查看: 621|回复: 0
[原创] 取出钢筋符号中数量最多的钢筋符号,数量相同时,取强度值低者
已领礼包: 202个
发表于 2020-5-29 09:39:41 | 显示全部楼层 |阅读模式
[Actionscript3] 纯文本查看 复制代码
(defun yqz::get:maxfh(lst / lst-rp)
	(defun get::e(lst-rp lst / e len len1 lst-a)
		(while (setq e (car lst-rp))
			(setq len (length lst)
				lst (vl-remove e lst)
				lst-rp (cdr lst-rp)
			);;;setq
			(if lst
				(setq len1 (length lst))
				(setq len1 0)
			);;;if
			(setq lst-a (cons (list (- len len1) e) lst-a))
		);;;while
		(cadar
			(vl-sort lst-a
				'(lambda(a b)
					(if (= (car a) (car b))
						(< (cadr (assoc (cadr a) *lst-fh*))
							(cadr (assoc (cadr b) *lst-fh*))
						(> (car a) (car b))
					);;;if
				);;;lambda
			);;;vl
		);;;cadar
	);;;defun
	(setq *lst-fh* '(("%%132%%140R%%141" 360.)("%%132" 360.)("%%133" 435.)("%%131" 300.)("%%130%%140RH%%141" 430.)));;构造钢筋符号、强度值表
	(setq lst-rp (xd::list:removedup lst))
	(if (= (length lst-rp) 1)
		(car lst-rp)
		(get::e lst-rp lst)
	);;;if
);;;defun
实例:
1、(setq lst '("%%132" "%%132" "%%132" "%%132" "%%132" "%%132" "%%132"
"%%132" "%%132" "%%132" "%%132" "%%132" "%%132" "%%132" "%%132" "%%132" "%%132"
"%%132" "%%132" "%%132" "%%132" "%%132" "%%132" "%%132" "%%132" "%%132" "%%132" "%%133" "%%133" "%%130%%140RH%%141"))
返回值:"%%132"
2、(setq lst '("%%133" "%%133" "%%132" "%%132" "%%130%%140RH%%141" "%%130%%140RH%%141"))
返回值:"%%132"
GMT+8, 2024-5-29 03:51 , Processed in 0.343021 second(s), 28 queries , Gzip On.
© 2001-2024 Discuz! Team.
