查看: 2482|回复: 34
[每日一码] 曲线转向(大量实例)
发表于 2017-7-24 12:08:47 | 显示全部楼层 |阅读模式
  1. ;;转向LWPOLYLINE
  2. (defun rlw ( LW / E X1 X2 X3 X4 X5 X6 )
  3.   ;; by ElpanovEvgeniy
  4.   ;; reverse lwpolyline
  5.   (if (= (cdr (assoc 0 (setq e (entget lw)))) "LWPOLYLINE")
  6.     (progn (foreach a1 e
  7.              (cond ((= (car a1) 10) (setq x2 (cons a1 x2)))
  8.                    ((= (car a1) 40) (setq x4 (cons (cons 41 (cdr a1)) x4)))
  9.                    ((= (car a1) 41) (setq x3 (cons (cons 40 (cdr a1)) x3)))
  10.                    ((= (car a1) 42) (setq x5 (cons (cons 42 (- (cdr a1))) x5)))
  11.                    ((= (car a1) 210) (setq x6 (cons a1 x6)))
  12.                    (t (setq x1 (cons a1 x1)))
  13.              )
  14.            )
  15.            (entmod (append (reverse x1)
  16.                            (append (apply (function append)
  17.                                           (apply (function mapcar)
  18.                                                  (cons 'list
  19.                                                        (list x2
  20.                                                              (cdr (reverse (cons (car x3) (reverse x3))))
  21.                                                              (cdr (reverse (cons (car x4) (reverse x4))))
  22.                                                              (cdr (reverse (cons (car x5) (reverse x5))))
  23.                                                        )
  24.                                                  )
  25.                                           )
  26.                                    )
  27.                                    x6
  28.                            )
  29.                    )
  30.            )
  31.            (entupd lw)
  32.     )
  33.   )
  34. )
  1. ;; 转向SPLINE - Marko Ribar, d.i.a.
  2. (defun rspl ( spl / enx x12 x13 x1 x2 x3 x4 x5 )
  3.   (if (= (cdr (assoc 0 (setq enx (entget spl)))) "SPLINE")
  4.     (progn
  5.       (foreach a1 enx
  6.         (cond
  7.           ( (= (car a1) 12) (setq x13 (cons (cons 13 (mapcar '- (cdr a1))) x13)) )
  8.           ( (= (car a1) 13) (setq x12 (cons (cons 12 (mapcar '- (cdr a1))) x12)) )
  9.           ( (= (car a1) 40) (setq x2 (cons a1 x2)) )
  10.           ( (= (car a1) 10) (setq x3 (cons a1 x3)) )
  11.           ( (= (car a1) 41) (setq x4 (cons a1 x4)) )
  12.           ( (= (car a1) 11) (setq x5 (cons a1 x5)) )
  13.           ( t (setq x1 (cons a1 x1)) )
  14.         )
  15.       )
  16.       (entmod
  17.         (append
  18.           (reverse x1)
  19.           x12
  20.           x13
  21.           (mapcar '(lambda ( x ) (cons 40 (- (cdar x2) (cdr x)))) x2)
  22.           (if x4
  23.             (apply 'append (mapcar '(lambda ( a b ) (list a b)) x3 x4))
  24.             x3
  25.           )
  26.           x5
  27.         )
  28.       )
  29.       (entupd spl)
  30.     )
  31.   )
  32. )
  1. ;; 转向HELIX - Marko Ribar, d.i.a.
  2. (defun rhel ( hel / enx enx1 enx2 v x1 x2 x3 )
  3.   (if (= (cdr (assoc 0 (setq enx (entget hel)))) "HELIX")
  4.     (progn
  5.       (setq enx1 (reverse (cdr (member '(100 . "AcDbHelix") (reverse enx)))))
  6.       (setq enx2 (member '(100 . "AcDbHelix") enx))
  7.       (foreach a1 enx1
  8.         (cond
  11.           ( t (setq x1 (cons a1 x1)) )
  12.         )
  13.       )
  14.       (setq enx2 (subst (cons 40 (distance (cdr (assoc 10 enx2)) (cdr (assoc 11 enx2)))) (assoc 40 enx2) enx2))
  15.       (setq enx2 (subst (cons 10 (mapcar '+ (cdr (assoc 10 enx2)) (mapcar '* (cdr (assoc 12 enx2)) (list (* (cdr (assoc 41 enx2)) (cdr (assoc 42 enx2))) (* (cdr (assoc 41 enx2)) (cdr (assoc 42 enx2))) (* (cdr (assoc 41 enx2)) (cdr (assoc 42 enx2))))))) (assoc 10 enx2) enx2))
  16.       (setq enx2 (subst (cons 11 (cdr (car x3))) (assoc 11 enx2) enx2))
  17.       (setq enx2 (subst (cons 12 (mapcar '- (cdr (assoc 12 enx2)))) (assoc 12 enx2) enx2))
  18.       (entmod
  19.         (append
  20.           (reverse x1)
  22.           x3
  23.           enx2
  24.         )
  25.       )
  26.       (entupd hel)
  27.     )
  28.   )
  29. )
  1. ;; 转向LINE - Marko Ribar, d.i.a.
  2. (defun rli ( li / enx sp ep )
  3.   (if (= (cdr (assoc 0 (setq enx (entget li)))) "LINE")
  4.     (progn
  5.       (setq sp (cdr (assoc 10 enx)) ep (cdr (assoc 11 enx)))
  6.       (setq enx (subst (cons 10 ep) (assoc 10 enx) enx))
  7.       (setq enx (subst (cons 11 sp) (assoc 11 enx) enx))
  8.       (entmod enx)
  9.       (entupd li)
  10.     )
  11.   )
  12. )
  1. ;; 转向3DPOLYLINE - Marko Ribar, d.i.a.
  2. (defun r3dp ( 3dp / v p pl sfa var )
  3.   (vl-load-com)
  4.   (if
  5.     (and
  6.       (= (cdr (assoc 0 (entget 3dp))) "POLYLINE")
  7.       (< 7 (cdr (assoc 70 (entget 3dp))) 10)
  8.     )
  9.     (progn
  10.       (setq v 3dp)
  11.       (while (= (cdr (assoc 0 (entget (setq v (entnext v))))) "VERTEX")
  12.         (setq p (cdr (assoc 10 (entget v))))
  13.         (setq pl (cons p pl))
  14.       )
  15.       (setq pl (apply 'append pl))
  16.       (setq sfa (vlax-make-safearray vlax-vbdouble (cons 0 (1- (length pl)))))
  17.       (vlax-safearray-fill sfa pl)
  18.       (setq var (vlax-make-variant sfa))
  19.       (vla-put-coordinates (vlax-ename->vla-object 3dp) var)
  20.       (entupd 3dp)
  21.     )
  22.   )
  23. )
  1. ;; 转向old heavy 2d POLYLINE - Marko Ribar, d.i.a.
  2. (defun rhpl ( hpl / rlw )
  3.   (vl-load-com)
  4.   (defun rlw ( LW / E X1 X2 X3 X4 X5 X6 )
  5.     ;; by ElpanovEvgeniy
  6.     ;; reverse lwpolyline
  7.     (if (= (cdr (assoc 0 (setq e (entget lw)))) "LWPOLYLINE")
  8.       (progn (foreach a1 e
  9.                (cond ((= (car a1) 10) (setq x2 (cons a1 x2)))
  10.                      ((= (car a1) 40) (setq x4 (cons (cons 41 (cdr a1)) x4)))
  11.                      ((= (car a1) 41) (setq x3 (cons (cons 40 (cdr a1)) x3)))
  12.                      ((= (car a1) 42) (setq x5 (cons (cons 42 (- (cdr a1))) x5)))
  13.                      ((= (car a1) 210) (setq x6 (cons a1 x6)))
  14.                      (t (setq x1 (cons a1 x1)))
  15.                )
  16.              )
  17.              (entmod (append (reverse x1)
  18.                              (append (apply (function append)
  19.                                             (apply (function mapcar)
  20.                                                    (cons 'list
  21.                                                          (list x2
  22.        (cdr (reverse (cons (car x3) (reverse x3))))
  23.        (cdr (reverse (cons (car x4) (reverse x4))))
  24.        (cdr (reverse (cons (car x5) (reverse x5))))
  25.                                                          )
  26.                                                    )
  27.                                             )
  28.                                      )
  29.                                      x6
  30.                              )
  31.                      )
  32.              )
  33.              (entupd lw)
  34.       )
  35.     )
  36.   )
  37.   (if
  38.     (and
  39.       (= (cdr (assoc 0 (entget hpl))) "POLYLINE")
  40.       (or
  41.         (< -1 (cdr (assoc 70 (entget hpl))) 6)
  42.         (< 127 (cdr (assoc 70 (entget hpl))) 134)
  43.       )
  44.     )
  45.     (progn
  46.       (cond
  47.         ( (or (< -1 (cdr (assoc 70 (entget hpl))) 2) (< 127 (cdr (assoc 70 (entget hpl))) 130))
  48.           (command "_.CONVERTPOLY" "_L" hpl "")
  49.           (rlw hpl)
  50.           (command "_.CONVERTPOLY" "_H" hpl "")
  51.           (entupd hpl)
  52.         )
  53.         ( (or (< 1 (cdr (assoc 70 (entget hpl))) 4) (< 129 (cdr (assoc 70 (entget hpl))) 132))
  54.           (vla-put-type (vlax-ename->vla-object hpl) (- (vla-get-type (vlax-ename->vla-object hpl)) 1))
  55.           (command "_.CONVERTPOLY" "_L" hpl "")
  56.           (rlw hpl)
  57.           (command "_.CONVERTPOLY" "_H" hpl "")
  58.           (vla-put-type (vlax-ename->vla-object hpl) (+ (vla-get-type (vlax-ename->vla-object hpl)) 1))
  59.           (entupd hpl)
  60.         )
  61.         ( (and (or (< 3 (cdr (assoc 70 (entget hpl))) 6) (< 131 (cdr (assoc 70 (entget hpl))) 134)) (= (cdr (assoc 75 (entget hpl))) 5))
  62.           (vla-put-type (vlax-ename->vla-object hpl) (- (vla-get-type (vlax-ename->vla-object hpl)) 2))
  63.           (command "_.CONVERTPOLY" "_L" hpl "")
  64.           (rlw hpl)
  65.           (command "_.CONVERTPOLY" "_H" hpl "")
  66.           (vla-put-type (vlax-ename->vla-object hpl) (+ (vla-get-type (vlax-ename->vla-object hpl)) 2))
  67.           (entupd hpl)
  68.         )
  69.         ( (and (or (< 3 (cdr (assoc 70 (entget hpl))) 6) (< 131 (cdr (assoc 70 (entget hpl))) 134)) (= (cdr (assoc 75 (entget hpl))) 6))
  70.           (vla-put-type (vlax-ename->vla-object hpl) (- (vla-get-type (vlax-ename->vla-object hpl)) 3))
  71.           (command "_.CONVERTPOLY" "_L" hpl "")
  72.           (rlw hpl)
  73.           (command "_.CONVERTPOLY" "_H" hpl "")
  74.           (vla-put-type (vlax-ename->vla-object hpl) (+ (vla-get-type (vlax-ename->vla-object hpl)) 3))
  75.           (entupd hpl)
  76.         )
  77.       )
  78.     )
  79.   )
  80. )
  2. (defun r3dp ( 3dp / r3dppol typ )
  3.   (defun r3dppol ( 3dp / v p pl sfa var )
  4.     (vl-load-com)
  5.     (setq v 3dp)
  6.     (while (= (cdr (assoc 0 (entget (setq v (entnext v))))) "VERTEX")
  7.       (setq p (cdr (assoc 10 (entget v))))
  8.       (setq pl (cons p pl))
  9.     )
  10.     (setq pl (apply 'append pl))
  11.     (setq sfa (vlax-make-safearray vlax-vbdouble (cons 0 (1- (length pl)))))
  12.     (vlax-safearray-fill sfa pl)
  13.     (setq var (vlax-make-variant sfa))
  14.     (vla-put-coordinates (vlax-ename->vla-object 3dp) var)
  15.     (entupd 3dp)
  16.   )
  17.   (setq typ (vla-get-type (vlax-ename->vla-object 3dp)))
  18.   (vla-put-type (vlax-ename->vla-object 3dp) acsimplepoly)
  19.   (r3dppol 3dp)
  20.   (if typ (vla-put-type (vlax-ename->vla-object 3dp) typ))
  21.   (entupd 3dp)
  22. )
  1. ;转向2D POLYLINE和LWPOLYLINE
  2. ; (KGA_List_Divide_2 '(0 1 2 3 4 5 6 7 8 9)) => ((0 1) (2 3) (4 5) (6 7) (8 9))
  3. ; (KGA_List_Divide_2 '(0 1 2 3 4 5 6 7 8))   => ((0 1) (2 3) (4 5) (6 7))
  4. (defun KGA_List_Divide_2 (lst / ret)
  5.   (repeat (/ (length lst) 2)
  6.     (setq ret (cons (list (car lst) (cadr lst)) ret))
  7.     (setq lst (cddr lst))
  8.   )
  9.   (reverse ret)
  10. )
  11. ; (KGA_List_Divide_3 '(0 1 2 3 4 5 6 7 8)) => ((0 1 2) (3 4 5) (6 7 8))
  12. ; (KGA_List_Divide_3 '(0 1 2 3 4 5 6 7))   => ((0 1 2) (3 4 5))
  13. (defun KGA_List_Divide_3 (lst / ret)
  14.   (repeat (/ (length lst) 3)
  15.     (setq ret (cons (list (car lst) (cadr lst) (caddr lst)) ret))
  16.     (setq lst (cdddr lst))
  17.   )
  18.   (reverse ret)
  19. )
  20. ; Make a zero based list of integers.
  21. ; With speed improvement based on Reini Urban's (std-%setnth).
  22. ; (KGA_List_IndexSeqMakeLength 7) => (0 1 2 3 4 5 6)
  23. (defun KGA_List_IndexSeqMakeLength (len / ret)
  24.   (repeat (rem len 4)
  25.     (setq ret (cons (setq len (1- len)) ret))
  26.   )
  27.   (repeat (/ len 4)
  28.     (setq ret
  29.       (vl-list*
  30.         (- len 4)
  31.         (- len 3)
  32.         (- len 2)
  33.         (- len 1)
  34.         ret
  35.       )
  36.     )
  37.     (setq len (- len 4))
  38.   )
  39.   ret
  40. )
  41. ; Obj must be an "AcDb2dPolyline" of the acsimplepoly type or an "AcDbPolyline".
  42. ; (KGA_Geom_PolylineReverse (vlax-ename->vla-object (car (entsel))))
  43. (defun KGA_Geom_PolylineReverse (obj / bulgeLst idxLst ptLst widLst)
  44.   (setq ptLst
  45.     ((if (= "AcDb2dPolyline" (vla-get-objectname obj)) KGA_List_Divide_3 KGA_List_Divide_2)
  46.       (vlax-get obj 'coordinates)
  47.     )
  48.   )
  49.   (setq idxLst (KGA_List_IndexSeqMakeLength (length ptLst)))
  50.   (setq bulgeLst
  51.     (mapcar
  52.       '(lambda (idx) (vla-getbulge obj idx))
  53.       idxLst
  54.     )
  55.   )
  56.   (setq widLst
  57.     (mapcar
  58.       '(lambda (idx / widSta widEnd)
  59.         (vla-getwidth obj idx 'widSta 'widEnd)
  60.         (list widSta widEnd)
  61.       )
  62.       idxLst
  63.     )
  64.   )
  65.   (mapcar
  66.     '(lambda (idx pt bulge widSub)
  67.       (vlax-put obj 'coordinate idx pt)
  68.       (vla-setbulge obj idx (- bulge))
  69.       (vla-setwidth obj idx (cadr widSub) (car widSub))
  70.     )
  71.     idxLst
  72.     (reverse ptLst)
  73.     (append (cdr (reverse bulgeLst)) (list (car bulgeLst)))
  74.     (append (cdr (reverse widLst)) (list (car widLst)))
  75.   )
  76. )
  1. ;; 转向 heavy 2d POLYLINE - Marko Ribar, d.i.a.
  2. (defun rhpl ( hpl / KGA_List_Divide_3 KGA_List_IndexSeqMakeLength KGA_Geom_PolylineReverse )
  3.   (vl-load-com)
  4.   ; (KGA_List_Divide_3 '(0 1 2 3 4 5 6 7 8)) => ((0 1 2) (3 4 5) (6 7 8))
  5.   ; (KGA_List_Divide_3 '(0 1 2 3 4 5 6 7))   => ((0 1 2) (3 4 5))
  6.   (defun KGA_List_Divide_3 (lst / ret)
  7.     (repeat (/ (length lst) 3)
  8.       (setq ret (cons (list (car lst) (cadr lst) (caddr lst)) ret))
  9.       (setq lst (cdddr lst))
  10.     )
  11.     (reverse ret)
  12.   )
  13.   ; Make a zero based list of integers.
  14.   ; With speed improvement based on Reini Urban's (std-%setnth).
  15.   ; (KGA_List_IndexSeqMakeLength 7) => (0 1 2 3 4 5 6)
  16.   (defun KGA_List_IndexSeqMakeLength (len / ret)
  17.     (repeat (rem len 4)
  18.       (setq ret (cons (setq len (1- len)) ret))
  19.     )
  20.     (repeat (/ len 4)
  21.       (setq ret
  22.         (vl-list*
  23.           (- len 4)
  24.           (- len 3)
  25.           (- len 2)
  26.           (- len 1)
  27.           ret
  28.         )
  29.       )
  30.       (setq len (- len 4))
  31.     )
  32.     ret
  33.   )
  34.   ; Obj must be an "AcDb2dPolyline" of the acsimplepoly type or an "AcDbPolyline".
  35.   ; (KGA_Geom_PolylineReverse (vlax-ename->vla-object (car (entsel))))
  36.   (defun KGA_Geom_PolylineReverse (obj / typ bulgeLst idxLst ptLst widLst conWid v vx)
  37.     (setq typ (vla-get-type obj))
  38.     (vla-put-type obj acsimplepoly)
  39.     (setq ptLst (KGA_List_Divide_3 (vlax-get obj 'coordinates)))
  40.     (setq idxLst (KGA_List_IndexSeqMakeLength (1+ (length ptLst))))
  41.     (setq v (vlax-vla-object->ename obj))
  42.     (while (= (cdr (assoc 0 (setq vx (entget (setq v (entnext v)))))) "VERTEX")
  43.       (setq widLst (cons (list (cdr (assoc 40 vx)) (cdr (assoc 41 vx))) widLst))
  44.       (setq bulgeLst (cons (cdr (assoc 42 vx)) bulgeLst))
  45.     )
  46.     (if (vl-catch-all-error-p (setq conWid (vl-catch-all-apply 'vla-get-constantwidth (list obj))))
  47.       (mapcar
  48.        '(lambda (idx pt bulge widSub)
  49.           (vla-put-coordinate obj idx (vlax-3d-point pt))
  50.           (vla-setbulge obj idx (- bulge))
  51.           (vla-setwidth obj idx (cadr widSub) (car widSub))
  52.         )
  53.         idxLst
  54.         (reverse ptLst)
  55.         (append (cdr bulgeLst) (list (car bulgeLst)))
  56.         (append (cdr widLst) (list (car widLst)))
  57.       )
  58.       (progn
  59.         (mapcar
  60.          '(lambda (idx pt bulge widSub)
  61.             (vla-put-coordinate obj idx (vlax-3d-point pt))
  62.             (vla-setbulge obj idx (- bulge))
  63.           )
  64.           idxLst
  65.           (reverse ptLst)
  66.           (append (cdr bulgeLst) (list (car bulgeLst)))
  67.         )
  68.         (vla-put-constantwidth obj conWid)
  69.       )
  70.     )
  71.     (if typ (vla-put-type obj typ))
  72.   )
  73.   (KGA_Geom_PolylineReverse (vlax-ename->vla-object hpl))
  74.   (entupd hpl)
  75. )
另外一个版本转向"AcDb2dPolyline" or an "AcDbPolyline"
游客,如果您要查看本帖隐藏内容请回复
评分
参与人数 2D豆 +15 贡献 +1 收起 理由
/db_自贡黄明儒_ + 10 很给力!经验;技术要点;资料分享奖!
炫翔 + 5 + 1 很给力!经验;技术要点;资料分享奖!
查看全部评分
已领礼包: 2476个
发表于 2017-7-24 12:15:33 | 显示全部楼层
圆弧似乎不能反向
已领礼包: 475个
发表于 2017-7-24 13:16:42 | 显示全部楼层
试试看
已领礼包: 26个
发表于 2017-7-24 13:40:44 | 显示全部楼层
已领礼包: 26个
发表于 2017-7-24 13:42:36 | 显示全部楼层
圆弧是按照圆心角方向计算圆弧方向的,想转向,可以先转化为多段线
发表于 2017-7-24 14:11:51 | 显示全部楼层
XDRX API, 对任意曲线
(xdrx_curve_reverse ent)
已领礼包: 1336个
发表于 2017-7-24 14:49:22 | 显示全部楼层
一般情况下够用了,谢谢分享!
已领礼包: 37个
发表于 2017-7-24 15:30:15 | 显示全部楼层
感谢楼主分享
已领礼包: 5586个
发表于 2017-7-24 15:49:42 | 显示全部楼层
非常感谢楼主分享程序
已领礼包: 432个
发表于 2017-7-24 17:25:42 | 显示全部楼层
我来测试一下,行不行
已领礼包: 3031个
发表于 2017-7-24 20:34:39 | 显示全部楼层
谢谢分享!感恩!
已领礼包: 8729个
发表于 2017-7-25 06:55:41 | 显示全部楼层
非常感谢分享程序!!!
已领礼包: 812个
发表于 2017-7-25 07:56:44 | 显示全部楼层
感谢楼主分享
已领礼包: 2409个
发表于 2017-7-25 08:54:34 | 显示全部楼层
学习!!!!!!!!!!!!!!!
发表于 2017-11-16 23:36:23 | 显示全部楼层
圆弧似乎不能反向
GMT+8, 2024-4-30 19:14 , Processed in 0.435055 second(s), 57 queries , Gzip On.
© 2001-2024 Discuz! Team.
