查看: 1101|回复: 1
.NET: How to set the Lineweight of a Line
发表于 2021-1-8 23:48:11 | 显示全部楼层 |阅读模式
问题:
How do I create a line and append it to the current space, but also setting its LineWeight?
解答:
  1. [Autodesk.AutoCAD.Runtime.CommandMethod("CreateLine")]
  2. // creates a line and sets the lineweight for it, by Fenton Webb, DevTech, Autodesk
  3. public void CreateLine()
  4. {
  5.     // create a new line
  6.     Line line = new Line(new Point3d(0, 0, 0), new Point3d(100, 100, 0));
  7.     // set the lineweight for it
  8.     line.LineWeight = LineWeight.LineWeight211;
  9.     // add the object to the current space
  10.     Database dwg = HostApplicationServices.WorkingDatabase;
  11.     // make sure lineweights are turn on
  12.     dwg.LineWeightDisplay = true;
  13.     // get the transaction manager
  14.     Autodesk.AutoCAD.DatabaseServices.TransactionManager tm = dwg.TransactionManager;
  15.     // start a new transaction
  16.     using (Transaction myT = tm.StartTransaction())
  17.     {
  18.         try
  19.         {
  20.             // get the current space and open it for write
  21.             BlockTableRecord btr = (BlockTableRecord)tm.GetObject(dwg.CurrentSpaceId, OpenMode.ForWrite, false);
  22.             // add it to the blocktable record
  23.             btr.AppendEntity(line);
  24.             // now to the tranaction manager
  25.             tm.AddNewlyCreatedDBObject(line, true);
  26.             // all ok, lets commit it
  27.             myT.Commit();
  28.         }
  29.         catch
  30.         {
  31.             // if we failed, then abort
  32.             myT.Abort();
  33.         };
  34.     }
  35. }
已领礼包: 14个
发表于 2021-6-25 09:07:02 | 显示全部楼层
学习,学习。
GMT+8, 2024-4-29 15:09 , Processed in 0.334743 second(s), 25 queries , Gzip On.
© 2001-2024 Discuz! Team.
