查看: 1062|回复: 0
如何像在文本对象ObjectAdded事件,在VBA中修改一个图形对象
发表于 2021-1-26 16:22:58 | 显示全部楼层 |阅读模式
问题:
How to modify a drawing object inside a VBA event handler like the document object’s ObjectAdded event
解答:
Consider this: Using WithEvents in VB(A), you are trying to modify an object passed to the document's ObjectAdded, ObjectModified events, or drawing object's Modified event. However, this results in Error that look similar to this: "Object was opened for read" or similar. How can you work around this?
Firstly, modifying objects in events such as these is generally not recommended and not worth the trouble you might face later; especially if you are trying to modify objects that are already in the process of being modified. That is rarely a good idea.
However, if you absolutely need to modify objects in event handlers, there are some ways to achieve it.
ActiveX events are modeled on ObjectARX Event handling mechanism (reactors). There are many notifications when object is in an open state (for Read, Write or Notify) so in general, you cannot change it from within the event, evidenced by the fact for instance that the object is passed ByVal to the ObjectAdded event. You can however access any object for write in the CommandEnded event. So, you can set some global flags, trigger them in CommandStart, store ObjectIds during ObjectAdded and use the Ids in CommandEnded to change the relevant objects. For example, the code below will alter any line added to the document. This is the solution specific to VBA. For VB you have additional complexity of attaching events to docs (but that is a topic for another blog post).
下面是VBA代码
  1. Option Explicit
  2. Dim cIDs As New Collection ' collection for line IDs to be modified
  3. Dim bFlag As Boolean   ' flag to indicate when modification needed
  4. Private Sub AcadDocument_BeginCommand(ByVal CommandName As String)
  5.   ' Here we can set the flag ONLY for particular command.
  6.   ' For simplicity, set always in this sample
  7.   bFlag = True
  8.   Call ClearCollection(cIDs)'Just in case
  9.                             '(done already in EndCommand)
  10. End Sub
  11. Private Sub AcadDocument_ObjectAdded(ByVal Object As Object)
  12.   If bFlag Then ' If flag on and line - add the ID to the collection
  13.       Dim obj As AcadObject
  14.       Set obj = Object
  15.       If obj.ObjectName = "AcDbLine" Then
  16.           cIDs.Add obj.ObjectID
  17.       End If
  18.   End If
  19. End Sub
  20. Private Sub AcadDocument_EndCommand(ByVal CommandName As String)
  21.   ' Set all line start points to origin and color to magenta
  22.   If bFlag Then
  23.     Dim pntO(0 To 2) As Double
  24.     pntO(0) = 0#: pntO(1) = 0#: pntO(2) = 0#
  25.     Dim id As Variant
  26.     For Each id In cIDs
  27.       Dim line As AcadLine
  28.       Set line = ThisDrawing.ObjectIdToObject(id)
  29.       line.StartPoint = pntO
  30.       line.Color = acMagenta
  31.     Next id
  32.     ' Reset flag and collection
  33.     bFlag = False
  34.     Call ClearCollection(cIDs)
  35.   End If
  36. End Sub
  37. Private Sub ClearCollection(cCol As Collection)
  38.   Dim iCnt As Long
  39.   For iCnt = 1 To cCol.Count
  40.     cCol.Remove 1 ' Since collections are reindexed
  41.                   'automatically, remove the first member
  42.   Next iCntEnd
  43. End Sub
GMT+8, 2024-4-29 05:15 , Processed in 0.343024 second(s), 25 queries , Gzip On.
© 2001-2024 Discuz! Team.
