查看: 1250|回复: 0
[其他] 利用ARX从AUTOLISP创建匿名组
发表于 2021-1-16 20:44:49 | 显示全部楼层 |阅读模式
Create an anonymous group from Visual LISP with help from ARX
问题:
DevNote TS36234 describes how to create an anonymous group from VBA, with the
help of an ARX application that was supplied.  Is it possible to call this ARX
application directly from Lisp?  Is it also possible to return the Object ID
of the newly-created group to the Lisp function, as well?
解答:
The attached ARX project is slightly different from the one available in DevNote
(TS36234), in this example acedDefun() is used to define the command
acdbAddAnonGrpRet2Lsp() as an external Lisp function.  It is further modified
to return a list, containing the new group's ObjectID, to the external Lisp
function, as well.
  1. // ObjectARX defined commands
  2. #include "StdAfx.h"
  3. #include "StdArx.h"
  4. // This is command 'ACDBADDANONGRPRET2LSP'
  5. int acdbAddAnonGrpRet2Lsp()
  6. {
  7.    // TODO: Implement the command
  8.    resbuf *pArg =acedGetArgs () ;
  9.    struct resbuf *startRb = NULL;
  10.    AcDbGroup *pGroup = new AcDbGroup();
  11.    AcDbObjectId grpId;
  12.    AcDbDictionary *pGroupDict;
  13.    Acad::ErrorStatus es;
  14.    AcApDocument *curDoc;
  15.    //get the group dictionary
  16.    AcDbDatabase *pDb = acdbHostApplicationServices()->workingDatabase();
  17.    if (Acad::eOk == (es = acDocManager->lockDocument(curDoc=acDocManager->curDocument())))
  18.       es = pDb->getGroupDictionary(pGroupDict,AcDb::kForWrite);
  19.    if (es != Acad::eOk)
  20.       return es;
  21.    //make an anonymous entry
  22.    if ((es = pGroupDict->setAt("*", pGroup, grpId)) == Acad::eOk) {
  23.       //retrieve its name char *pNam;
  24.       pGroup->close();
  25.    }
  26.    // create a resbuf with our ObjectID in it
  27.    struct resbuf *newRb = acutBuildList (RTLONG, grpId, RTNONE);
  28.    // if ok
  29.    if (newRb != NULL) {
  30.       // if this is the first time we've done this
  31.       if (startRb == NULL) {
  32.          // then set this as the start
  33.          startRb = newRb;
  34.       }
  35.       // otherwise add it to the end of our list
  36.       else {
  37.          // create a pointer to the beginning of our resbuf list
  38.          struct resbuf *ptr = startRb;
  39.          // find the end of our list
  40.          while (ptr->rbnext != NULL)
  41.             ptr = ptr->rbnext;
  42.          // now attach our newly create resbuf to the end
  43.          ptr->rbnext = newRb;
  44.       }
  45.    }
  46.    pGroupDict->close();
  47.    acDocManager->unlockDocument(curDoc);
  48.    acedRetList(startRb);
  49.    acutRelRb(startRb);
  50.    return (RTNORM);
  51. }
For the most part, the following Lisp code is a direct translation of the VBA
code from the DevNote (TS36234):
下面是LISP代码:
游客,本帖隐藏的内容需要积分高于 30 才可浏览,您当前积分为 0
GMT+8, 2024-4-29 09:58 , Processed in 0.180764 second(s), 25 queries , Gzip On.
© 2001-2024 Discuz! Team.
