查看: 168|回复: 2
[标注] 这个LSP加载后是乱码
发表于 2023-3-26 16:44:08 | 显示全部楼层 |阅读模式
  1. (defun c:bb()(vl-load-com)(setq AA (getvar "clayer"))(setq layer "文字     text")(if (not (tblsearch "layer" layer ))
  2. (progn (command "layer" "new" "文字     text" "s" "文字     text" "C" 212 "" "L" "Continuous" "" "LW" 0.2 "" "")))
  3. (COMMAND "CLAYER" layer)(setvar "texteval" 1)(setvar "cmdecho" 0)(setq vv (getvar "osmode"))
  4. (setq ht (getreal "\n-->标注字高默认:2.5)") zk (getreal "\n-->标注字宽默认:0.7)"))
  5. (if (= ht nil) (setq ht 2.5))(if (= zk nil) (setq zk 0.7))(setq zj (/ ht 3))(setq n 0)
  6. (while (= n 0)(setq TXT (getstring "\n-->请输入文字:"))(setvar "osmode" 33)
  7. (if (/= txt "")(setq   p1 (getpoint "\n-->请指定点坐标:")))
  8. (if (= txt "") (setq n 1)(zcx)))(setvar "osmode" vv)(princ))
  9. (defun zcx()(setvar "osmode" 0)
  10. (setq p2 (polar p1 0 10) a1 (car p1 ) c1 (car p2) vx (* (- (strlen TXT) 0.2) (* ht 0.75))
  11. le vx bb_sp(vla-get-Modelspace (vla-get-activeDocument (vlax-get-acad-object))))
  12. (if (< c1 a1)(setq pp (polar p2 pi le)p3 (polar pp (/ pi 2) zj))
  13. (setq pp (polar p2 0 le) p3 (polar p2 (/ pi 2) zj)))
  14. (vla-addline bb_sp (vlax-3d-point p1) (vlax-3d-point p2))
  15. (setq en1 (entlast))(vla-addline bb_sp (vlax-3d-point p2) (vlax-3d-point pp))
  16. (setq en2 (entlast))(vla-addtext  bb_sp TXT (vlax-3d-point p3) ht)
  17. (entmod (subst (cons 41 zk) (assoc 41 (entget (entlast)))(entget (entlast))))
  18. (setq en3 (entlast))(setq ent1 (entget en1)ent2 (entget en2) ent3 (entget en3))
  19. (setq le1 (caadr (textbox ent3)))(setq le (* 1.2 le1) jl (* 0.1 le1))
  20. (while (= (car (setq mouse (grread t 0 0))) 5)(setq pt (cadr mouse))
  21. (if (>= (car pt)(car p1))(progn (setq ent1 (subst (cons 11 pt)(assoc 11 ent1) ent1))
  22. (entmod ent1)(setq ent2 (subst (cons 10 pt)(assoc 10 ent2) ent2))
  23. (entmod ent2)(setq ent2 (subst (cons 11 (polar pt 0 le))(assoc 11 ent2) ent2))
  24. (entmod ent2)(setq ent3 (subst '(72 . 0) (assoc 72 ent3) ent3))
  25. (setq ent3 (subst (cons 10 (list (+ (car pt) jl) (+ (cadr pt) zj)))(assoc 10 ent3) ent3))
  26. (entmod ent3))(progn(setq ent1 (subst (cons 11 pt)(assoc 11 ent1) ent1))
  27. (entmod ent1)(setq ent2 (subst (cons 10 pt)(assoc 10 ent2) ent2))
  28. (entmod ent2)(setq ent2 (subst (cons 11 (polar pt pi le))(assoc 11 ent2) ent2))
  29. (entmod ent2)(setq ent3 (subst '(72 . 2) (assoc 72 ent3) ent3))
  30. (setq ent3 (subst (cons 10 (list (- (car pt) jl) (+ (cadr pt) zj)))(assoc 10 ent3) ent3))
  31. (setq ent3 (subst (cons 11 (list (- (car pt) jl) (+ (cadr pt) zj)))(assoc 11 ent3) ent3))
  32. (entmod ent3))))(princ))
 楼主| 发表于 2023-3-26 16:45:25 | 显示全部楼层
->鏍囨敞瀛楅珮榛樿?:2.5)
-->鏍囨敞瀛楀?榛樿?:0.7)
-->璇疯緭鍏ユ枃瀛?
 楼主| 发表于 2023-3-26 16:46:33 | 显示全部楼层
就是这样子,全是乱码
GMT+8, 2024-6-7 18:14 , Processed in 0.217524 second(s), 33 queries , Gzip On.
© 2001-2024 Discuz! Team.
