查看: 981|回复: 4
[原创] acad cnct sqlite3
已领礼包: 5个
发表于 2019-2-5 23:10:33 | 显示全部楼层 |阅读模式
(setq ConnectString " DRIVER=Devart ODBC Driver for SQLite;Database=C:\\CAD\\test.db")
qi ce hao yong
sqlite---python ---actveX--acad--actveX--- vlsp --sqlite
da jia yi qi happy new year
已领礼包: 960个
发表于 2019-2-6 00:23:26 | 显示全部楼层
问一下,这是做什么用的
已领礼包: 7个
发表于 2019-2-7 15:17:34 | 显示全部楼层
只是定义了一个字符串变量,接下来怎么连接呢
已领礼包: 5个
 楼主| 发表于 2019-2-7 20:52:24 | 显示全部楼层
已领礼包: 5个
 楼主| 发表于 2019-10-20 20:42:14 | 显示全部楼层
;;装好 sqliteodbcqudong_downcc
;;建好  sqlite3 的odbc     Driver={SQLite3 ODBC Driver}
;;准备一个 test.db 文件    Database=I:\\A_slv\\db\\test.db;
;;表里有个 scb  字段有 dh,cp,sl,tuan
;;加几个记录
;;数据库连接函数ADOLISP,目前测试32位CAD可用(系统32位和64位均可)
;;; An example of using ADOLISP_Library.lsp
(if (not ADOLISP_ConnectToDB)
  (load "ADOLISP_Library.lsp")
(defun C:sqltt (/ ConnectionObject Result ConnectString SQLStatement
                  TablesList ColumnsList
  ;; Connecting to the database ...
;  (setq ConnectString
    ;     "Provider=MSDASQL;Driver={Microsoft Access Driver (*.mdb)};DBQ=C:\\CAD\\ADOLISP_test.mdb"
  ;; An alternative connect string
  ;(setq ConnectString "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=C:\\CAD\\ADOLISP_test.mdb;Persist Security Info=False")
  ;(setq ConnectString "Provider=Microsoft.ACE.OLEDB.12.0;Data Source=C:\\CAD\\ADOLISP_test.accdb;Persist Security Info=False")
  (setq ConnectString
     ;;  "DRIVER=Devart ODBC Driver for SQLite;Database=C:\\CAD\\test.db"
     ;;设定一个链接字符串
    "Driver={SQLite3 ODBC Driver};Database=I:\\A_slv\\db\\test.db;
     StepAPI=0;SyncPragma=;NoTXN=0;Timeout=;ShortNames=0;LongNames=0;NoCreat=0;NoWCHAR=0;
     FKSupport=0;JournalMode=;OEMCP=0;LoadExt=;BigInt=0;JDConv=0;
  ;;  去连接
  (prompt (strcat "\n\nConnecting to the database using \n\""
                  ConnectString
  (if (not (setq ConnectionObject
                  (ADOLISP_ConnectToDB ConnectString "admin" "")
    (progn
      (prompt "\nConnection failed!")
      (ADOLISP_ErrorPrinter)
    (prompt "\nResult: succeeded!")
  ;; If we got a connection ...
  ;;  如果得到 链接
  (if ConnectionObject
    (progn
      ;; Retrieve some data
      (setq
        SQLStatement "SELECT * FROM scb"
      (prompt
        (strcat
          "\n\nExecuting a SELECT statement to retrieve some data:\n\""
          SQLStatement
      (if (setq Result (ADOLISP_DoSQL ConnectionObject SQLStatement))
        (progn
          (prompt "\nResult: ")
          (print Result)
        (progn
          (prompt "\nFailed!")
      ;; Insert a row
      (setq SQLStatement
            ; "INSERT INTO DESKS (AUTOCAD_HANDLE, AUTOCAD_DRAWING, OCCUPANT, EXTENSION, PROPERTY_NUMBER) VALUES ('ABCDEF00', 'TESTDRAWING', 'Barbara', '123456', '654321')"
             "INSERT INTO SCB (dh,cp,sl) VALUES ('15','柜子','18')"
      (prompt (strcat "\n\nInserting a row:\n\""
                      SQLStatement
        (prompt "\nResult:\nSucceeded!")
        (progn
      ;; Change a row or rows
      (setq SQLStatement
             ;"UPDATE DESKS SET OCCUPANT='Me' WHERE AUTOCAD_DRAWING='TESTDRAWING'"
             "UPDATE SCB SET  SL='9' WHERE tuan='中文'"
      (prompt (strcat "\n\nChanging a row or rows:\n\""
                      SQLStatement
        (progn
      ;; Delete a row or rows
      (setq SQLStatement
             "DELETE FROM scb WHERE cp='柜子'"
      (prompt (strcat "\n\nDeleting a row or rows:\n\""
                      SQLStatement
        (progn
      ;; Just for grins, see what's in the database
      (prompt "\n\nTables and views in the database:")
      (setq TablesList (ADOLISP_GetTablesAndViews ConnectionObject))
      (print (ADOLISP_GetTablesAndViews ConnectionObject))
      (prompt (strcat "\n\nColumn properties in table "
                      (caar TablesList)
      (setq ColumnsList
             (ADOLISP_GetColumns
               ConnectionObject
               (caar TablesList)
      (foreach Item ColumnsList
        (print Item)
      ;; Disconnect  断开链接
      (prompt "\n\nDisconnecting from the database\n")
      (ADOLISP_DisconnectFromDB ConnectionObject)
      ;; Although the following is unnecessary in this case (because
      ;; ConnectionObject is a local variable), it's never a _bad_
      ;; idea to NIL-out the connection object.
      (setq ConnectionObject nil)
  (prin1)
(prin1)
GMT+8, 2024-5-14 18:14 , Processed in 0.310940 second(s), 35 queries , Gzip On.
© 2001-2024 Discuz! Team.
