查看: 595|回复: 0
Exporting Table contents
发表于 2021-1-9 22:06:34 | 显示全部楼层 |阅读模式
问题:
I would like to save the table contents to a file. How can I do this ?
解答:
AutoCAD command “TABLEEXPORT” can be used to save the contents of a table in the CSV format. One way to do this is to send this command using "SendStringToExecute".
You can also do the same thing without sending a command by traversing through the table contents as shown in the following code snippet:
  1.         [CommandMethod("TabExp")]
  2.         public void commandMethodTest()
  3.         {
  4.             Document activeDoc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
  5.             Database db = activeDoc.Database;
  6.             Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
  7.             PromptEntityOptions peo = new PromptEntityOptions("\nSelect a table : ");
  8.             peo.SetRejectMessage("\nMust be a table...");
  9.             peo.AddAllowedClass(typeof(Table), true);
  10.             PromptEntityResult per = ed.GetEntity(peo);
  11.             if (per.Status != PromptStatus.OK)
  12.                 return;
  13.             ObjectId oid = per.ObjectId;
  14.             String fileName = String.Empty;
  15.             SaveFileDialog sfd = new SaveFileDialog("Save As CSV", "Test", "csv", "Export Table As CSV", SaveFileDialog.SaveFileDialogFlags.AllowAnyExtension);
  16.             if (sfd.ShowDialog() != System.Windows.Forms.DialogResult.OK)
  17.             {
  18.                 return;
  19.             }
  20.             fileName = sfd.Filename;
  21.             StreamWriter sw = new StreamWriter(fileName);
  22.             using (Transaction tr = db.TransactionManager.StartTransaction())
  23.             {
  24.                 Table table = (Table)tr.GetObject(oid, OpenMode.ForRead);
  25.                 int Rows = table.Rows.Count;
  26.                 int Cols = table.Columns.Count;
  27.                 for (int row = 0; row < Rows; row++)
  28.                 {
  29.                     String sRow = String.Empty;
  30.                     for (int col = 0; col < Cols; col++)
  31.                     {
  32.                         if(sRow == String.Empty)
  33.                             sRow = String.Format("{0}", table.Cells[row, col].GetTextString(FormatOption.FormatOptionNone));
  34.                         else
  35.                             sRow = String.Format("{0}, {1}", sRow, table.Cells[row, col].GetTextString(FormatOption.FormatOptionNone));
  36.                     }
  37.                     sw.WriteLine(sRow);
  38.                 }
  39.                 tr.Commit();
  40.             }
  41.             ed.WriteMessage("\nTable contents exported to " + fileName + " in CSV format.");
  42.             sw.Close();
  43.         }
GMT+8, 2024-4-29 04:09 , Processed in 0.338999 second(s), 25 queries , Gzip On.
© 2001-2024 Discuz! Team.
