查看: 308|回复: 4
[分享] WEB CAD SDK 集成后怎么实现参数化绘图(在线编辑CAD)
发表于 2023-11-30 09:28:15 | 显示全部楼层 |阅读模式
前言
MxCAD 的WEB CAD SDK提供了参数化绘图的功能, 我们可以通过查看继承自McDbEntity的类的所有实例,它们都可以进行参数化的绘图。
首先我们应该在页面上显示一张图纸, 请根据mxcad入门文档的说明或者通过查看github| gitee存储的初始化各种示例项目查看代码来实现显示图纸的页面。
点的绘制
参数化绘制一个CAD中的点:
import { MxCpp, McDbPoint, McCmColor } from "mxcad"
const mxcad = MxCpp.App.getCurrentMxCAD()
const point = new McDbPoint()
const color = new McCmColor()
color.setRGB(0, 255, 255)
point.trueColor = color
point.setPosition(200, 200)
mxcad.drawEntity(point)
效果图:
多行文字
绘制多行文字代码如下:
import { MxCpp, McGePoint3d, McCmColor, McDb, McDbMText } from "mxcad"
const mText = new McDbMText()
const textId = mxcad.drawEntity(mText)
const text = textId.getMcDbEntity() as McDbMText
text.attachment = McDb.AttachmentPoint.kTopLeft
text.contents = "内容 \\P 内容"
text.location = new McGePoint3d(10, 20)
text.trueColor = new McCmColor(255, 0, 255)
text.textHeight = 10
mxcad.updateDisplay()
效果图:
单行文字
绘制单行文本代码如下:
import { MxCpp, McGePoint3d, McCmColor, McDb, McDbText } from "mxcad"
const text = new McDbText()
text.widthFactor = 1
text.horizontalMode = McDb.TextHorzMode.kTextCenter
text.verticalMode = McDb.TextVertMode.kTextBottom
text.textString = "内容"
text.position = new McGePoint3d(-10, -20)
text.height = 10
mxcad.drawEntity(text)
效果图:
对齐标注
绘制对齐标注尺寸代码如下:
import { MxCpp, McGePoint3d, McCmColor, McDb, McDbAlignedDimension } from "mxcad"
const mDimension = new McDbAlignedDimension()
const dimensionId = mxcad.drawEntity(mDimension)
const dimension = dimensionId.getMcDbEntity() as McDbAlignedDimension
dimension.xLine1Point = new McGePoint3d(0, 255)
dimension.xLine2Point = new McGePoint3d(30, 60)
dimension.dimLinePoint = new McGePoint3d(88, 88)
dimension.textAttachment = McDb.AttachmentPoint.kTopLeft
dimension.trueColor = new McCmColor(200, 255, 0)
dimension.oblique = 0
效果图:
旋转标注
绘制旋转标注尺寸代码如下:
import { MxCpp, McGePoint3d, McCmColor, McDb, McDbRotatedDimension } from "mxcad"
const mDimension = new McDbRotatedDimension()
const dimension = dimensionId.getMcDbEntity() as McDbRotatedDimension
dimension.xLine1Point = new McGePoint3d(100, -137)
dimension.xLine2Point = new McGePoint3d(161,30)
dimension.dimLinePoint = new McGePoint3d(80, -60)
dimension.textRotation = 0.23
dimension.rotation = 0
效果图:
绘制直线
绘制直线代码如下:
import { MxCpp, McCmColor, McDbLine } from "mxcad"
const line = new McDbLine(0, 0, 0, -80, -80, 0)
line.trueColor = new McCmColor(255, 0, 0)
mxcad.drawEntity(line)
效果图:
绘制圆弧
绘制圆弧代码如下:
import { MxCpp, McGePoint3d, McDbArc, McCmColor } from "mxcad"
const arc = new McDbArc()
arc.center = new McGePoint3d(-100, -100),
arc.radius = 20
arc.startAngle = Math.PI / 2
arc.endAngle = Math.PI * 3 / 2
arc.trueColor = new McCmColor(255, 233, 0)
mxcad.drawEntity(arc)
效果图:
绘制椭圆
绘制椭圆代码如下:
import { MxCpp, McGePoint3d, McDbEllipse, McCmColor, McGeVector3d } from "mxcad"
const ellipse = new McDbEllipse()
ellipse.center = new McGePoint3d(-200, -200),
ellipse.majorAxis = new McGeVector3d(0, 300, 0)
ellipse.minorAxis = new McGeVector3d(33, 0, 0)
ellipse.radiusRatio = 0.5
ellipse.startAngle = Math.PI / 2
ellipse.endAngle = Math.PI * 3 / 2
ellipse.trueColor = new McCmColor(255, 233, 0)
mxcad.drawEntity(ellipse)
效果图:
交互绘制
如果上述位置属性是用户通过点击或者输入框输入,mxcad就提供了这样一套用于获取用户输入并在绘制中得到输入的机制,最频繁的应该是鼠标点击输入。
1、通过鼠标点击获取CAD图纸中的坐标位置,代码如下:
import { MxCADUiPrPoint } from "mxcad"
const getPoint = new MxCADUiPrPoint()
const point = await getPoint.go()
console.log(point)
上述代码打印的就是一个坐标点了, 其坐标点是用户通过鼠标点击获取到的对应的图纸坐标位置
2、通过输入框输入值, 来确定除了坐标以外的其他参数,代码如下:
const input = document.createElement("input")
input.addEventListener("keydown", (e: KeyboardEvent) => {
    // 设置传输命令行消息数据
    MxFun.setCommandLineInputData((e.target as HTMLInputElement).value, e.keyCode);
document.body.appendChild(input)
mxcad中引用了mxdraw 下载依赖时会自动下载, 所有我们只要安装了mxcad就可以使用mxdraw
如上代码所示, 我们传入用户输入的内容和对应按键的keyCode值
const getInt = new MxCADUiPrInt()
const getKey = new MxCADUiPrKeyWord
const getStr = new MxCADUiPrString()
getInt.setMessage("提示用户输入数字:")
const intVal = await getInt.go()
console.log(intVal)
getKey.setMessage("提示用户关键词 A、 B、 C:")
getKey.setKeyWords("A B C")
const keyVal = await getKey.go()
console.log(keyVal)
getStr.setMessage("提示用户输入字符串:")
const strVal = await getStr.go()
console.log(strVal)
上述代码会在用户输入对应类型的数据后按下回车键(Enter或者Esc)才会往下执行, 通过setMessage设置提示最终得到用户输入的数据, 通过这些数据进行参数化绘图。
最后这些设置的用户提示通过下面代码获得:
import { MxFun } from "mxdraw"
MxFun.listenForCommandLineInput(({ msCmdTip, msCmdDisplay, msCmdText }) => {
    console.log(msCmdTip, msCmdDisplay, msCmdText)
如果你无法理解上述某个函数的意思,可以在mxdraw API文档或者mxcad API文档中查看对应的APi说明
参数化绘制文字的完整流程
下面简单实现一个的参数化绘制文字的流程:
import { MxCADUiPrInt, MxCADUiPrKeyWord, MxCADUiPrString, MxCADUiPrPoint, McDbText, MxCpp } from "mxcad"
MxFun.addCommand("Mx_draw_Text", async ()=> {
    const getKey = new MxCADUiPrKeyWord()
    getPoint.setMessage("请点击确定文字位置")
    const position = await getPoint.go()
    if(!position) return
    text.position = position
    getInt.setMessage("请输入文字高度")
    const height = await getInt.go()
    if(!height) return
    text.height = height
    getKey.setMessage("选择水平对齐方式 快捷键 L: 左对齐 C: 居中对齐 R: 右对齐 A: 水平对齐 M: 垂直中间对齐 F: 自适应")
    getKey.setKeyWords("L C R A M F")
    await getKey.go()
    if(getKey.isKeyWordPicked("L")) text.horizontalMode = McDb.TextHorzMode.kTextLeft
    if(getKey.isKeyWordPicked("C")) text.horizontalMode = McDb.TextHorzMode.kTextCenter
    if(getKey.isKeyWordPicked("R")) text.horizontalMode = McDb.TextHorzMode.kTextRight
    if(getKey.isKeyWordPicked("A")) text.horizontalMode = McDb.TextHorzMode.kTextAlign
    if(getKey.isKeyWordPicked("M")) text.horizontalMode = McDb.TextHorzMode.kTextMid
    if(getKey.isKeyWordPicked("F")) text.horizontalMode = McDb.TextHorzMode.kTextFit
    getStr.setMessage("请输入文字内容")
    const str = await getStr.go()
    if(!str) return
    text.textString = str
已领礼包: 225个
发表于 2023-12-1 08:34:37 | 显示全部楼层
谢谢分享!!!!!
已领礼包: 225个
发表于 2023-12-4 08:02:21 | 显示全部楼层
谢谢分享!!!!!
已领礼包: 225个
发表于 2023-12-6 08:38:09 | 显示全部楼层
谢谢分享!!!!!!
已领礼包: 225个
发表于 2023-12-15 08:20:15 | 显示全部楼层
感谢分享!!!
GMT+8, 2024-5-15 20:09 , Processed in 0.353330 second(s), 38 queries , Gzip On.
© 2001-2024 Discuz! Team.
