查看: 787|回复: 0
[图块] Bind-as-Insert, using Visual LISP?
已领礼包: 145个
发表于 2021-1-12 01:40:43 | 显示全部楼层 |阅读模式
问题:
How to perform a bind-as-insert an Xref, using Visual LISP?
解答:
In AutoCAD , the BINDTYPE system variable was introduced.  By setting it
to 1, a bind-as-insert is performed:
(setvar "BINDTYPE" 1)
(command "_-xref" "_bind" "MYBLOCK")
(setvar "BINDTYPE" 0)
Using Visual Lisp, the following code will accomplish the same task in AutoCAD
.  See below:
  1. (defun c:BindInsert ( / appAcad docActive colBlocks objBlk)
  2.    (vl-load-com) ;load ActiveX
  3.    (setq appAcad (vlax-get-acad-object)
  4.          docActive (vla-get-ActiveDocument appAcad)
  5.    ) ;setq
  6.    ;;get the blocks collection
  7.    (setq colBlocks (vla-get-blocks docActive))
  8.    (vlax-for objBlk colBlocks
  9.       ;;Is the block an xref?
  10.       (if (= (vlax-get-property objBlk 'IsXref) :vlax-true)
  11.          ;;if True, then bind it as an insert
  12.          (vlax-invoke-method objBlk "bind" :vlax-true)
  13.       ) ;if
  14.       (vlax-release-object objBlk)
  15.    ) ;vlax-for
  16.    ;;release objects from memory
  17.    (vlax-release-object colBlocks)
  18.    (vlax-release-object docActive)
  19. )
Note: In AutoCAD 2000/2000i, there is a problem with the Bind method.  The results
are opposite (i.e.  invoking the Bind method with :vlax-true does not bind the
xref as an insert).  In that case, the workaround is to change the argument
to :vlax-false.  This is not a problem in AutoCAD 2002.
GMT+8, 2024-4-29 13:33 , Processed in 0.164443 second(s), 25 queries , Gzip On.
© 2001-2024 Discuz! Team.
