1)%cnt],q[j%cnt])/w;
            while(dot(q[i],q[(i+1)%cnt],q[(k1+1)%cnt])>dot(q[i],q[(i+1)%cnt],q[(k1%cnt)]))
                k1++;
            if(i==0)
                k2=k1;
            while(dot(q[i],q[(i+1)%cnt],q[(k2+1)%cnt])<=dot(q[i],q[(i+1)%cnt],q[(k2%cnt)]))
                k2++;
            double wide=(dot(q[i],q[(i+1)%cnt],q[(k1%cnt)])-dot(q[i],q[(i+1)%cnt],q[(k2%cnt)]))/w;
            //printf("%.3lf %.3lf %.3lf\n",high,wide,(high+wide)*2);
            S=min(S,high*wide);
            C=min(C,(high+wide)*2);
        printf("%.2lf %.2lf\n",S,C);
    return 0;
已领礼包: 2226个
发表于 2017-1-21 19:57:40 | 显示全部楼层
有没有lisp版?
已领礼包: 20个
发表于 2017-1-21 20:31:37 | 显示全部楼层
应该很容易改成LISP的。
剖开这个代码,说下方法,先求出凸包,然后做个多边形POLYLINE,然后循环每个边,求每个边方向上的最大包围盒,找出这些包围盒的面积最小的。
GMT+8, 2024-5-30 00:47 , Processed in 0.338060 second(s), 32 queries , Gzip On.
© 2001-2024 Discuz! Team.
