查看: 1118|回复: 0
在contextual tab selection rule中检测是否选择了自定义实体
发表于 2021-2-3 09:10:00 | 显示全部楼层 |阅读模式
Checking if custom entity is selected inside a contextual tab selection rule
问题:
I'm using the solution from DevNote AN20090811-2 [Using custom contextual ribbon tabs], but it does not work for my custom entities. I pass in the name of my entity that is displayed in the Property Palette, but still, Selection.ContainsOnly("MyEntity") is always false.
解答:
The selection rule is using the .NET type name of the selected entities. So if your entity does not have a .NET wrapper then the selection set will know it as the type name of the .NET wrapper of your custom entity's base class - i.e. if your entity is based on AcDbEntity then the selection set will know it as type "Entity"
So, if you want to check if only your custom entities are selected (and they do not have a .NET wrapper class), then create a utility assembly which iterates through the Selection set and checks each entity's RxClass.Name.
We could simply modify the sample code in DevNote AN20090811-2 the following way to check if only my custom entities called "MyLine" are selected:
游客,本帖隐藏的内容需要积分高于 30 才可浏览,您当前积分为 0
GMT+8, 2024-4-29 04:09 , Processed in 0.354823 second(s), 25 queries , Gzip On.
© 2001-2024 Discuz! Team.
