查看: 1257|回复: 0
使用 acedInvoke 调用 LISP函数
发表于 2021-1-16 21:11:37 | 显示全部楼层 |阅读模式
Calling Lisp function using acedInvoke
问题:
I am using acedInvoke to call a Lisp function but I get a return value that equals RTERROR (5001). What am I missing ?
解答:
The Lisp function must be defined as a command as shown here :
  1. ;;; (defun DoIt() Define the Lisp function as a command using c:
  2. (defun c:DoIt()
  3.   (setq pntA (getpoint "\nPick A")
  4.         pntB (getpoint pntA "\nPick B")
  5.   )
  6.   (grdraw pntA pntB 1 2)
  7. )
Here is the sample code to call the Lisp command using acedInvoke :
  1. <DllImport("acad.exe", CallingConvention:=CallingConvention.Cdecl, EntryPoint:="acedInvoke")> _
  2. Private Shared Function acedInvoke(ByVal args As IntPtr, ByRef result As IntPtr) As Integer
  3. End Function
  4. . . .
  5. Dim m_args As New Autodesk.AutoCAD.DatabaseServices.ResultBuffer()
  6. 'Returns RTERROR (5001)
  7. 'm_args.Add(New Autodesk.AutoCAD.DatabaseServices.TypedValue(5005, "DoIt"))
  8. 'Returns RTNORM (5100)
  9. m_args.Add(New Autodesk.AutoCAD.DatabaseServices.TypedValue(5005, "c:DoIt"))
  10. Dim m_ResultBuf As IntPtr = IntPtr.Zero
  11. Dim m_Return As Integer = acedInvoke(m_args.UnmanagedObject, m_ResultBuf)
  12. m_args.Dispose()
  13. MsgBox(String.Format("Return value {0}", m_Return))
GMT+8, 2024-4-29 03:11 , Processed in 0.349408 second(s), 25 queries , Gzip On.
© 2001-2024 Discuz! Team.
