查看: 13005|回复: 28
[转贴]:VLAX类库
已领礼包: 181个
发表于 2003-1-11 10:50:19 | 显示全部楼层 |阅读模式
提供Lisp接口,增强VBA的开发功能。以下是调用前应注意的。
  1.   [FONT=courier new]
  2. AutoCAD 或 Visual LISP 启动时并没有自动加载 ActiveX 功能,所以,如果要使用 ActiveX,就必须确保已加载了 ActiveX。下述函数可以完成该任务:
  3. (vl-load-com)
  4. 如果没有加载 ActiveX 支持程序,那么运行 vl-load-com 可以初始化 AutoLISP ActiveX 环境。如果已加载 ActiveX,vl-load-com 将不做任何工作。
  5.   [/FONT]
  2. VERSION 1.0 CLASS
  3. BEGIN
  4.   MultiUse = -1  'True
  5. END
  6. Attribute VB_Name = "VLAX"
  7. Attribute VB_GlobalNameSpace = False
  8. Attribute VB_Creatable = False
  9. Attribute VB_PredeclaredId = False
  10. Attribute VB_Exposed = False
  11. ' VLAX.CLS v1.4 (Last updated 8/27/2001)
  12. ' Copyright 1999-2001 by Frank Oquendo
  13. '
  14. ' Permission to use, copy, modify, and distribute this software
  15. ' for any purpose and without fee is hereby granted, provided
  16. ' that the above copyright notice appears in all copies and
  17. ' that both that copyright notice and the limited warranty and
  18. ' restricted rights notice below appear in all supporting
  19. ' documentation.
  20. '
  21. ' FRANK OQUENDO (THE AUTHOR) PROVIDES THIS PROGRAM "AS IS" AND WITH
  22. ' ALL FAULTS. THE AUTHOR SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY
  23. ' OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE.  THE AUTHOR
  24. ' DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE
  25. ' UNINTERRUPTED OR ERROR FREE.
  26. '
  27. ' Use, duplication, or disclosure by the U.S. Government is subject to
  28. ' restrictions set forth in FAR 52.227-19 (Commercial Computer
  29. ' Software - Restricted Rights) and DFAR 252.227-7013(c)(1)(ii)
  30. ' (Rights in Technical Data and Computer Software), as applicable.
  31. '
  32. ' VLAX.cls allows developers to evaluate AutoLISP expressions from
  33. ' Visual Basic or VBA
  34. '
  35. ' Notes:
  36. ' All code for this class module is publicly available througout various posts
  37. ' at [url]news://discussion.autodesk.com/autodesk.autocad.customization.vba.[/url] I do not
  38. ' claim copyright or authorship on code presented in these posts, only on this
  39. ' compilation of that code. In addition, a great big "Thank you!" to Cyrille Fauvel
  40. ' demonstrating the use of the VisualLISP ActiveX Module.
  41. '
  42. ' Dependencies:
  43. ' Use of this class module requires the following application:
  44. ' 1. VisualLISP
  45. Private VL As Object
  46. Private VLF As Object
  47. Private Sub Class_Initialize()
  48.     Set VL = ThisDrawing.Application.GetInterfaceObject("VL.Application.1")
  49.     Set VLF = VL.ActiveDocument.Functions
  50. End Sub
  51. Private Sub Class_Terminate()
  52.     Set VLF = Nothing
  53.     Set VL = Nothing
  54. End Sub
  55. Public Function EvalLispExpression(lispStatement As String)
  56.     Dim sym As Object, ret As Object, retval
  57.
  58.     Set sym = VLF.Item("read").funcall(lispStatement)
  59.     On Error Resume Next
  60.     retval = VLF.Item("eval").funcall(sym)
  61.     If Err Then
  62.         EvalLispExpression = ""
  63.     Else
  64.         EvalLispExpression = retval
  65.     End If
  66. End Function
  67. Public Sub SetLispSymbol(symbolName As String, value)
  68.     Dim sym As Object, ret, symValue
  69.
  70.     symValue = value
  71.     Set sym = VLF.Item("read").funcall(symbolName)
  72.     ret = VLF.Item("set").funcall(sym, symValue)
  73.     EvalLispExpression "(defun translate-variant (data) (cond ((= (type data) 'list) (mapcar 'translate-variant data)) ((= (type data) 'variant)
  74. (translate-variant (vlax-variant-value data))) ((= (type data) 'safearray) (mapcar 'translate-variant (vlax-safearray->list data))) (t data)))"
  75.     EvalLispExpression "(setq " & symbolName & "(translate-variant " & symbolName & "))"
  76.     EvalLispExpression "(setq translate-variant nil)"
  77. End Sub
  78. Public Function GetLispSymbol(symbolName As String)
  79.     Dim sym As Object, ret, symValue
  80.
  81.     symValue = value
  82.     Set sym = VLF.Item("read").funcall(symbolName)
  83.     GetLispSymbol = VLF.Item("eval").funcall(sym)
  84. End Function
  85. Public Function GetLispList(symbolName As String) As Variant
  86.    Dim sym As Object, list As Object
  87.    Dim Count, elements(), i As Long
  88.
  89.    Set sym = VLF.Item("read").funcall(symbolName)
  90.    Set list = VLF.Item("eval").funcall(sym)
  91.
  92.    Count = VLF.Item("length").funcall(list)
  93.
  94.    ReDim elements(0 To Count - 1) As Variant
  95.
  96.    For i = 0 To Count - 1
  97.         elements(i) = VLF.Item("nth").funcall(i, list)
  98.    Next
  99.
  100.    GetLispList = elements
  101.
  102. End Function
  103. Public Sub NullifySymbol(ParamArray symbolName())
  104.     Dim i As Integer
  105.
  106.     For i = LBound(symbolName) To UBound(symbolName)
  107.         EvalLispExpression "(setq " & CStr(symbolName(i)) & " nil)"
  108.     Next
  109. End Sub
  110.   [/FONT]
已领礼包: 181个
 楼主| 发表于 2003-1-11 10:53:21 | 显示全部楼层
下面的类库扩充了VBA处理曲线类对象的能力。
  3. BEGIN
  5. END
  6. Attribute VB_Name = "Curve"
  11. ' Curve.cls v1.3 (Last updated 12/18/2001)
  12. ' Copyright 2000, 2001 by Frank Oquendo
  13. '
  20. '
  26. '
  31. '
  32. ' Curve.cls allows developers to access the various VLAX-CURVE functions
  33. ' from Visual Basic or VBA.
  34. '
  35. ' Notes:
  36. ' I do not claim copyright or authorship of the code being wrapped by this module,
  37. ' only on this compilation of that code.
  38. '
  39. ' Dependencies:
  40. ' Use of this class module requires the following files:
  41. ' 1. VLAX.CLS - This file can be obtained by visiting [url]http://www.acadx.com[/url]
  42. Private objVLAX As VLAX
  43. Private mvarEntity As AcadEntity
  44. Private types(8) As String
  45. Private Sub Class_Initialize()
  46.     Set objVLAX = New VLAX
  47.     types(0) = "AcDbCircle": types(1) = "AcDbLine"
  48.     types(2) = "AcDbArc": types(3) = "AcDbSpline"
  49.     types(4) = "AcDb3dPolyline": types(5) = "AcDbPolyline"
  50.     types(6) = "AcDb2dPolyline": types(7) = "AcDbEllipse"
  51.     types(8) = "AcDbLeader"
  52. End Sub
  53. Private Sub Class_Terminate()
  54.     Set objVLAX = Nothing
  55. End Sub
  56. Public Property Set Entity(ent As AcadEntity)
  57.     Dim tmp As String, i As Long, bFound As Boolean
  58.
  59.     tmp = ent.ObjectName
  60.
  61.     For i = 0 To 8
  62.         If tmp = types(i) Then
  63.             Set mvarEntity = ent
  64.             bFound = True
  65.             Exit For
  66.         End If
  67.     Next
  68.
  69.     If Not bFound Then Err.Raise vbObjectError + 1, , "That entity is not a curve."
  70. End Property
  71. Public Property Get Entity() As AcadEntity
  72.     Set entityt = mvarEntity
  73. End Property
  74. Public Property Get CurveType() As String
  75.     CurveType = mvarEntity.ObjectName
  76. End Property
  77. Public Property Get Area() As Double
  78.     Dim retval As Double
  79.
  80.     With objVLAX
  81.         .SetLispSymbol "handle", mvarEntity.Handle
  82.         retval = .EvalLispExpression("(vlax-curve-getArea (handent handle))")
  83.         .NullifySymbol "handle"
  84.     End With
  85.     Area = retval
  86. End Property
  87. Public Property Get Closed() As Boolean
  88.     Dim retval As Boolean
  89.
  90.     With objVLAX
  91.         .SetLispSymbol "handle", mvarEntity.Handle
  92.         retval = .EvalLispExpression("(vlax-curve-isClosed (handent handle))")
  93.         .NullifySymbol "handle"
  94.     End With
  95.     Closed = retval
  96. End Property
  97. Public Property Get EndParameter() As Double
  98.     Dim retval As Double
  99.
  100.     With objVLAX
  101.         .SetLispSymbol "handle", mvarEntity.Handle
  102.         retval = .EvalLispExpression("(vlax-curve-getEndParam (handent handle))")
  103.         .NullifySymbol "handle"
  104.     End With
  105.     EndParameter = retval
  106. End Property
  107. Public Property Get EndPoint() As Variant
  108.     Dim retval As Variant, pt(0 To 2) As Double
  109.     Dim i As Long
  110.
  111.     With objVLAX
  112.         .SetLispSymbol "handle", mvarEntity.Handle
  113.         .EvalLispExpression "(setq lst (vlax-curve-getEndPoint (handent handle)))"
  114.         retval = .GetLispList("lst")
  115.         .NullifySymbol "handle", "lst"
  116.     End With
  117.
  118.     For i = 0 To 2
  119.         pt(i) = retval(i)
  120.     Next
  121.
  122.     EndPoint = pt
  123. End Property
  124. Public Function GetClosestPointTo(Point, Optional Extend As Boolean = False) As Variant
  125.     Dim retval As Variant, pt(0 To 2) As Double
  126.     Dim i As Long
  127.
  128.     With objVLAX
  129.         .SetLispSymbol "handle", mvarEntity.Handle
  130.         .SetLispSymbol "givenPt", Point
  131.         If Extend Then .EvalLispExpression "(setq ext T)"
  132.         .EvalLispExpression "(setq lst (vlax-curve-getClosestPointTo (handent handle) givenPt ext))"
  133.         retval = .GetLispList("lst")
  134.         .NullifySymbol "handle", "lst", "ext", "givenPt"
  135.     End With
  136.
  137.     For i = 0 To 2
  138.         pt(i) = retval(i)
  139.     Next
  140.
  141.     GetClosestPointTo = pt
  142. End Function
  143. Public Function GetDistanceAtParameter(Param As Double) As Double
  144.     Dim retval As Double
  145.
  146.     With objVLAX
  147.         .SetLispSymbol "handle", mvarEntity.Handle
  148.         .SetLispSymbol "param", Param
  149.         retval = .EvalLispExpression("(vlax-curve-getDistAtParam (handent handle) param)")
  150.         .NullifySymbol "handle", "param"
  151.     End With
  152.     GetDistanceAtParameter = retval
  153. End Function
  154. Public Function GetDistanceAtPoint(Point As Variant) As Double
  155.     Dim retval As Double
  156.
  157.     With objVLAX
  158.         .SetLispSymbol "handle", mvarEntity.Handle
  159.         .SetLispSymbol "point", Point
  160.         retval = .EvalLispExpression("(vlax-curve-getDistAtPoint (handent handle) point)")
  161.         .NullifySymbol "handle", "point"
  162.     End With
  163.     GetDistanceAtPoint = retval
  164. End Function
  165. Public Function GetFirstDerivative(Param As Double) As Variant
  166.     Dim retval As Variant
  167.
  168.     With objVLAX
  169.         .SetLispSymbol "handle", mvarEntity.Handle
  170.         .SetLispSymbol "param", Param
  171.         .EvalLispExpression "(setq lst (vlax-curve-getFirstDeriv (handent handle) param))"
  172.         retval = .GetLispList("lst")
  173.         .NullifySymbol "handle", "param", "lst"
  174.     End With
  175.     GetFirstDerivative = retval
  176. End Function
  177. Public Function GetParameterAtDistance(Dist As Double) As Double
  178.     Dim retval As Double
  179.
  180.     With objVLAX
  181.         .SetLispSymbol "handle", mvarEntity.Handle
  182.         .SetLispSymbol "dist", Dist
  183.         retval = .EvalLispExpression("(vlax-curve-getParamAtDist (handent handle) dist)")
  184.         .NullifySymbol "handle", "dist"
  185.     End With
  186.     GetParameterAtDistance = retval
  187. End Function
  188. Public Function GetParameterAtPoint(Point As Variant) As Double
  189.     Dim retval As Double
  190.
  191.     With objVLAX
  192.         .SetLispSymbol "handle", mvarEntity.Handle
  193.         .SetLispSymbol "point", Point
  194.         retval = .EvalLispExpression("(vlax-curve-getparamAtPoint (handent handle) point)")
  195.         .NullifySymbol "handle", "point"
  196.     End With
  197.     GetParameterAtPoint = retval
  198. End Function
  199. Public Function GetPointAtDistance(Dist As Double) As Variant
  200.     Dim retval As Variant, pt(0 To 2) As Double
  201.     Dim i As Long
  202.
  203.     With objVLAX
  204.         .SetLispSymbol "handle", mvarEntity.Handle
  205.         .SetLispSymbol "dist", Dist
  206.         .EvalLispExpression "(setq lst (vlax-curve-getPointAtDist (handent handle) dist))"
  207.         retval = .GetLispList("lst")
  208.         .NullifySymbol "handle", "dist", "lst"
  209.     End With
  210.
  211.     For i = 0 To 2
  212.         pt(i) = retval(i)
  213.     Next
  214.
  215.     GetPointAtDistance = pt
  216. End Function
  217. Public Function GetPointAtParameter(Param As Double) As Variant
  218.     Dim retval As Variant, pt(0 To 2) As Double
  219.     Dim i As Long
  220.
  221.     With objVLAX
  222.         .SetLispSymbol "handle", mvarEntity.Handle
  223.         .SetLispSymbol "param", Param
  224.         .EvalLispExpression "(setq lst (vlax-curve-getPointAtParam (handent handle) param))"
  225.         retval = .GetLispList("lst")
  226.         .NullifySymbol "handle", "param", "lst"
  227.     End With
  228.
  229.     For i = 0 To 2
  230.         pt(i) = retval(i)
  231.     Next
  232.
  233.     GetPointAtParameter = pt
  234. End Function
  235. Public Function GetSecondDerivative(Param As Double) As Variant
  236.     Dim retval As Variant
  237.
  238.     With objVLAX
  239.         .SetLispSymbol "handle", mvarEntity.Handle
  240.         .SetLispSymbol "param", Param
  241.         .EvalLispExpression "(setq lst (vlax-curve-getSecondDeriv (handent handle) param))"
  242.         retval = .GetLispList("lst")
  243.         .NullifySymbol "handle", "param", "lst"
  244.     End With
  245.     GetSecondDerivative = retval
  246. End Function
  247. Public Property Get length() As Double
  248.     Dim retval As Double
  249.
  250.     With objVLAX
  251.         .SetLispSymbol "handle", mvarEntity.Handle
  252.         .EvalLispExpression "(setq curve (handent handle))"
  253.         retval = .EvalLispExpression("(vlax-curve-getDistAtParam curve (vlax-curve-getEndParam curve))")
  254.         .NullifySymbol "handle", "curve"
  255.     End With
  256.     length = retval
  257. End Property
  258. Public Property Get Periodic() As Boolean
  259.     Dim retval As Boolean
  260.
  261.     With objVLAX
  262.         .SetLispSymbol "handle", mvarEntity.Handle
  263.         retval = .EvalLispExpression("(vlax-curve-isPeriodic (handent handle))")
  264.         .NullifySymbol "handle"
  265.     End With
  266.     Periodic = retval
  267. End Property
  268. Public Property Get Planar() As Boolean
  269.     Dim retval As Boolean
  270.
  271.     With objVLAX
  272.         .SetLispSymbol "handle", mvarEntity.Handle
  273.         retval = .EvalLispExpression("(vlax-curve-isPlanar (handent handle))")
  274.         .NullifySymbol "handle"
  275.     End With
  276.     Planar = retval
  277. End Property
  278. Public Property Get StartPoint() As Variant
  279.     Dim retval As Variant, pt(0 To 2) As Double
  280.     dim As Long
  281.
  282.     With objVLAX
  283.         .SetLispSymbol "handle", mvarEntity.Handle
  284.         .EvalLispExpression "(setq lst (vlax-curve-getStartPoint (handent handle)))"
  285.         retval = .GetLispList("lst")
  286.         .NullifySymbol "handle", "lst"
  287.     End With
  288.
  289.     For i = 0 To 2
  290.         pt(i) = retval(i)
  291.     Next
  292.
  293.     StartPoint = pt
  294. End Property
  295. Public Function GetClosestPointToProjection(Point As Variant, Normal As Variant, Optional Extend As Boolean = False) As Variant
  296.     Dim retval As Variant, pt(0 To 2) As Double
  297.     Dim i As Long
  298.
  299.     With objVLAX
  300.         .SetLispSymbol "handle", mvarEntity.Handle
  301.         .SetLispSymbol "givenPt", Point
  302.         .SetLispSymbol "normal", Normal
  303.         If Extend Then .EvalLispExpression "(setq ext T)"
  304.         .EvalLispExpression "(setq lst (vlax-curve-getClosestPointToProjection (handent handle) givenPt normal ext))"
  305.         retval = .GetLispList("lst")
  306.         .NullifySymbol "handle", "lst", "normal", "ext", "givenPt"
  307.     End With
  308.
  309.     For i = 0 To 2
  310.         pt(i) = retval(i)
  311.     Next
  312.
  313.     GetClosestPointToProjection = pt
  314. End Function
  315.   [/FONT]
已领礼包: 181个
 楼主| 发表于 2003-1-11 11:03:35 | 显示全部楼层
这个附件是用于vb.net的vlax类库,有兴趣的朋友可以研究一下。
发表于 2003-4-28 23:37:26 | 显示全部楼层
think you
发表于 2003-6-1 20:47:40 | 显示全部楼层
如:
DIM OBJ AS VLAX
SET OBJ =NEW VLAX
在上一行时出错,何故?
另,
上述程序行
VB并不支持
发表于 2004-3-18 19:54:00 | 显示全部楼层
终于找到lisp和vba的交流方式了
SetLispSymbol( symbolName, value)
GetLispSymbol(symbolName)
还是容易出错,主要是lisp变量类型会变化,感觉要做个完美的GetLispSymbol比较困难
发表于 2004-4-11 12:06:29 | 显示全部楼层
好东东,可惜我还不能下载。
发表于 2004-7-31 18:15:23 | 显示全部楼层
我很喜欢这个接口,万分感谢
发表于 2004-8-3 11:38:21 | 显示全部楼层
好像兼容性不是很好,使用过程有不稳定的现象
发表于 2004-8-3 17:59:56 | 显示全部楼层
好,有没有更详细的说明,acad帮助中有这个吗?
发表于 2004-8-4 08:43:44 | 显示全部楼层
VB.Net不需vlax类库,vlax类是弥补VBA的缺陷的,可以看Lisp的帮助
发表于 2004-8-7 10:45:47 | 显示全部楼层
最初由 efan2000 发布
[B]下面的类库扩充了VBA处理曲线类对象的能力。
[CODE]
VERSION 1.0 CLASS
BEGIN
  MultiUse = -1  'True
END
Attri... [/B]
VERSION 1.0 CLASS
BEGIN
  MultiUse = -1  'True
END
我搞不清这些东西是什么?所以我把他们注释掉了,可以使用,为什么??
发表于 2004-8-13 13:24:09 | 显示全部楼层
很多机器上只有按照2002 vlax类不存在,怎么注册?
发表于 2005-3-25 21:07:11 | 显示全部楼层
好象看来不错,下拉!
发表于 2005-3-31 10:33:58 | 显示全部楼层
我的CAD2002,vlax类不存在,怎么注册? 哪里有下,谢谢!!
GMT+8, 2024-5-15 04:38 , Processed in 0.193766 second(s), 61 queries , Gzip On.
© 2001-2024 Discuz! Team.
