查看: 1302|回复: 0
AUTOCAD 2015中新增的Audit API
发表于 2021-1-26 16:26:01 | 显示全部楼层 |阅读模式
问题:
Audit API - New in AutoCAD 2015
解答:
From AutoCAD 2015, you can programmatically audit the drawing file using the new Database API “Audit” . You can also try fixing the issues in the drawing file using API’s argument. This API is present in ObjectARX and .NET.
In ObjectARX – use Acad::ErrorStatus acedAudit(AcDbDatabase* , bool , bool ) API.
  1. [CommandMethod("AuditTest")]
  2. publicvoid AuditTest() // This method can have any name
  3. {
  4.     Document doc = Application.DocumentManager.MdiActiveDocument;
  5.     Editor ed = doc.Editor;
  6.     try
  7.     {
  8.         //to fix the error or not
  9.         bool bFixErrors = true;
  10.         //to show the message in commandline or not
  11.         bool becho = true;
  12.         //call audit API
  13.         doc.Database.Audit(bFixErrors, becho);
  14.     }
  15.     catch
  16.     {
  17.         ed.WriteMessage("Unable to audit the drawing\n");
  18.     }
  19. }
GMT+8, 2024-4-29 09:12 , Processed in 0.407100 second(s), 25 queries , Gzip On.
© 2001-2024 Discuz! Team.
