查看: 582|回复: 1
[求助] 修改 块 x y 比例
发表于 2017-2-27 22:07:06 | 显示全部楼层 |阅读模式
我想修改选择块的比例。下面的代码是直接修改块的属性。但是不能成功,望大神指点!!
Sub 图框缩放()
Do
    Dim ds As Double
    Dim Ent As AcadEntity  '选择集对象
    Dim Ent1 As AcadEntity  '选择集对象
   On Error Resume Next
   ThisDrawing.Utility.GetEntity Ent, Pnt, "图框:"
   ThisDrawing.Utility.GetEntity Ent1, Pnt1, "说明文字:"
     If Pnt(0) = "" Then         '退出sub
      Exit Sub
      End If
    ds = Ent1.Height
    ds = ds / 3
   Ent.XScaleFactor = ds
   Ent.XEffectiveScaleFactor = ds
   Ent.YScaleFactor = ds
   Ent.YEffectiveScaleFactor = ds
      If Err <> 0 Then
        Exit Do
      End If
Loop
End Sub
已领礼包: 20个
发表于 2017-2-27 22:28:08 | 显示全部楼层
你应该对BlockReference  对象操作,而不是Entity
下面是个例子,你对照下看看
Sub Example_XScaleFactor()
    ' This example creates a block containing a circle.
    ' It then inserts the block and changes the XScaleFactor.
    ' Create the block
    Dim blockObj As AcadBlock
    Dim insertionPnt(0 To 2) As Double
    insertionPnt(0) = 0#: insertionPnt(1) = 0#: insertionPnt(2) = 0#
    Set blockObj = ThisDrawing.Blocks.Add(insertionPnt, "CircleBlock")
    ' Add a circle to the block
    Dim circleObj As AcadCircle
    Dim center(0 To 2) As Double
    Dim radius As Double
    center(0) = 0: center(1) = 0: center(2) = 0
    radius = 1
    Set circleObj = blockObj.AddCircle(center, radius)
    ' Insert the block
    Dim blockRefObj As AcadBlockReference
    insertionPnt(0) = 2#: insertionPnt(1) = 2#: insertionPnt(2) = 0
    Set blockRefObj = ThisDrawing.ModelSpace.InsertBlock(insertionPnt, "CircleBlock", 1#, 1#, 1#, 0)
    ' Find the current XScaleFactor for the block reference
    Dim currXScaleFactor As Double
    currXScaleFactor = blockRefObj.XScaleFactor
    ZoomAll
    MsgBox "The current XScaleFactor for the block reference is " & blockRefObj.XScaleFactor, , "XScaleFactor Example"
    ' Change the XScaleFactor for the block reference
    blockRefObj.XScaleFactor = currXScaleFactor + 2
    ZoomAll
    MsgBox "The new XScaleFactor for the block reference is " & blockRefObj.XScaleFactor, , "XScaleFactor Example"
End Sub
GMT+8, 2024-6-7 18:27 , Processed in 0.344670 second(s), 30 queries , Gzip On.
© 2001-2024 Discuz! Team.
