查看: 524|回复: 0
Define a localized command name in the .NET API
发表于 2021-1-12 18:01:43 | 显示全部楼层 |阅读模式
问题:
In ARX I can define both globalized and localized command name. Is there a similar way to define localized command name in the .Net API? Or should I simply define two command methods which call the same function?
解答:
There are a few signatures of CommandMethodAttribute that have a parameter of local command name id. For example:
CommandMethodAttribute(
System.String groupName,
System.String globalName,
System.String localizedNameId,
Autodesk.AutoCAD.Runtime.CommandFlags flags)
Autodesk.AutoCAD.Runtime.CommandFlags flags,
System.String helpTopic)
System.Type contextMenuExtensionType)
System.Type contextMenuExtensionType,
System.String helpFileName,
This example uses the first signature to demonstrate how to use the parameter of localizedNameId:
    public class BzhCommands
        [CommandMethod("CmdGroup", "TestCommand", "LocalNameID", CommandFlags.Transparent)]
        static public void testLocalCommandName()
            Editor ed = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor;
            ed.WriteMessage("\nTest command.");
The third parameter is a String ID pointing to a localized command name in a resource file embedded into the assembly dll. Please note that the key point is that the name of the resource file must be named after the command class.(BzhCommands in this example) Therefore the name of the resource file must be BzhCommands.resx. If the name of the resource file is incorrect, AutoCAD will reject to load the assembly dll though it can be compiled without errors.
The attached C# project defines a localized command name. (BzhTestCommand)
附件是完整工程:
CsTestLocalCmdName.zip (9.17 KB, 下载次数: 0, 售价: 30 D豆)
GMT+8, 2024-4-29 15:28 , Processed in 0.185129 second(s), 29 queries , Gzip On.
© 2001-2024 Discuz! Team.
