查看: 585|回复: 0
[求助] 为何下面代码无法得到close后的返回值
已领礼包: 2个
发表于 2021-3-11 16:45:54 | 显示全部楼层 |阅读模式
  1.   (setq #layout (vla-get-activelayout #doc))
  2.   (setq PrinterConfigPath (Vlax-Get (Vlax-Get (Vlax-Get (Vlax-Get-Acad-Object) 'Preferences) 'Files) 'PrinterConfigPath))
  3.
  4.   (defun c:plotdiy/Form2#OnInitialize (/ DeviceNames StyleTableNames)
  5.     (dcl-Control-SetList plotdiy/Form2/ComboBox1 (setq DeviceNames (vlax-safearray->list (vlax-variant-value (vla-GetPlotDeviceNames #layout)))))
  6.     (dcl-Control-SetList plotdiy/Form2/ComboBox2 (setq StyleTableNames (vlax-safearray->list (vlax-variant-value (vla-GetPlotStyleTableNames #layout)))))
  7.     (if (member "ToPDF DIY.pc3" DeviceNames)
  8.       (dcl-Control-SetText plotdiy/Form2/ComboBox1 "ToPDF DIY.pc3")
  9.       (dcl-Control-SetText plotdiy/Form2/ComboBox1 "DWG To PDF.pc3")
  10.     )
  11.     (if (member "白图黑框.ctb" StyleTableNames)
  12.       (dcl-Control-SetText plotdiy/Form2/ComboBox2 "白图黑框.ctb")
  13.       (dcl-Control-SetText plotdiy/Form2/ComboBox2 "monochrome.ctb")
  14.     )
  15.     (dcl-Control-SetText plotdiy/Form2/TextBox7
  16.       (strcat
  17.         (vla-item (vlax-get (vlax-create-object "WScript.Shell" ) 'SpecialFolders) "Desktop")
  18.         "\\批量导PDF"
  19.       )
  20.     )
  21.   )
  22.   (defun c:plotdiy/Form2/TextButton1#OnClicked (/)
  23.     (startapp "explorer"
  24.       (strcat
  25.         PrinterConfigPath
  26.         "\"
  27.         (dcl-Control-getText plotdiy/Form2/ComboBox1 "ToPDF DIY.pc3")
  28.       )
  29.     )
  30.   )
  31.   (defun c:plotdiy/Form2/TextButton2#OnClicked (/)
  32.     (startapp "explorer"
  33.       (strcat
  34.         PrinterConfigPath
  35.         "\\Plot Styles\"
  36.         (dcl-Control-getText plotdiy/Form2/ComboBox2 "ToPDF DIY.pc3")
  37.       )
  38.     )
  39.   )
  40.   (defun c:plotdiy/Form2/TextButton3#OnClicked (/ fd)
  41.     (if (setq fd (GetFolder "选择批量打印文件夹" 12))
  42.       (dcl-Control-SetText plotdiy/Form2/TextBox7 fd)
  43.     )
  44.   )
  45.   (defun c:plotdiy/Form2/TextButton4#OnClicked (/)
  46.     (dcl-Form-Close plotdiy/Form2 1)
  47.   )
  48.   (defun c:plotdiy/Form2/TextButton5#OnClicked (/)
  49.     (dcl-Form-Close plotdiy/Form2 3)
  50.   )
  51.   (defun c:plotdiy/Form2/TextButton6#OnClicked (/)
  52.     (dcl-Form-Close plotdiy/Form2 4)
  53.   )
  54.   (defun c:plotdiy/Form2/OptionButton1#OnClicked (Value /)
  55.     (dcl-Control-SetValue plotdiy/Form2/OptionButton2 0)
  56.   )
  57.   (defun c:plotdiy/Form2/OptionButton2#OnClicked (Value /)
  58.     (dcl-Control-SetValue plotdiy/Form2/OptionButton1 0)
  59.   )
  60.   (defun c:plotdiy/Form2/OptionButton3#OnClicked (Value /)
  61.     (dcl-Control-SetValue plotdiy/Form2/OptionButton4 0)
  62.   )
  63.   (defun c:plotdiy/Form2/OptionButton4#OnClicked (Value /)
  64.     (dcl-Control-SetValue plotdiy/Form2/OptionButton3 0)
  65.   )
  66.   (Load_ODCL_Project "plotdiy" T nil nil)
  67.   (setq Result (dcl-Form-Show plotdiy/Form2))
  68.   (princ)
  69.   (princ (itoa Result))
GMT+8, 2024-5-15 11:03 , Processed in 0.349038 second(s), 27 queries , Gzip On.
© 2001-2024 Discuz! Team.
