查看: 680|回复: 1
[研讨] XDGE几何库应用 ---- 判断两曲线位置关系(5种)
已领礼包: 51个
发表于 2017-2-13 20:07:34 | 显示全部楼层 |阅读模式
使用ARX的几何库 AcGeCurveCurveInt3d 类 判断曲线位置关系,两曲线的交点关系有如下可能:
1、相交 2、相离 3、内部 4、外部、5、相贴
AcGe::AcGeXConfig Enum
AcGeXConfig
NameDeclared ValueDescription
kNotDefined1 << 0
kUnknown1 << 1
kLeftRight1 << 2
kRightLeft1 << 3
kLeftLeft1 << 4
kRightRight1 << 5
kPointLeft1 << 6
kPointRight1 << 7
kLeftOverlap1 << 8
kOverlapLeft1 << 9
kRightOverlap1 << 10
kOverlapRight1 << 11
kOverlapStart1 << 12
kOverlapEnd1 << 13
kOverlapOverlap1 << 14
通过图示说明下
通过使用AcGeCurveCurveInt3d类下的getIntConfigs方法,下面写个判断两曲线关系的函数。
(defun XD::Curve:Relation (e1 e2 / config config1 g1 g2 gint i numints pos1
                              pos2 ret tf
  (if (and
        (setq g1 (xdge::Constructor e1))
        (setq g2 (xdge::Constructor e2))
        (setq gint (xdge::Constructor "kCurveCurveInt3d" g1 g2))
    (progn
      (setq numints (xdge::getpropertyvalue gint "numintpoints"))
      (cond
        ((= numints 0)
          (cond
            ((xdrx_curve_isclosed e1)
              (if (xdrx_curve_isinside e1 e2)
                (setq ret "Outside")
                (progn
                  (if (xdrx_curve_isclosed e2)
                    (if (xdrx_curve_isinside e2 e1)
                      (setq ret "Inside")
                      (setq ret "Disjoint")
            (t
        ((> numints 0)
          (setq tf t
                i 0
          (setq config1 (xdge::getpropertyvalue gint "getintconfigs" 0 t)
                pos1 (car (xdrx_string_regexps "(?<=k)[a-zA-Z]+(?=overlap)"
                                               (car config1)
          (while (and
                   tf
                   (< i numints)
            (setq config (xdge::getpropertyvalue gint "getintconfigs" i t))
            (setq i (1+ i))
            (setq pos2 (car (xdrx_string_regexps "(?<=koverlap)[a-zA-Z]+"
                                                 (car config)
            (if (or
                  (and
                    (xdrx_string_regexps "right" (car config))
                    (xdrx_string_regexps "left" (car config))
                  (and
                    pos2
                    (/= pos2 "Overlap")
                    (/= pos1 pos2)
              (progn
                (setq tf nil
                      ret "Intersect"
          (if (not ret)
            (setq ret "Overlap")
  ret
测试命令TT
(defun c:tt ()
  (if (and (setq e1 (car (entsel)))
           (setq e2 (car (entsel)))
    (progn
      (setq pos (XD::Curve:Relation e1 e2))
      (cond
        ((= pos "Inside")
         (xdrx_prompt "\n曲线1在曲线2内部!")
        ((= pos "Outside")
         (xdrx_prompt "\n曲线1在曲线2外部!")
        ((= pos "Intersect")
         (xdrx_prompt "\n曲线1和曲线2相交!")
        ((= pos "Disjoint")
         (xdrx_prompt "\n曲线1和曲线2相离!")
        ((= pos "Overlap")
         (xdrx_prompt "\n曲线1和曲线2相贴!")
  (princ)
已领礼包: 58个
发表于 2017-8-29 14:18:22 | 显示全部楼层
帖子真好 正慢慢读懂
下图两曲线判断为相交?应该是相贴吧
GMT+8, 2024-5-29 03:37 , Processed in 0.370705 second(s), 34 queries , Gzip On.
© 2001-2024 Discuz! Team.
