查看: 726|回复: 1
.NET - how to set the zoom in Paperspace Viewports
发表于 2021-1-8 23:45:23 | 显示全部楼层 |阅读模式
问题:
I need to control the zoom value in viewports on a layout. How can this be done using the .NET API????
解答:
Attached is a C# project with two custom commands. "TestVP" command iterates through all of the layouts and changes the zoom by setting the ViewHeight and ViewCenter of the viewports. The CVPORT variable is used to set the current viewport. This example uses the extents of the database so run the code in a drawing that has at least one entity. Please note that only viewports with the number 2 and 3 are handled in this example. "NewLayout" command in the example project creates a new layout and adds a viewport.
  1.         [CommandMethod("testVP")]
  2.         static public void TestVP()
  3.         {
  4.             Database db = HostApplicationServices.WorkingDatabase;
  5.             Autodesk.AutoCAD.EditorInput.Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
  6.             //db.TileMode = false;
  7.             try
  8.             {
  9.                 Transaction tr;
  10.                 using (tr = db.TransactionManager.StartTransaction())
  11.                 {
  12.                     LayoutManager layoutMgr = LayoutManager.Current;
  13.                     Layout layoutObj;
  14.                     DBDictionary layoutDict;
  15.                     ed.WriteMessage("Number of Layouts = " + layoutMgr.LayoutCount.ToString() + "\n");
  16.                     ed.WriteMessage("Current Layout = " + layoutMgr.CurrentLayout + "\n");
  17.                     Point3d x_Min = db.Extmin;
  18.                     Point3d x_Max = db.Extmax;
  19.                     using (layoutDict = (DBDictionary)tr.GetObject(db.LayoutDictionaryId, OpenMode.ForRead))
  20.                     {
  21.                         foreach (DictionaryEntry layoutEntry in layoutDict)
  22.                         {
  23.                             using (layoutObj = (Layout)tr.GetObject((ObjectId)(layoutEntry.Value), OpenMode.ForRead))
  24.                             {
  25.                                 // Set the CurrentLayout to the layout if it is not Modelspace
  26.                                 if(layoutObj.LayoutName.ToString()!= "Model")
  27.                                     layoutMgr.CurrentLayout = layoutObj.LayoutName.ToString();
  28.                                 ed.WriteMessage("Layout Name = " + layoutObj.LayoutName + "\n");
  29.                                 BlockTableRecord r = (BlockTableRecord)tr.GetObject(layoutObj.BlockTableRecordId, OpenMode.ForRead);
  30.                                 foreach (ObjectId obj in r)
  31.                                 {
  32.                                     DBObject dbobj = tr.GetObject(obj, OpenMode.ForRead);
  33.                                     Autodesk.AutoCAD.DatabaseServices.Viewport vp = dbobj as Autodesk.AutoCAD.DatabaseServices.Viewport;
  34.                                     if (vp != null)
  35.                                     {
  36.                                         ed.WriteMessage("\nnumber of Viewport = " + vp.Number.ToString());
  37.                                         //get the screen aspect ratio to calculate the height and width
  38.                                         double mScrRatio;
  39.                                         mScrRatio = (vp.Width / vp.Height);//width/height
  40.                                         Point3d mMaxExt = db.Extmax;
  41.                                         Point3d mMinExt = db.Extmin;
  42.                                         Extents3d mExtents;
  43.                                         mExtents.Set(mMinExt, mMaxExt);
  44.                                         //prepare Matrix for DCS to WCS transformation
  45.                                         Matrix3d matWCS2DCS;
  46.                                         matWCS2DCS = Matrix3d.PlaneToWorld(vp.ViewDirection);
  47.                                         matWCS2DCS = Matrix3d.Displacement(vp.ViewTarget - Point3d.Origin) * matWCS2DCS;
  48.                                         matWCS2DCS = Matrix3d.Rotation(-vp.TwistAngle, vp.ViewDirection, vp.ViewTarget) * matWCS2DCS;
  49.                                         matWCS2DCS = matWCS2DCS.Inverse();
  50.                                         //tranform the extents to the DCS defined by the viewdir
  51.                                         mExtents.TransformBy(matWCS2DCS);
  52.                                         //width of the extents in current view
  53.                                         double mWidth;
  54.                                         mWidth = (mExtents.MaxPoint.X - mExtents.MinPoint.X);
  55.                                         //height of the extents in current view
  56.                                         double mHeight;
  57.                                         mHeight = (mExtents.MaxPoint.Y - mExtents.MinPoint.Y);
  58.                                         //get the view center point
  59.                                         Point2d mCentPt = new Point2d(((mExtents.MaxPoint.X + mExtents.MinPoint.X) * 0.5), ((mExtents.MaxPoint.Y + mExtents.MinPoint.Y) * 0.5));
  60.                                         //check if the width 'fits' in current window,if not then get the new height as per the viewports aspect ratio
  61.                                         if (mWidth > (mHeight * mScrRatio)) mHeight = mWidth / mScrRatio;
  62.                                         //set the viewport parameters
  63.                                         if (vp.Number == 2)
  64.                                         {
  65.                                             vp.UpgradeOpen();
  66.                                             vp.ViewHeight = mHeight * 1.01;    //set the view height - adjusted by 1%
  67.                                             vp.ViewCenter = mCentPt; //set the view center
  68.                                             vp.Visible = true;
  69.                                             vp.On = true;
  70.                                             vp.UpdateDisplay();
  71.                                             ed.SwitchToModelSpace();
  72.                                             Application.SetSystemVariable("CVPORT", vp.Number);
  73.                                         }
  74.                                         if (vp.Number == 3)
  75.                                         {
  76.                                             vp.UpgradeOpen();
  77.                                             vp.ViewHeight = mHeight * 1.25;
  78.                                             vp.ViewCenter = mCentPt; //set the view center
  79.                                             vp.Visible = true;
  80.                                             vp.On = true;
  81.                                             vp.UpdateDisplay();
  82.                                             ed.SwitchToModelSpace();
  83.                                             Application.SetSystemVariable("CVPORT", vp.Number);
  84.                                         }
  85.                                     }//if
  86.                                 }//for each
  87.                             }//using layoutObj
  88.                         }//for each dictionaryEntry
  89.                     }//using layout dict
  90.                     tr.Commit();
  91.                 }
  92.             }
  93.             catch (System.Exception ex)
  94.             {
  95.                 ed.WriteMessage(ex.ToString());
  96.             }
  97.         }
已领礼包: 4365个
发表于 2021-1-9 09:20:51 | 显示全部楼层
GMT+8, 2024-4-29 04:32 , Processed in 0.235062 second(s), 25 queries , Gzip On.
© 2001-2024 Discuz! Team.
