查看: 618|回复: 2
[分享] 坐标标注
已领礼包: 7个
发表于 2019-1-2 15:32:55 | 显示全部楼层 |阅读模式
坐标标注   X Y坐标都可用
[pcode=vb,true]
' 在模型空间中创建坐标标注。
Public Sub pc_zb()
    On Error Resume Next
    Dim dimObj As AcadDimOrdinate
    Dim pT0 As Variant
    Dim pT As Variant
    Dim pTyd(0 To 2) As Double
    Dim pTs(0 To 2) As Double
    Dim pTe(0 To 2) As Double
    Dim fx As Boolean
    fx = True
    pTyd(0) = 0: pTyd(1) = 0: pTyd(2) = 0
    pT0 = ThisDrawing.Utility.GetPoint(, "坐标起点: ")
    Dim j_xxs As Double, j_yxs As Double, j_wzxs As Boolean
    j_wzxs = True
    '获取标注的全局比例
    Dim RetVal As Variant
    RetVal = ThisDrawing.GetVariable("dimscale")
    j_xxs = 0: j_yxs = RetVal * 10
    ' 在模型空间中创建起点坐标标注
    pTs(0) = 0: pTs(1) = 0: pTs(2) = 0
    pTe(0) = j_xxs: pTe(1) = j_yxs: pTe(2) = 0
    Set dimObj = ThisDrawing.ModelSpace.AddDimOrdinate(pTs, pTe, fx)
    dimObj.Layer = "标注"
    dimObj.Move pTyd, pT0
     '设置关键字
    ThisDrawing.Utility.InitializeUserInput 1, "X Y T"
    Do
        pT = ThisDrawing.Utility.GetPoint(pT0, "[X]标注X坐标,[Y]标注Y坐标,[T]变换文字位置,选取下一点: ")
        If Err Then
            If InStr(1, Err.Description, "关键字", vbTextCompare) > 0 Or _
                InStr(1, Err.Description, "keyword", vbTextCompare) > 0 Then '输入了一个关键字
                Dim inputString As String
                Err.Clear
                inputString = ThisDrawing.Utility.GetInput
                Select Case inputString
                    Case "X"
                        fx = True
                        If j_wzxs Then
                        Else
                            j_xxs = 0: j_yxs = 0 - RetVal * 10
                        End If
                    Case "Y"
                        fx = False
                        If j_wzxs Then
                            j_xxs = RetVal * 10: j_yxs = 0
                        Else
                            j_xxs = 0 - RetVal * 10: j_yxs = 0
                        End If
                    Case "T"
                        j_wzxs = Not j_wzxs
                        j_xxs = 0 - j_xxs: j_yxs = 0 - j_yxs
                End Select
            Else
                Err.Clear
                Exit Sub  '错误退出
            End If
        Else
            pTs(0) = pT(0) - pT0(0): pTs(1) = pT(1) - pT0(1): pTs(2) = 0
            pTe(0) = pTs(0) + j_xxs: pTe(1) = pTs(1) + j_yxs: pTe(2) = 0
                dimObj.Layer = "标注"
        End If
    Loop
End Sub
[/pcode]
已领礼包: 7个
 楼主| 发表于 2019-1-2 15:34:48 | 显示全部楼层
为什么不是高亮显示
  1. ' 在模型空间中创建坐标标注。
  2. Public Sub pc_zb()
  3.     On Error Resume Next
  4.
  5.     Dim dimObj As AcadDimOrdinate
  6.     Dim pT0 As Variant
  7.     Dim pT As Variant
  8.     Dim pTyd(0 To 2) As Double
  9.     Dim pTs(0 To 2) As Double
  10.     Dim pTe(0 To 2) As Double
  11.     Dim fx As Boolean
  12.
  13.     fx = True
  14.     pTyd(0) = 0: pTyd(1) = 0: pTyd(2) = 0
  15.     pT0 = ThisDrawing.Utility.GetPoint(, "坐标起点: ")
  16.
  17.     Dim j_xxs As Double, j_yxs As Double, j_wzxs As Boolean
  18.     j_wzxs = True
  19.     '获取标注的全局比例
  20.     Dim RetVal As Variant
  21.     RetVal = ThisDrawing.GetVariable("dimscale")
  22.     j_xxs = 0: j_yxs = RetVal * 10
  23.
  24.     ' 在模型空间中创建起点坐标标注
  25.     pTs(0) = 0: pTs(1) = 0: pTs(2) = 0
  26.     pTe(0) = j_xxs: pTe(1) = j_yxs: pTe(2) = 0
  27.     Set dimObj = ThisDrawing.ModelSpace.AddDimOrdinate(pTs, pTe, fx)
  28.     dimObj.Layer = "标注"
  29.     dimObj.Move pTyd, pT0
  30.
  31.      '设置关键字
  32.     ThisDrawing.Utility.InitializeUserInput 1, "X Y T"
  33.     Do
  34.         pT = ThisDrawing.Utility.GetPoint(pT0, "[X]标注X坐标,[Y]标注Y坐标,[T]变换文字位置,选取下一点: ")
  35.         If Err Then
  36.             If InStr(1, Err.Description, "关键字", vbTextCompare) > 0 Or _
  37.                 InStr(1, Err.Description, "keyword", vbTextCompare) > 0 Then '输入了一个关键字
  38.                 Dim inputString As String
  39.                 Err.Clear
  40.                 inputString = ThisDrawing.Utility.GetInput
  41.                 Select Case inputString
  42.                     Case "X"
  43.                         fx = True
  44.                         If j_wzxs Then
  45.                             j_xxs = 0: j_yxs = RetVal * 10
  46.                         Else
  47.                             j_xxs = 0: j_yxs = 0 - RetVal * 10
  48.                         End If
  49.                     Case "Y"
  50.                         fx = False
  51.                         If j_wzxs Then
  52.                             j_xxs = RetVal * 10: j_yxs = 0
  53.                         Else
  54.                             j_xxs = 0 - RetVal * 10: j_yxs = 0
  55.                         End If
  56.                     Case "T"
  57.                         j_wzxs = Not j_wzxs
  58.                         j_xxs = 0 - j_xxs: j_yxs = 0 - j_yxs
  59.                 End Select
  60.             Else
  61.                 Err.Clear
  62.                 Exit Sub  '错误退出
  63.             End If
  64.         Else
  65.             pTs(0) = pT(0) - pT0(0): pTs(1) = pT(1) - pT0(1): pTs(2) = 0
  66.             pTe(0) = pTs(0) + j_xxs: pTe(1) = pTs(1) + j_yxs: pTe(2) = 0
  67.             Set dimObj = ThisDrawing.ModelSpace.AddDimOrdinate(pTs, pTe, fx)
  68.                 dimObj.Layer = "标注"
  69.                 dimObj.Move pTyd, pT0
  70.         End If
  71.     Loop
  72. End Sub
已领礼包: 71个
发表于 2019-1-3 07:50:48 | 显示全部楼层
谢谢!学习学习!
GMT+8, 2024-5-30 03:04 , Processed in 0.360441 second(s), 31 queries , Gzip On.
© 2001-2024 Discuz! Team.
