- UID
- 1
- 积分
- 15865
- 精华
- 贡献
- 威望
- 活跃度
- D豆
- 在线时间
- 小时
- 注册时间
- 2002-1-3
- 最后登录
- 1970-1-1
问题:
Are there two ways of creating an AutoCAD ActiveX client using C++?
解答:
There are two ways of creating an AutoCAD Active X client using C++.
Method #1
Use MFC ClassWizard to import the interfaces (from acad.tlb) that you need for
your client application.
Method #2
Use #import with acad.tlb.
NOTE: Although #import is something new from VC++ 5.0, it previously existed in
ClassWizard.
The following code segments demonstrate both methods, and is to be used with a
MFC ClassWizard-generated IAcadApplication interface.
- // This is declared as a member variable in the CSampActiveXClientDlg.
- // Given that you've use ClassWizard to import IAcadApplication interface
- // from acad.tlb.
- IAcadApplication m_IApp;
- void CSampActiveXClientDlg::OnStartacad()
- // TODO: Add your control notification handler code here
- HRESULT hr = NOERROR;
- CLSID clsid;
- LPUNKNOWN pUnk = NULL;
- LPDISPATCH pDisp = NULL;
- BeginWaitCursor();
- CoInitialize(NULL);
- hr = ::CLSIDFromProgID(L"AutoCAD.Application", &clsid);
- if (SUCCEEDED(hr))
- if(::GetActiveObject(clsid, NULL, &pUnk) == S_OK)
- VERIFY(pUnk->QueryInterface(IID_IDispatch, (LPVOID*) &pDisp) == S_OK);
- m_IApp.AttachDispatch(pDisp);
- pUnk->Release();
- else
- VERIFY(m_IApp.CreateDispatch(clsid) == TRUE);
- m_IApp.SetVisible(TRUE);
- else
- AfxMessageBox("Acad.Application is not registered!");
- EndWaitCursor();
- This code snippet is to be used with #import.
- // your location of acad.tlb may vary
- #import "c:\acad2k\acad.tlb" raw_interfaces_only, raw_native_types,
- no_namespace, named_guids
- CComQIPtr<IAcadApplication, &IID_IAcadApplication> gpApp;
- // start Acad
- HRESULT InitAcad()
- HRESULT hr = S_OK;
- CLSID clsid;
- // get acad running first
- hr = CLSIDFromProgID(L"AutoCAD.Application", &clsid);
- if(FAILED(hr))
- return hr;
- CComPtr<IUnknown> pIUnk;
- hr = GetActiveObject(clsid, NULL, pIUnk);
- if(!pIUnk)
- hr = CoCreateInstance(clsid, NULL, CLSCTX_LOCAL_SERVER,
- IID_IAcadApplication, (void**)&gpApp);[
- else
- gpApp = pIUnk;
- if(FAILED(hr) || !gpApp)
- return hr;
- gpApp->put_Visible(VARIANT_TRUE);
- return hr;
