查看: 772|回复: 0
[其他] 外部DWG创建 AcDbXRefGraph
发表于 2021-1-12 01:59:43 | 显示全部楼层 |阅读模式
问题:
In ObjectARX there only seems to be one function to create an AcDbXRefGraph
of a drawing, this function is called acedGetCurDwgXRefGraph.
The problem is that this only works on the current drawing!! How can I create
an AcDbXRefGraph of an external drawing (AcDbDatabase) that I have read in?
解答:
Here is a function to do the trick.
  1. // ObjectARX defined commands
  2. #include "StdAfx.h"
  3. #include "StdArx.h"
  4. // function to fill in an AcDbXrefGraph with a completed graph of the current drawing's xrefs.
  5. // Returns Acad::eOk if successful.
  6. Acad::ErrorStatus GetXrefGraph (AcDbDatabase *dwgDb, AcDbXrefGraph& graph);
  7. // This is command 'TEST'
  8. void asdktest()
  9. {
  10. // lock the document
  11. AcAxDocLock docLock;
  12. // now read in an external drawing
  13. AcDbDatabase *db = new AcDbDatabase (false);
  14. // if we created the db ok
  15. if (db != NULL)
  16. {
  17.   Acad::ErrorStatus es;
  18.   // try and read in the drawing
  19.   es = db->readDwgFile ("c:\\temp\\114-AB1B2.dwg");
  20.   // if ok
  21.   if (es == Acad::eOk)
  22.   {
  23.    AcDbXrefGraph graph;
  24.    // try out our new function
  25.    GetXrefGraph (db, graph);
  26.    // a little test to see if it worked
  27.    acutPrintf ("\nNumber of nodes = %d", graph.numNodes ());
  28.   }
  29.   delete db;
  30. }
  31. }
GMT+8, 2024-4-29 06:48 , Processed in 0.148358 second(s), 25 queries , Gzip On.
© 2001-2024 Discuz! Team.
